Missing command on installing_on_ubuntu_precise?
10 years 9 months ago #68694
by me_cnc
Missing command on installing_on_ubuntu_precise? was created by me_cnc
Greetings,
While working through the instructions on to install linuxcnc on Ubuntu Precise located here:
linuxcnc.org/docs/html/getting-started/g...ng_on_ubuntu_precise
Step 4 says:
Add a new apt source
deb linuxcnc.org/ precise base 2.7-rtai
This returns the error
deb command not found
Shouldn't the command be something like:
sudo add-apt-repository " linuxcnc.org/ precise base 2.7-rtai"
Thanks,
Marc
Step 4 says:
Thanks,
Marc
10 years 9 months ago - 10 years 9 months ago #68696
by ArcEye
No, the docs just assume too much knowledge
Should read something like:
Add a new apt source to the /etc/apt/sources.list file with
echo "deb linuxcnc.org/ precise base 2.7-rtai" >> /etc/apt/sources.list
or by opening /etc/apt/sources.list in an editor and inserting manually.
Your solution would probably work except that add-apt-repository is not a default package on most distros, so would have to be installed specially.
The above will work wherever.
Replied by ArcEye on topic Missing command on installing_on_ubuntu_precise?
sudo add-apt-repository "linuxcnc.org/ precise base 2.7-rtai"
Last edit: 10 years 9 months ago by ArcEye.
10 years 9 months ago #68718
by me_cnc
Replied by me_cnc on topic Missing command on installing_on_ubuntu_precise?
Thanks for the reply, much appreciated.
I'm new to the community, where does one submit a bug report for this sort of thing?
Thanks,
Marc
Thanks,
Marc
10 years 9 months ago #68720
by BigJohnT
Replied by BigJohnT on topic Missing command on installing_on_ubuntu_precise?
Or it could read "open the Synaptic Package Manager" and add the deb...
Software bugs go to github.com/LinuxCNC/linuxcnc/issues . I fix most document errors as I read about them... when I don't forget.
JT
JT
10 years 9 months ago #68740
by ArcEye
Yes, or that too
I never tend to think of doing things in Synaptic
Yes, or that too
10 years 9 months ago #68762
by me_cnc
Still having a problem, the deb URL needs to be modified.
>>sudo echo "deb linuxcnc.org/ precise base 2.7-rtai" >> /etc/apt/sources.list
>>sudo apt-get update
E: Malformed line 9 in source list /etc/apt/sources.list (URI parse)
E: The list of sources could not be read.
I spent sometime looking but could not find the sources themselves. What is the URL for the deb sources to add to /etc/apt/sources.list?
Thanks,
Marc
>>sudo apt-get update
Thanks,
Marc
Time to create page: 0.335 seconds
