GladeVCP panel fails to launch intermittently
2 months 3 weeks ago #348634 by scsmith1451
My GladeVCP panel fails to launch intermittently. The only errors that are found in the report are:
GladeVCP.QTVCP.QT_ISTAT][^[[33mWARNING^[[0m]  INI Parsing Error, No MIN_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 0.5 (qt_istat.py:532)
**** GLADE VCP ERROR:    With xml file: crosshair_panel.glade : 'gi.repository.Gtk' object has no attribute 'glade'
and:
crosshair_panel.hal:7: Pin 'crosshair_panel.crosshair-ctl-active' does not exist
The second error is thrown because the panel fails to launch.  The reference to the pin is in my postgui_hal file.
How do I diagnose and repair this issue.
Regards,
2 months 3 weeks ago #348648 by scsmith1451
Update: I uninstalled Glade and then reinstalled it. The issue still persists.
The errors thrown during launch not reads:
tool_mmap_user(): tool mmap not available
poll(): continuing without tool mmap data
gtk-builder-error-quark: crosshair_panel.glade:12:34 Invalid property: HAL_Table.n-rows (11)
when launched from the panel from the command line:
$ gladevcp crosshair_panel.glade
Maybe I need to reinstall linuxcnc?
Regards,
2 months 3 weeks ago #348654 by tuxcnc
I can't help you, but have a suggestion.
The "object has no attribute" is python's error and means "python can not finds", probably due bad path.
For me often helps to install python package in both ways, deb package and pip package.
The following user(s) said Thank You: scsmith1451
1 month 4 days ago #349964 by HansU
You could post your crosshair_panel.glade and crosshair_panel.hal then we will have a chance to help you ;-)
1 week 4 days ago #350385 by scsmith1451
Hi HansU,
I'm not sure the files are the issue since nothing has changed since the panel last functioned properly. However, I've attached both files.
Thanks for working with me.
Kind Regards,
Moderators: HansU
Time to create page: 0.359 seconds
