Connect PyQt Button to HAL
2 years 8 months ago #292986 by JT
I'm a bit stumped on how to connect a PyQt button clicked signal to a HAL pin.
I can create a HAL pin and see it in showhal.
    parent.hal_test = hal.component('test')     parent.hal_test.newpin('out', hal.HAL_BIT, hal.HAL_OUT)     parent.hal_test.ready()
After a lot of grepping in src/emc/usr_intf I'm still at a loss how to connect the hal component to the clicked signal of a QPushButton.
After creating the hal component do you need to install it?
JT
2 years 8 months ago #292991 by JT
Replied by JT on topic Connect PyQt Button to HAL
I did just figure out that my component is loaded and I can make a net connection to it in the postgui.hal file.
JT
2 years 8 months ago #293038 by cmorley
Replied by cmorley on topic Connect PyQt Button to HAL
How are you defining the clicked signal? from designer? in code?
Can you post your sample code for reference?
usually something like this:
button.clicked.connect(my_function)
def my_function(state):
print(state)
if state:
parent.hal_test.out.set(10)
else:
parent.hal_test.out.set(0)
2 years 8 months ago #293046 by JT
Hi Chris,
I'm trying to connect a PyQt native signal from a QPushButton like clicked, pressed etc and have that set a HAL pin.
I "think" you have given me enough clues to try and make this work. I'll give it a whirl in the morning.
JT
2 years 8 months ago #293084 by JT
With some help from the IRC this is some code:
#!/usr/bin/env python3 from PyQt6.QtWidgets import QApplication, QWidget, QVBoxLayout, QPushButton from PyQt6.QtWidgets import QSpinBox import hal, linuxcnc ''' HAL_BIT HAL_FLOAT HAL_U32 HAL_S32 HAL_U64 HAL_S64 ''' class TestWidget(QWidget):     def __init__(self):         super().__init__()         self.halcomp = hal.component('mytest')         self.halcomp.newpin('out', hal.HAL_BIT, hal.HAL_OUT)         self.halcomp.newpin('in', hal.HAL_BIT, hal.HAL_IN)         self.halcomp.newpin('value', hal.HAL_U32, hal.HAL_IN)         self.halcomp.ready()         self.setWindowTitle('Test Widget')         self.setGeometry(300, 300, 250, 150)         self.layout = QVBoxLayout()         self.setLayout(self.layout)         self.test_out = QPushButton('Test Out')         self.test_out.setCheckable(True)         self.test_out.clicked.connect(self.set_out_pin)         self.test_in = QPushButton('Test In')         self.test_in.setCheckable(True)         self.test_in.clicked.connect(self.set_in_pin)         self.number_in = QSpinBox()         self.number_in.valueChanged.connect(lambda: hal.set_p('mytest.value', f'{self.number_in.value()}'))         self.layout.addWidget(self.test_out)         self.layout.addWidget(self.test_in)         self.layout.addWidget(self.number_in)         self.test_hal = QPushButton('Test HAL')         self.test_hal.clicked.connect(lambda: hal.set_p('halui.mode.teleop', "true"))         self.layout.addWidget(self.test_hal)         self.show()     def set_out_pin(self, data):         self.halcomp['out'] = data     def set_in_pin(self, data):         self.halcomp['in'] = data     def closeEvent(self, event):         event.accept()         self.halcomp.exit() app = QApplication([]) w = TestWidget() app.exec()
and a video
JT
2 years 8 months ago #293088 by JT
I tried this minimal example using your suggestion:
#!/usr/bin/env python3 from PyQt6.QtWidgets import QApplication, QWidget, QPushButton, QVBoxLayout import hal class test(QWidget): def __init__(self): super().__init__() self.layout = QVBoxLayout() self.setLayout(self.layout) self.hal_test = hal.component('test') self.hal_test.newpin('out', hal.HAL_BIT, hal.HAL_OUT) self.hal_test.ready() self.test_out = QPushButton('Test Out') self.test_out.setCheckable(True) self.test_out.clicked.connect(self.set_out_pin) self.layout.addWidget(self.test_out) self.show() def set_out_pin(self, state): print(state) if state: self.hal_test.out.set(10) else: self.hal_test.out.set(0) def closeEvent(self, event): event.accept() self.hal_test.exit() app = QApplication([]) x = test() app.exec()
And I get this error:
john@cave:~/github/hal$ ./hal_test_2.py True Traceback (most recent call last): File "/home/john/github/hal/./hal_test_2.py", line 28, in set_out_pin self.hal_test.out.set(10) ^^^^^^^^^^^^^^^^^^^^^ AttributeError: 'bool' object has no attribute 'set' Aborted
If you don't have PyQt6 just use PyQt5 and change app.exec() to app.exec_().
Thanks for your time and help
JT
Time to create page: 0.256 seconds
