Gscreen - a GTK / Glade / Python based screen
13 years 3 months ago #36232 by tjamscad
cmorley wrote: pushed a Gcode search feature. while in edit mode you can search for specific text
Chris M
Thanks Chris it works in simulator mode. I just noticed that when selecting run at line it automatically starts running after selecting the line. This seems dangerous to me. I think it would be best to select cycle start after selecting the run at line. Also have you had any progress on run at line loading the previous modle commands? Do my theme work for you?
13 years 3 months ago #36270 by tjamscad
Chris,
How do we change a button into just an indicator?
How do we shut down the on screen keyboard until it gets fixed so it doesnt resize the screen?
13 years 3 months ago #36278 by LAIR82
To turn off the onboard keyboard, go to the "gscreen.preferences" file and set "embedded_keyboard" to "false".
I just set-up our 15" machine to use the "industrial" skin, and have turned off the onboard keyboard, we have rubber keyboards affixed to our controls.
Rick
13 years 3 months ago #36279 by tjamscad
LAIR82 wrote: To turn off the onboard keyboard, go to the "gscreen.preferences" file and set "embedded_keyboard" to "false".
Rick
Where is that located? How was the install on your machine?
13 years 3 months ago #36281 by LAIR82
It is a hidden file, in your home directory.
Go to "Places" and click "Home Folder", then click "View" and select "Show Hidden Files".
You should find a file named ".gscreen_preferences", open that up and near the bottom you will see "embedded_keyboard=True", set that to false.
Rick
The following user(s) said Thank You: tjamscad
13 years 3 months ago #36283 by tjamscad
LAIR82 wrote: It is a hidden file, in your home directory.
Rick
Does this hide the button for keyboard toggle as well?
Time to create page: 0.463 seconds
