Newbie: 1st LinuxCNC install, crashes when I run it
9 years 9 months ago #85629 by andypugh
40,000 is fine, especially if you avoid watching Youtube Videos while machining.
9 years 9 months ago #85706 by ronaldinho07
hello
i have a similar issues .
everytime i try to use,it runs into crash.
here's pic
What is the problem,thank you
amd phenom ll 1090t cpu
image missing http://2.pik.vn/201756d947be-6c74-406c-a4d2-aee80bb9f94e.jpg
image missing http://2.pik.vn/20172c82d7db-9b76-4fea-bed0-c5a705dd937d.jpg
9 years 9 months ago #85712 by vasiliy
I never got to the root of the problem. Not good at dealing with Linux oopses.
I went into BIOS settings and disabled everything APM and some APIC things. That helped with crashes.
Curious, if this helps you, what your latencies would be.
9 years 8 months ago #87525 by bkt
It seems a videio/energy management, ram problem .... youtube -> crash ... use latency test and Monitor to see the latency result and cpu's usage .... or you can start axis, Monitor and than youtube .... so you can see ram and cpus usage during start of program and crash of Lcnc.
I hope these help.
Giorgio
Time to create page: 1.752 seconds
