QtPYVcp - Modify GcodeEditor Colors
26 Nov 2019 18:18 #151308
by Donb9261
QtPYVcp - Modify GcodeEditor Colors was created by Donb9261
Hello,
Does anyone know how to change the colors of the GcodeEditor?
Background?
Margin?
Text?
etc...?
I have tried via QT but any changes are reverted on GUI load.
Background?
Margin?
Text?
etc...?
26 Nov 2019 19:49 #151313
by Leon82
Replied by Leon82 on topic QtPYVcp - Modify GcodeEditor Colors
Right click and edit stylesheet.
If it is in a box or window they has style sheet colors set it may override it as well
27 Nov 2019 15:19 #151354
by Donb9261
Replied by Donb9261 on topic QtPYVcp - Modify GcodeEditor Colors
I can get the background colors but cannot modify the highlighting, text colors, etc. With a dark background it makes reading the text a challenge. Not to mention the text size is too small.
From some reading it appears QsciScintilla is the editor itself but I cannot find a file that acts as the settings file nor any docs showing what parameters are available. In QtPyVCP there are 2 params... backgroundcolor and marginbackgroundcolor.
It would be nice to have some specifics on how to add additional params to the widget so that one could truly customize the look.
Thanks for the response. If I come up with a solution, I will share it.
screenshot attached of what I am talking about.
- Thank you received: 5927
27 Nov 2019 16:00 #151356
Replied by tommylight on topic QtPYVcp - Modify GcodeEditor Colors
Ohhhh I see !!!!screenshot attached of what I am talking about.
The following user(s) said Thank You: Donb9261
Time to create page: 0.298 seconds
