linux preempt and mesa ethernet card
11 years 2 weeks ago - 11 years 2 weeks ago #63886 by grub
Following PCW's comment,
need to install the uspace version of LinuxCNC
it might be more sensible to install a clean version of Debian and then add the RT/Preempt kernel, rather than to basically completely change the pre-configured setup from RTAI to RT/Preempt.
All the information for a clean install can be found here:
linuxcnc.org/docs/2.7/html/getting-start...th_preempt_rt_kernel
if there are any gaps in the documentation you can fill them with information from this post:
linuxcnc.org/index.php/german/forum/9-in...ssieq-and-linuxcnc27
Just make Jessie -> Wheezy, stick with 32-bit and you should have the desired outcome.
If you get stuck somewhere feel free to post in this board.
P.S. Can't really help you with the hardware. You might want to open another topic to elaborate on that one, as this one might attract the wrong (help with OS/Software) people.
Last edit: 11 years 2 weeks ago by grub.
The following user(s) said Thank You: johannbuck
11 years 2 weeks ago - 11 years 2 weeks ago #63889 by PCW
johannbuck wrote: Thanks everyone, I think I'm finally ready to Install and use the preempt linuxcnc as soon as my ITX gets here.
I'm now ready to order the 7i92 and PCW, do I need the 7i76 breakout card or is there another one better for
connecting stepper drivers.
If you already have a parallel port breakout board you can use that with a 7I92
If you need a lot of I/O you can use a 7I92 with a 7I76, but in that case you are better off with a a 7I76E
(which does not need the 7I92 since the Ethernet interface is on board)
Last edit: 11 years 2 weeks ago by PCW.
Time to create page: 0.058 seconds
