FlexGui - hal_io Spinbox
- MaHa
- Thank you received: 199
29 Oct 2025 23:12 #337422
by MaHa
FlexGui - hal_io Spinbox was created by MaHa
From a postgui hal file are some flexhal pins set at startup, with setp. In halshow the value is set, but the spinbox is not populated with that value. How can i force the spinbox to update?
- JT
- Thank you received: 539
30 Oct 2025 14:20 - 30 Oct 2025 16:40 #337487
by JT
Replied by JT on topic FlexGui - hal_io Spinbox
I'll have to check that out.
Edit: This will take some thought to have the spinbox updated from the hal pin and the hal pin updated from the spinbox without a fight as to who is in control of the value.
JT
JT
Last edit: 30 Oct 2025 16:40 by JT.
- JT
30 Oct 2025 20:23 #337526
by JT
Looks like I never did finish the HAL I/O but it's finished now and working as expected. If the HAL value changes the widget value or state changes to match and if the widget value or state changes then the HAL pin is updated.
JT
JT
The following user(s) said Thank You: tlightus, tommylight, MaHa
Moderators: JT
Time to create page: 0.083 seconds
