USB haas operator panel interface
5 years 7 months ago #202591 by andypugh
fupeama wrote: but i cant get information from
mesaflash --device 7i76e --sserial --verbose.
there is no cookie send to card.
I tried original firmware 7i76e with 2x7i76 and situation is same
whats wrong?
I know very little about Mesaflash. I suggest asking that question in the Driver Boards part of the forum where someone who does know Mesaflash migh see it.
5 years 3 months ago #214383 by Sviper
Hello
does anyone have the HAAS keyboard running on LinuxCNC using the Smart Serial? Could you provide all the important data and projects?
Greetings
The following user(s) said Thank You: GeckoWorks
5 years 3 months ago - 5 years 3 months ago #215462 by Sviper
Ok here is the other pic.
I'm holding a speaker I salvaged from a motherboard.
There is a momentary button out of the picture used to set the mega's USB chip into upload mode.
Hello
I have my Haas keyboard running with the Arduino as a USB keyboard.
However, many keys are unassigned.
Is there a way to create Hal pins from a key combination. I imagine CTRL+K --> Hal input --> cooling on for example.
Or is there someone who has a newer version incl. Hal config?
cmorley do you already have a new version?
Or a version with Smart Serial incl. the config for linuxcnc?
Last edit: 5 years 3 months ago by Sviper.
5 years 3 months ago #215628 by cmorley
I have not got back to anything more with this unfortunately.
you could use hal_input to convert the button presses to HAL pins but then you lose the regular keyboard part.
Yes many keys are not assigned - they need to be filled into the stdKeys or shiftKeys or altKeys array.
I could add another array specifically for cntrl keys too.
I have not git an STM32 running sserial yet (only played a little unsuccessfully then ran out of time).
Chris
4 years 2 weeks ago #254250 by MrJTJinx
I'm having a few issues with the arduino code and the Haas keypad on a Mega. Im not seeing many characters just a few too many square boxes ie non printable ascii characters. Its definitely a Haas keypad, its still connected to the 2002 haas mini mill. What im trying to figure out is what keys work on which row and col so that i can build a remote that will be piggybacked onto the existing ribbon cable. Im actually after the numbers and the write/enter key. could you offer any advice/assistance.
3 years 7 months ago #267473 by Kasper-001
how did it come out with this USB adapter ?  i found 2 simulators on the scrapyard, and tried to decode data from the skbif board,
