Creating DXF's from probing points
4 years 8 months ago #235670 by robertspark
I'm sure that this has probably been done before,
I was wondering if anyone has created a DXF file from an array of probing points, or on the fly whist creating a probing routine?
The most simple format seems to be to save the file as a R12 DXF so that the header info is not important (required).
The most basic dxf (R12) file seems to be:
0 ENDSEC 0 SECTION 2 ENTITIES 0 ENDSEC 0 EOF
Which is basically a blank file (but it loads without error).
for a simple DXF (R12) with a line it would be as follows:
0 ENDSEC 0 SECTION 2 ENTITIES 0 LINE 8 0 10 0 20 0 30 0 11 0 21 150 31 0 0 ENDSEC 0 EOF
Seems to open ok in LibreCAD + Autocad 2020.
Whilst I can crate a probing routine to create a load of line entities (editing the smartprobe.ngc file)
I was wondering if anyone has done any work with polylines / splines as that would probably be more useful as a blended / curve fit application
I'm just dabbling thats all, thanks,
4 years 8 months ago #235703 by robertspark
stumbled across this one from Andy:
Nice  + Simple + Thanks :)
;probe a profile ;the routine will initially probe in negative Y and will walk around the profile clockwise ;but can follow a re-entrant shape #1 = 0 (explore angle) #2 = #5420 (start positions) #3 = #5421 #4 = 3 (step size) #5 = 0.5 (retract on sucessful probe) (AXIS,stop) (LOGOPEN,profile.txt) O100 WHILE [1]     G38.3 F100 X[#2 + #4 * COS[#1 - 90]] Y[#3 + #4 * SIN[#1 - 90]]     O101 IF [#5070 EQ 1]         G38.5 F20 X#2 Y#3 (slow probe away, store point)         (LOG, #5061, #5062)         #2 = [#5061 + #5 * COS[#1 + 90]]          #3 = [#5062 + #5 * SIN[#1 + 90]]         G0 X#2 Y#3 (1mm back along probe track)         O102 DO             G38.5 F500 X#2 Y#3             G38.3 F500 X[#2 + #4 * COS[#1]] Y[#3 + #4 * SIN[#1]]             O103 IF [#5070 EQ 1]                 #1 = [#1 + 15]             O103 ENDIF         O102 WHILE [#5070 EQ 1]         #2 = #5420         #3 = #5421     O101 ELSE         (missed, so now start a clockwise polygon looking for the edge)         #1 = [#1 - 15]     O101 ENDIF O100 ENDWHILE (LOGCLOSE) M2
4 years 8 months ago - 4 years 8 months ago #235736 by jtc
Some years ago I create a simple program that import a log file and create a dxf file where the log points are circles connected by lines.
It turned to be very useful various times.
MDI comands, by order:
(LOGOPEN,filename.txt) (log,#<_x> ,#<_y> ) (logclose)
python program:
import csv import sys import ezdxf f = open('filename.txt', 'rt') try:     teste= list(csv.reader(f))     drawing = ezdxf.new(dxfversion='AC1024')     modelspace = drawing.modelspace()     drawing.layers.new('circle', dxfattribs={'color': 2})     drawing.layers.new('line', dxfattribs={'color': 3})    # print (teste[0],teste[1])     i=0     for point in range(0,len(teste)-1):         modelspace.add_line(teste[i],teste[i+1],dxfattribs={ 'layer': 'line'})         i=i+1     for point in range(0,len(teste)):         modelspace.add_circle(teste[point],3,dxfattribs={ 'layer': 'circle'}) finally:     f.close()     drawing.saveas('log2dxf.dxf')
João
Last edit: 4 years 8 months ago by jtc.
The following user(s) said Thank You: robertspark
4 years 8 months ago #235750 by robertspark
very nice thanks,
I was looking at ezdxf
ezdxf.readthedocs.io/en/stable/
much appreciated
Time to create page: 0.058 seconds
