GladeVCP HAL pin not found
9 years 7 months ago #90195 by Chre9
Replied by Chre9 on topic GladeVCP HAL pin not found
Right, I changed gladevcp.hal_led1 to status.hal_led1 after seeing, that it's the name of the pin.
Sorry for being so unclear!
So if I uncomment it I get the error
9 years 7 months ago #90197 by andypugh
Replied by andypugh on topic GladeVCP HAL pin not found
So, it tells you that the pin does exist in the pin list, then tells you that it doesn't exist in an error message?
Are you _absolutely_ sure that the INI file is not referencing the same postgui HAL file?
Maybe change the name of this HAL file, just to be certain.
The following user(s) said Thank You: Chre9
9 years 7 months ago #90202 by Chre9
You were kind of right, the Ini refers to a file called "postgui_call_list.hal", which includes the line "source custom_postgui.hal".
I don't know why it's in there, but it seems to have caused the problem.
I changed the name of the file and it works now.
Thanks for your help! ;)
Moderators: HansU
Time to create page: 0.261 seconds
