RS485 Communication Problem with HY Inverter
7 years 1 month ago #145765 by macsddau
Hi.
I'm trying to control the 2.2kW spindle connected to a Huanyang Inverter HY022223B through the RS485 link.
I have followed this video tutorial to help me configuring.
But nothing append. Spindle doesn't work.
I have found on the forum command lines to get some test out of LinuxCNC.
halcmd loadusr -Wn spindle-vfd hy_vfd -n spindle-vfd -t 1 -d /dev/ttyUSB0 -p none -r 9600 -s 1 halcmd setp spindle-vfd.enable 1
The last line return infinite error :
ERROR invalid crc received 6100 - crc_calc 9664 (-16) error reading setup from VFD, retrying
Can you help me to solve this issue ?
7 years 1 month ago #145831 by Hakan
Double and triple check that the settings in PD16x matches what you have on the loadrt line.
Other than that it can be a cabling issue. I have had good luck with a twisted cable pair from
a network cable. You can also try to connect the cable with reversed polarity.
Also make sure the copper is in contact in the terminal of the vfd and not the insulation of the cable. Don't ask...
The following user(s) said Thank You: macsddau
7 years 1 month ago #145835 by macsddau
Thanks Hakan.
Effectively, Pinout of USB converter is not written on it. Data- and Data+ were inverted.
I can now run the spindle with LinuxCNC !
7 years 1 month ago #145854 by pl7i92
Hi please for the others with the same Problem facing it
can you do a QUICK image and connection schema
that will help more of NEW CNC people
7 years 1 month ago #145865 by macsddau
Here some pictures :
The USB to RS485 converter :
White wire (D+) has to be inverted with the blue wire (D-). pinout of the converter is :
LeftGND
CenterD+
RightD-
Cable is a twisted shield pair without connecting shield (length is above 1,2m 47in) and RS485 works not very quickly (9600 Bauds)
And the connection into the HY inverter :
There's no schematic.
The Router CNC console is now closed. I will normally not open it yet until router table is made ... wait and see...
7 years 1 week ago #148508 by ronny130286
you can try this: github.com/esp8266/source-code-examples/issues/26
I had a similar problem, the result, my Debian 9 user had no rights to read the dev/tty*. You can temporarily test with the description in the first post (see link) if it's okay so do this from second post.
Maybe it helps.
Time to create page: 0.300 seconds
