Scaling 0-1024 to 0-102
20 Aug 2024 00:22 - 20 Aug 2024 00:24 #308179 by slowpoke
Scaling 0-1024 to 0-102 was created by slowpoke
I have an exposed analog from pot value in HAL "arduino.ain.0"  (range is 0-1024), and I want to drive "halui.axis.jog-speed" with that value divided by 10
1) Am I best to use mult2, scale or something else?
2) How to implement whatever you suggest?
Much appreciated.
This entire HAL concept and the implementation with HALShow is simply fantastic!
I cobbled together a really rough around the edges (proof of concept) gadget to test messaging before going to an actual PCB and so far so good, All the buttons are working, Pot's next and then a few messages to the display and proof of concept will be complete.
Last edit: 20 Aug 2024 00:24 by slowpoke.
20 Aug 2024 01:54 #308183 by Benb
Replied by Benb on topic Scaling 0-1024 to 0-102
The following user(s) said Thank You: slowpoke
20 Aug 2024 09:22 - 20 Aug 2024 09:24 #308203 by slowpoke
Replied by slowpoke on topic Scaling 0-1024 to 0-102
Thanks for that.
The visual (block diagram) explanation works much better for me than the plain text explanation that I initially found.
excerpt from my postgui for anyone trying to figure this out in the future.... this works for me:
#  Analog Inputs - Jog Speed
loadrt scale count=1
addf scale.0 servo-thread
setp scale.0.offset 0.0
setp scale.0.gain 0.12
net jog-pot-in scale.0.in <= arduino.ain.0
net jog-speed halui.axis.jog-speed <= scale.0.out
Last edit: 20 Aug 2024 09:24 by slowpoke.
