- Thank you received: 240
Once I get there, I can let you know if there's any more errors. I can tell you this, though - at least this time when I installed, the updates and package manager are actually working and erroring out, so I have more confidence that I had a dodgy installation the last few days and that this one is working.
ArcEye wrote:
The reason why I didn't put the name of the display manager, is because it depends which desktop you chose at installation.
ArcEye wrote: sudo service [program] start/stop/restart is now the prefered way to address anything in the /etc/init.d/ folder
I must admit I generally address directly just out of habit
ArcEye wrote: The package xinput-calibrator is in sid, you would need to add that stanza to your /etc/apt/sources.list
The problem might be that it requires too high a version number of libc6
The actual errors will tell you what is wrong, albeit sometimes obtusely and only for the first error it hit
That's the kind of stuff that we need to know. I'll Google later and try to figure out how to add that in. Been way too long for me to even attempt to recall.
ArcEye wrote: Same as your other lines except replace wheezy main contrib non-free with sid main contrib non-free
If several packages exist but you want a particular one you can specify the archive with
apt-get install -t sid [name-of-package]
Generally safest to keep the repo stanzas you don't normally use commented out, then enable them and and run apt-get update before using, then comment out and run apt-get update again.
That way you don't run the risk of running apt-get dist-upgrade and finding you have upgraded to Jessie :laugh:
So, using the /etc/apt/sources.list is there a way to add a specific package in a specific repository without allowing everything else in there? Something to the effect of " use this repository to keep this package updated, and only this package " , such that one would not need to remember to fiddle with commenting out and in entries without endangering oneself in the manner you point out?
