(SOLVED) Spindle RPM - FWD/REV difference
- spumco
- Thank you received: 788
09 Mar 2022 01:05 #236728
by spumco
(SOLVED) Spindle RPM - FWD/REV difference was created by spumco
[MX21, LCNC 2.9, Probe Basic master, 7i76ED, first time Lcnc user (been fiddling with this for a while, off and on)]
I've got a problem and I'm not sure where to start the troubleshooting. Spindle runs at commanded RPM in forward but not reverse.
VFD (GS3) is controlled via 0-10v from 7i76ED. Direct motor encoder feedback to VFD and to Lcnc, but Lcnc is open loop (P/I/D = 0 in .ini file)
When I command reverse, I get about 150-200RPM regardless of the desired speed. Forward is fine from 100-8krpm, and the VFD analog offset/gain is tuned up so it's holding nicely within 10-50rpm at any speed.
VFD is reporting accurately; i.e. when I command "M3 S2000" I see ~2000rpm on both the VFD display and in halshow.
When I command "M4 S2000" I get spindle.0.out = 2000, but the VFD reports ~175rpm and the actual output in halshow is also ~175rpm. Same response whether I use the GUI spindle FWD/REV buttons or MDI.
Spindle override responds appropriately in both GUI slider and my hal-connected panel encoder.
Direct control of the VFD via drive software and keypad works as expected in both FWD & REV.
Anyone have an idea where to start fiddling?
Thanks,
Ralph
Thanks,
Ralph
- Thank you received: 5159
09 Mar 2022 01:18 #236729
Replied by PCW on topic (SOLVED) Spindle RPM - FWD/REV difference
net spindle-vel-cmd-rpm => pid.s.command
would need to be:
net spindle-vel-cmd-rpm-abs => pid.s.command
additional changes would be needed if the PID loop was used
for spindle speed feedback (it's not currently )
would need to be:
- spumco
09 Mar 2022 01:29 #236731
by spumco
Replied by spumco on topic (SOLVED) Spindle RPM - FWD/REV difference
Well, that was easy. As usual, thank you PCW!
For my Lcnc education... if you don't mind, can you explain how the 'abs' (absolute?) changed the system response?
- Thank you received: 6913
09 Mar 2022 01:35 #236732
Replied by tommylight on topic (SOLVED) Spindle RPM - FWD/REV difference
Leme give it a try:
ABS always outputs positive values, regardless if the input is positive or negative.
Anyone, please correct me if i am wrong.
09 Mar 2022 01:44 #236734
That's correct, and the 7I76E spindle analog output only works properly
with positive values
The following user(s) said Thank You: tommylight, spumco
- spumco
09 Mar 2022 02:18 #236736
by spumco
You guys are awesome.
09 Mar 2022 02:38 #236737
Title set to "solved" for all replies.
Thank you.
Thank you.
- BigJohnT
- Thank you received: 1175
09 Mar 2022 23:22 #236789
by BigJohnT
Replied by BigJohnT on topic (SOLVED) Spindle RPM - FWD/REV difference
Going to check that my 7i76e Configuration Tool does spindle correctly.
JT
JT
Time to create page: 0.366 seconds
