My custom designed GUI
10 years 4 months ago #75647 by aer73
Replied by aer73 on topic My custom designed GUI
Many thanks to both for take your time in help me.
@Cncbasher, that error is similar to mine.
@AndyPugh, can you be more explicit about filename and the component name don't match?
Don´t understand too A .comp file needs to have a component name in HAL that matches the file name.
Many thanks to both again for your help.
Kindly regards.
10 years 4 months ago #75649 by andypugh
Replied by andypugh on topic My custom designed GUI
aer73 wrote: Don´t understand too A .comp file needs to have a component name in HAL that matches the file name..
I am assuming that craftsman_toolchange is a .comp file, that might not be the case.
What is it?
The following user(s) said Thank You: aer73
10 years 4 months ago #75652 by aer73
I think maybe you have reason about comp file, beecause is a .dat file.
I attacht it.
Many thanks.
Regards.
File Name: toolchange.zip
File Size:163 B
10 years 4 months ago - 10 years 4 months ago #75654 by andypugh
[strike]The file you attached is a single byte file containing only the character "0".
Is that really your craftsman_toolchanger file?[/strike]
I found the file in the earlier zip file. It's a python file, an alternative to hal_manualtoolchange.
It seems to do the right things:
h = hal.component("craftsman_toolchange") ... h.ready()
Last edit: 10 years 4 months ago by andypugh.
10 years 4 months ago #75655 by aer73
You have reason i send a wrong file, sorry me.
But i don´t what you wanna say with the rest of your words.
Sorry again.
Many thanks for your help.
Kindly regards.
10 years 4 months ago - 10 years 4 months ago #75672 by pietvr
Replied by pietvr on topic My custom designed GUI
Hi
You will need to edit the following line in the 3 files in the bin folder (craftsmancnc, craftsman_toolchange & vfd_spindle)
sys.path.append('/home/craftsman/linuxcnc/configs/craftsmancnc/')
should be changed to your local configuration:
sys.path.append('/home/sarah/linuxcnc/configs/craftsmancnc/')
In the crafstmancnc file there is another line to be changed:
xmlname = os.path.join('/home/craftsman/linuxcnc/configs/craftsmancnc/',"craftsmancnc.glade")
to:
xmlname = os.path.join(''/home/sarah/linuxcnc/configs/craftsmancnc/'',"craftsmancnc.glade")
These files should also be set in their properties to "Execute"
The file vfd_controller in your /home/sarah/linuxcnc/configs/craftsmancnc/ folder also has the line:
needs to change to:
Note: the /sarah/ part should be changed to your local configuration name.
The file you have attached, toolchange.dat, only keeps track of what tool is currently loaded when running a gcode file.
Hope it helps
Piet
Last edit: 10 years 4 months ago by pietvr.
Time to create page: 0.388 seconds
