CNC Homing is not working
5 years 1 month ago #220028 by kedgardov
Good afternoon,
I'm running a  3axis (XXYZ) CNC mill machine that is kind of working so far. Manual homing works good enough run tests and they turn out fine. Now I'm trying to auto home my machine using limit switches (All home+ limit configuration )all connected to a single pin. It should home Y axis first, followed by both motors on X axis and finally Z axis. However from the very beginning, the Y axis keeps moving even after triggering the switch. I tested the switches in the halmeter and they trigger the signal ok. I want to know why the Y motor won't stop and go back after triggering the switch. I'm attaching my INI and HAL files.
5 years 1 month ago - 5 years 1 month ago #220029 by Aaroncnc
Replied by Aaroncnc on topic CNC Homing is not working
Maybe try adjusting the "HOME_SEQUENCE = " to the following
y=0 (it will go first)
x=1 (second)
z=2 (third)
Last edit: 5 years 1 month ago by Aaroncnc.
5 years 1 month ago #220032 by PCW
Replied by PCW on topic CNC Homing is not working
The all limit signal is not connect to any joints as far as I can see:
that is, you have:
# --- ALL-LIMIT-HOME ---
net all-limit-home <= hm2_7i76e.0.7i76.0.0.input-16-not
but all-limit-home is not connected to any joint home or limit pins
5 years 1 month ago #220035 by kedgardov
Replied by kedgardov on topic CNC Homing is not working
Thanks for pointing that out.
How can I do that? Is it on the ini or Hal file? Or how can I look for that documentation
5 years 1 month ago #220039 by PCW
by changing
# ---setup home / limit switch signals---
net x-home-sw => joint.0.home-sw-in
net x-neg-limit => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
to
net all-limit-home => joint.0.home-sw-in
net all-limit-home => joint.0.neg-lim-sw-in
Assuming that home is also negative limit
You would need to do this for all joints
5 years 1 month ago #220075 by kedgardov
Thank you very much! It is now stopping however, I now get joint errors after the switch is triggered. I'm guessing it has to do with all joints sharing limit switches, but I think that's what the all home + switch setup was solving
Time to create page: 0.461 seconds
