How to Install Debian 8.2 "Jessie" and LinuxCNC2.7
10 years 10 months ago #66393 by LinuksGuru
Does LinuxCNC have its own kernel modules?
In other words, does it depend upon particular kernel version, or RT patch is enough?
  • jepler
  • Administrator
  • Administrator
10 years 10 months ago #66422 by jepler
"uspace" linuxcnc does not use any kernel modules, so it is not dependent on having a specific matching kernel version number like "rtai" linuxcnc is.
10 years 9 months ago - 10 years 9 months ago #68757 by mstrick96
Thanks, Grub!
Your tutorial is helpful. I'm not a newbie, but am also not experienced.
I am currently running Wheezy that I installed from the live cd. I've been playing with installing and compiling packages and would like to try an install like yours.
Question... do I need to wipe out my current Wheezy installation first or can I just install Jessie on top of it?
UPDATE: I decided to blow away everything and install over the entire disk. Was dual booting with XP, but now XP is no more! Have installed freecad and teamviewer. Next is linuxcnc!
Last edit: 10 years 9 months ago by mstrick96. Reason: Update
10 years 8 months ago #69785 by vre
jepler wrote: "uspace" linuxcnc does not use any kernel modules, so it is not dependent on having a specific matching kernel version number like "rtai" linuxcnc is.
can i install linuxcnc uspace on jessie-amd64 to control machine from parport or it is only for simulation ?
10 years 8 months ago - 10 years 8 months ago #69791 by PCW
Depends on the hardware, in my experience Preempt-RT has similar latency to RTAI on fast hardware
(Sandy bridge range) and significantly worse latency that RTAI on slow hardware ( Intel Atoms etc )
Last edit: 10 years 8 months ago by PCW.
10 years 8 months ago - 10 years 8 months ago #69793 by vre
RTAI linuxcnc will be available for jessie i386 or amd64 ?
repos here are empty
linuxcnc.org/dists/jessie/2.7-rtai/
Last edit: 10 years 8 months ago by vre.
Time to create page: 0.386 seconds
