Spindle PID close loop goes to the maximum value
7 years 11 months ago - 7 years 11 months ago #120845 by gantarone
Hi ,
I have a mesa 7i76e and a 7i85 ,
I'm trying to do a Close Loop Spindle but I think I have a configuration problem in my HAL
The encoder work well with exact value of rpm (on GUI)
when I try to set any speed value my Spindle goes to its maximum speed
Ex. S1000 the spindle goes to 7000 rpm
I tried to change the pid values ​​but the result does not change ....
attached my ini and hal files
Any help is appreciated!!!!
Last edit: 7 years 11 months ago by gantarone.
7 years 11 months ago - 7 years 11 months ago #120848 by PCW
The spindle PID feedback term is linked to the signal spindle-vel-fb-rpm:
net spindle-vel-fb-rpm => pid.s.feedback
but spindle-vel-fb-rpm is not driven (so will always be 0)
You probably want the PID feedback to come from the signal spindle-fb-rpm-abs:
net spindle-fb-rpm-abs abs.spindle.out => lowpass.spindle.in
Last edit: 7 years 11 months ago by PCW.
The following user(s) said Thank You: gantarone
7 years 11 months ago #120851 by alan_3301
Is this might be another pncconf bug? I had the same issue. It set net spindle-vel-fb-rpm => pid.s.feedback instead of net spindle-vel-fb-rpm-abs => pid.s.feedback
7 years 11 months ago #120852 by PCW
Yes I think this is another pncconf bug
7 years 11 months ago #120859 by gantarone
Thanks for quick replay.....
I'll test it soon!!!
7 years 11 months ago #120984 by gantarone
It woks!!!!
just another question ... can I see the PID "Calibration" Spindle like as axes (JOINT_0, JOINT_1, JOINT_N) to modify on fly PID?
Time to create page: 0.315 seconds
