Touchy error
- Roobarb
29 Nov 2024 19:05 #315574
by Roobarb
Touchy error was created by Roobarb
Hello CNC'ersGreat forum all, many many questions already answered !Many thanks..however....Am trying to configure Linxcnc using Touchy UI.I keep hitting the same error, see attached report.If I switch the UI to Axis in the ini file, it starts no problem.I've searched on the forum but there is surprisingly little on Touchy and seemingly nothing for the warning the report gives.I'm using a stock OS Linuxcnc image for the RPI 4B with a Mesa7i96s, nothing convoluted. Debian 12/Linuxcnc2.9.1All advice welcome !!
- Thank you received: 7478
29 Nov 2024 19:16 #315577
Replied by tommylight on topic Touchy error
GTK warnings, probably due to new versions using GTK3 instead of GTK2.
- Thank you received: 2176
29 Nov 2024 19:22 #315580
Replied by Aciera on topic Touchy error
Does the included simulation config work?
'configs/sim/touchy/touchy.ini'
- JT
- Thank you received: 593
30 Nov 2024 12:41 #315646
by JT
Replied by JT on topic Touchy error
- Roobarb
30 Nov 2024 21:55 #315689
by Roobarb
Replied by Roobarb on topic Touchy error
Didn't know those existed...
Interestingly yes the SIM ran up no problem.
For those looking for the sim files, they live in :
/usr/share/doc/linuxcnc/examples/sample-configs/sim/touchy
Now, I need to think about why that worked....
- Roobarb
30 Nov 2024 21:59 #315691
by Roobarb
Ah, that looks interesting...food for thought...
- Thank you received: 2181
01 Dec 2024 03:27 #315702
Replied by cmorley on topic Touchy error
There is QtTouchy available in linuxcnc as well.
- JT
01 Dec 2024 13:41 #315731
by JT
01 Dec 2024 14:23 #315732
01 Dec 2024 21:27 #315758
Hey John, can you run it in a terminal so I can see what line the error came from?
Newer versions of Qt are picker about ints and floats.
Time to create page: 0.417 seconds
