What does canon do?
  • JT
  • JT's Avatar Topic Author
  • Administrator
  • Administrator
05 Jun 2024 11:33 #302375 by JT
What does canon do? was created by JT
I see canon passed in several places in code like
lib/python/qt5_graphics.py:392:            result, seq = self.load_preview(filename, canon, unitcode, initcode)
The whole function
    def load(self,filename = None):
        s = self.stat
        s.poll()
        if not filename and s.file:
            filename = s.file
        elif not filename and not s.file:
            return
        lines = open(filename).readlines()
        progress = Progress(2, len(lines))
        # monkey patch function to call ours
        progress.emit_percent = self.emit_percent
        code = []
        i = 0
        for i, l in enumerate(lines):
            l = l.expandtabs().replace("\r", "")
            code.extend(["%6d: " % (i+1), "lineno", l, ""])
            if i % 1000 == 0:
                del code[:]
                progress.update(i)
        if code:
            pass
        progress.nextphase(len(lines))
        td = tempfile.mkdtemp()
        self._current_file = filename
        try:
            random = int(self.inifile.find("EMCIO", "RANDOM_TOOLCHANGER") or 0)
            arcdivision = int(self.inifile.find("DISPLAY", "ARCDIVISION") or 64)
            text = ''
            canon = StatCanon(self.colors,
                                self.get_geometry(),
                                self.foam_option,
                                self.lathe_option,
                                s, text, random, i,
                                progress, arcdivision)
            # monkey patched function to call ours
            canon.output_notify_message = self.output_notify_message
            parameter = self.inifile.find("RS274NGC", "PARAMETER_FILE")
            temp_parameter = os.path.join(td, os.path.basename(parameter or "linuxcnc.var"))
            if parameter:
                shutil.copy(parameter, temp_parameter)
            canon.parameter_file = temp_parameter
            unitcode = "G%d" % (20 + (s.linear_units == 1))
            initcode = self.inifile.find("RS274NGC", "RS274NGC_STARTUP_CODE") or ""
            if result > gcode.MIN_ERROR:
                self.report_gcode_error(result, seq, filename)
            self.logger.set_depth(self.from_internal_linear_unit(self.get_foam_z()),
                       self.from_internal_linear_unit(self.get_foam_w()))
            self.calculate_gcode_properties(canon)
        except Exception as e:
            print (e)
            self.gcode_properties = None
        finally:
            shutil.rmtree(td)
            if canon:
                canon.progress = DummyProgress()
            try:
                progress.done()
            except UnboundLocalError:
                pass
        self._redraw()
class StatCanon(glcanon.GLCanon, interpret.StatMixin):
    def __init__(self, colors, geometry, is_foam, lathe_view_option, stat, random, text, linecount, progress, arcdivision):
        glcanon.GLCanon.__init__(self, colors, geometry, is_foam)
        interpret.StatMixin.__init__(self, stat, random)
        self.lathe_view_option = lathe_view_option
        self.text = text
        self.linecount = linecount
        self.progress = progress
        self.aborted = False
        self.arcdivision = arcdivision
    def is_lathe(self): return self.lathe_view_option
    def change_tool(self, pocket):
        glcanon.GLCanon.change_tool(self,pocket)
        interpret.StatMixin.change_tool(self,pocket)
    # not sure if this is used - copied from AXIS code
    def do_cancel(self, event):
        self.aborted = True
    def check_abort(self):
        #root_window.update()
        if self.aborted: raise KeyboardInterrupt
    def next_line(self, st):
        glcanon.GLCanon.next_line(self, st)
        self.progress.update(self.lineno)
        if self.notify:
            self.output_notify_message(self.notify_message)
            self.notify = 0
    # this is class patched
    # output the text from the magic comment eg: (PREVIEW,notify,The text)
    def output_notify_message(self, message):
        pass
Just trying to understand what's doing what and why.
JT
06 Jun 2024 12:33 #302464 by Aciera
Replied by Aciera on topic What does canon do?
I think 'canon' here points to the current instance of StatCanon (not sure if that is the correct terminology though).
This is line 322 'lib/python/gremlin.py':
canon = StatCanon(self.colors, self.get_geometry(),self.lathe_option, s, random)
and this is line 80:
class StatCanon(rs274.glcanon.GLCanon, rs274.interpret.StatMixin):
    def __init__(self, colors, geometry, lathe_view_option, stat, random):
        rs274.glcanon.GLCanon.__init__(self, colors, geometry)
        rs274.interpret.StatMixin.__init__(self, stat, random)
        self.progress = DummyProgress()
        rs274.glcanon.GLCanon.change_tool(self,pocket)
        rs274.interpret.StatMixin.change_tool(self,pocket)
  • JT
  • Administrator
  • Administrator
06 Jun 2024 15:40 #302480 by JT
Replied by JT on topic What does canon do?
Yes, I know canon = StatCanon(...) but what does StatCanon do?
JT
  • MennilTossFlykune
  • Senior Member
  • Senior Member
06 Jun 2024 23:37 #302498 by MennilTossFlykune
Replied by MennilTossFlykune on topic What does canon do?
canon is used to call Python functions from C++
  • Moderator
  • Moderator
07 Jun 2024 01:31 #302500 by tommylight
Replied by tommylight on topic What does canon do?
I might be off, but GLcanon is part of LinuxCNC, the python part that probably deals with OpenGL, and it is mentioned several times on your code above, and i am sure there is a file named glcanon.py included with LinuxCNC, so maybe having a look there sheds some light ... or turns out to be a deep rabbit hole ! :)
07 Jun 2024 11:12 - 07 Jun 2024 11:13 #302528 by Aciera
Well, I'm certainly not the python expert but if we follow the trail then it seems to initialize these two classes which can be found in /lib/python/rs274/glcanon.py and /lib/python/rs274/interpret.py
Which are used to set up the preview window depending on the geometry of the config and also (I guess) the tool preview. As for the more intricate details of the code, I'm probably not the right person to answer.
Last edit: 07 Jun 2024 11:13 by Aciera.
  • JT
  • Administrator
  • Administrator
07 Jun 2024 11:30 #302529 by JT
It's a very deep and cornfusing rabbit hole for sure.
It looks to me that all the graphics previews are a copy of what Axis has with some variations.
JT
07 Jun 2024 11:43 #302530 by Aciera
Yes, with the exeption of 'Probe Basic'.
forum.linuxcnc.org/qtpyvcp/52562-preview...-program-path#300022
  • Moderator
  • Moderator
08 Jun 2024 05:48 #302605 by tommylight
I think Probe Basic uses VTK for preview, from reading here as it was mentioned in regards to RPI not having VTK support, and i recall something was done to make it work.
Me not helping ... :)
  • JT
  • Administrator
  • Administrator
08 Jun 2024 10:50 #302619 by JT
I worked for a while on QtPyVCP and the VTK plotter.
JT
Moderators: JT
Time to create page: 0.156 seconds
