Missing command on installing_on_ubuntu_precise?
10 years 9 months ago - 10 years 9 months ago #68763 by ArcEye
Looking at the repo
www.linuxcnc.org/dists/precise/
You probably need to remove the base section so it reads
http://deb linuxcnc.org/ precise 2.7-rtai
[strike]There are normally only 2 arguments suite and components[/strike]
EDIT:
Actually not true, ignore, see next post
Last edit: 10 years 9 months ago by ArcEye.
10 years 9 months ago #68807 by ArcEye
me_cnc wrote: Still having a problem, the deb URL needs to be modified.
>>sudo echo "deb linuxcnc.org/ precise base 2.7-rtai" >> /etc/apt/sources.list
>>sudo apt-get update
E: Malformed line 9 in source list /etc/apt/sources.list (URI parse)
E: The list of sources could not be read.
I spent sometime looking but could not find the sources themselves. What is the URL for the deb sources to add to /etc/apt/sources.list?
Suddenly realised the whole confusion was being caused by this forum, which removes the http:// section
from what it recognises as being a URL in the body text
What you want on a line in your sources.list is:
deb http://linuxcnc.org/ precise base 2.7-rtai
This works even when added to a Jessie amd64 system, insofar as fetching the Packages and Release files anyway
Time to create page: 0.244 seconds
