upgrade from 2.6.5 to 2.7 will not install
05 Jun 2016 19:46 #75524 by danimal300
upgrade from 2.6.5 to 2.7 will not install was created by danimal300
I have gone through the install process several times and restarted the machine trying to get the installation to work. I followed the upgrade instructions, and everything worked well until I got to the seep 1.2.1
It says: Click the check box to mark the new linuxcnc and linuxcnc-doc-* packages for upgrade. The package manager may select a number of additional packages to be installed, to satisfy dependencies that the new linuxcnc package has.
When I click the box next to linuxcnc it tells me that I need to mark linuxcnc-dev to be upgraded, so I click mark, then the box next to linuxcnc turns red and it states:
Could not apply changes Fix broken packages first!
I tried marking all of them for removal, but that gives me some dependency error.
What do I do?
05 Jun 2016 19:49 #75525 by danimal300
Replied by danimal300 on topic upgrade from 2.6.5 to 2.7 will not install
I also tried the whole process over several times just in case I got a corrupted download, but everything worked exactly the same way. Man I just wanted to upgrade and get my spindle controller working, not spend all afternoon chasing ambiguously worded error messages.
Thanks in advance for any help that anyone can provide.
05 Jun 2016 22:50 #75531 by BigJohnT
Replied by BigJohnT on topic upgrade from 2.6.5 to 2.7 will not install
Is the OS Ubuntu 10.04?
What is the link to the instructions your following?
JT
06 Jun 2016 01:09 #75536 by danimal300
06 Jun 2016 18:10 #75570 by BigJohnT
What do I do?
Open a terminal and type:
sudo apt-get update
it should tell you what to do to fix the broken packages.
JT
08 Jun 2016 01:29 #75666 by danimal300
I ran the command you posted. I think that I have done that in previous troubleshooting.
Attached are screen-shots of the results.
08 Jun 2016 01:34 #75667 by danimal300
It will not let me remove the packages, and it will not let me change anything. it gives basically the same errors, and claims dependencies.
Here is another screen shot when I tried to manually mark each individual piece of the package.
08 Jun 2016 06:50 #75671 by cncbasher
Replied by cncbasher on topic upgrade from 2.6.5 to 2.7 will not install
you have broken packages that your trying to install , this is shown in red
so remove or deselect this package first
make sure that you have buildbot.linuxcnc.org and the approprate version you require from
listed in your repository list in synaptic package manager
( see wiki for further details )
then run sudo update && upgrade
The following user(s) said Thank You: danimal300
09 Jun 2016 13:40 #75726 by danimal300
I clicked the mark for removal, and it said that it could not be removed because Linuxcnc 2.6.5 depended on it.
How do I remove it?
09 Jun 2016 22:19 #75740 by BigJohnT
Time to create page: 0.154 seconds
