Large File Memory
14 Dec 2024 13:56 #316644 by kjlty
Large File Memory was created by kjlty
14 Dec 2024 14:01 #316645 by kjlty
Replied by kjlty on topic Large File Memory
Hello expert, look at the picture description, can you optimize the memory usage?专家你好,看图片描述,你能优化内存使用吗?
14 Dec 2024 18:19 #316662 by JT
Replied by JT on topic Large File Memory
(PREVIEW, stop) is some other GUI command, in Flex you uncheck the show program button like I showed above. I have no control over what LinuxCNC does when you open a program, I can only turn off or on the preview.
gnipsel.com/linuxcnc/flexgui/plotter.html#display
JT
16 Dec 2024 09:54 #316737 by kjlty
Is there any way to improve the loading speed of G-CODE, reduce the memory footprint, and operate the response speed of G5X? Updating the plot in real time is too much of an impact on the experience, and the GUI is unresponsive.
16 Dec 2024 12:09 #316745 by JT
Sure just delete the plotter.
JT
16 Dec 2024 13:16 #316751 by kjlty
Deleting the plot page in QT-Designer has no effect.
16 Dec 2024 13:37 #316754 by kjlty
I don't think plotter is a must-have feature, and if you can optimize the responsiveness of the Flex GUI to large files, then it's perfect. Thank you!
16 Dec 2024 15:07 #316763 by JT
Does Axis open that large file without any delay?
JT
17 Dec 2024 02:21 #316827 by cmorley
Replied by cmorley on topic Large File Memory
Could be the gcode text preview. The high lighting can be cpu intensive.
Could you post a sample large file that shows the problem?
17 Dec 2024 04:55 #316834 by kjlty
AXIS also takes a long time to open it, plus (AXIS, stop) is the same (BUG?), tklinuxcnc response is positive, whether it is loading G-CODE or artifact coordinate offset, but it only has 3 axes.
Time to create page: 0.407 seconds
