New GUI for embedded systems
8 years 1 month ago #117579 by Grotius
@Travis,
Peronal mail contact is not working at this forum.
You can do it by : michelwijnja
Add @
Add gmail.com
And you are ready.
8 years 1 month ago #117580 by travis.gillin
Grotius - Thanks for letting me know. I'll re-send to that address.
8 years 1 month ago #117583 by Grotius
Hi Travis,
Thanks for your invitation.
I tried to install your version.
-compiling go's good, i saw 2 warning's, can be c language warning's during compiling. not important right now.
-installing make and make clean go's good.
-./launch works, but then it stopped.
-rename a working ini startup icon into your name got following error,
for example : startup icon : /usr/bin/linuxcnc '/home/grotius/xmotion/configs/Gen2/Gen2.ini'
Maybe i missed something?
If the application will start i can make time for investegate your code.
8 years 1 month ago #117584 by travis.gillin
Grotius - Do you already have a LinuxCNC config that is running on an actual machine? If so, do a make install and edit the INI for that machine and set "display = Xmotion". Then from a TTY without X running, type linuxcnc /path/to/your/ini
Let me know how that works!
8 years 1 month ago #117655 by Grotius
Hi Travis,
I started a working axis config first.
Then i started the grotius gui to try.
I typed : linuxcnc path to ini, and i changed the display name into Xmotion.
See pic's
Can you solve this issue? I like to start up your application.
8 years 1 month ago #117660 by travis.gillin
Hey Grotius,
Do a git pull, make clean, then make. I made some changes over the weekend. Where it's complaining about the thcud pin is because I somewhat had it hardwired into my plasma configuration. I disabled the linuxcnc interactions while I develop the viewer, but you can still open the GUI and have a look around.
I notice you are trying to launch this with X open. You need to fallback to a TTY (Like Alt-F1) and kill X before launching this.
Also I noticed it's complaining about your keyboard and mouse devices. Make sure you copy the config_example.ini to /etc/Xmotion/config.ini and set the mouse and keyboard variables in the ini to the respective devices otherwise when the GUI opens you won't have keyboard or mouse input and the system will feel 'frozen' beacuse it's in KGRAPHICS mode and won't respond to a Ctrl-C or anything.
Time to create page: 0.162 seconds
