What OS/ISO Pair with What CPU?
- Project_Hopeless
- Thank you received: 10
08 May 2019 15:45 #133156
by Project_Hopeless
What OS/ISO Pair with What CPU? was created by Project_Hopeless
I have a couple old/older PC to repurpose for LinuxCNC. I'm getting poor latency number from one PC running the Stretch ISO/image I pulled form a tread on this forum. So I wonder If I should go back to Wheezy and tune that or try a different PC, so many options!
My question is, what is the general rule of thumb for what OS version best pairs with what range of CPU/hardware.
- Thank you received: 1480
08 May 2019 15:57 #133162
Replied by Todd Zuercher on topic What OS/ISO Pair with What CPU?
How old and what are the specs of the PCs in question? Older hardware is more likely to work better with the older OS. But if the PC is really old and pathetic, it might just be time to let it go.
- Thank you received: 4151
08 May 2019 21:21 #133199
Replied by rodw on topic What OS/ISO Pair with What CPU?
the PREEMPT_RT kernel in the stretch ISO in my experience does not work well on old 32 bit hardware. Latency was so bad I bought a new machine.
- Thank you received: 5334
09 May 2019 00:01 #133209
Replied by PCW on topic What OS/ISO Pair with What CPU?
32 bit hardware is going to be at least 10 years old so that s pretty old...
(Pentium 4 vintage)
(Pentium 4 vintage)
- Thank you received: 7490
09 May 2019 01:36 #133215
Replied by tommylight on topic What OS/ISO Pair with What CPU?
core and older ( before core2 ) = RTAI
core2duo and newer = PreemptRT
for core2duo both work nearly the same.
- Project_Hopeless
09 May 2019 01:43 - 09 May 2019 01:44 #133216
by Project_Hopeless
Gateway E-4200 ( 500MHz Intel Pentium III)
Dell 530 (Intel Core 2 Duo / Pentium Dual-Core / Celeron 400 Socket 939, 2MB)
Dell 1520 Laptop (Intel Core 2 Duo Socket 939, 2MB)
HP 1st gen i7 desktop (I prefer not to use this one, already allocated for another project.)
Raspberry Pi 3
I was hoping to re-purpose one of the above.
Replied by Project_Hopeless on topic What OS/ISO Pair with What CPU?
Raspberry Pi 3
Last edit: 09 May 2019 01:44 by Project_Hopeless.
09 May 2019 02:05 #133219
That does not look right ( 2 and 3 ), but they can be used with Wheezy for sure, the 1 one will need a bit of searching to find the 8.04 or 10.04 version of Linuxcnc ( it was named EMC2 at that time ).
09 May 2019 02:07 #133220
The P3 probably isn't worth the effort.
The Dell 530 might not be a bad choice,
Use rtai (wheezy) if you want to use a parallel port interface. The stretch one may be a good choice for other hardware interfaces.
The laptop probably isn't a good option.
- Project_Hopeless
09 May 2019 15:33 #133249
by Project_Hopeless
I could use the i7 if I swap HDD. I fear if I dual boot I'll mess something up, been known to happen
The 530 is my preference over Ethernet to a 7i96e card.The Dell 530 might not be a bad choice,
- Project_Hopeless
10 May 2019 15:43 #133369
by Project_Hopeless
I'm going to give the Dell 530 Intel Core 2 Duo Socket 939, 2MB another try. I still have the Wheezy ISO I can load.
Do I automatically get RTAI or Prempt_RT loading the Wheezy ISO from the Wiki? Other than updating LinuxCNC I should leave the OS alone and don't update it?
Any pointers on what to update, what not to?
Time to create page: 0.124 seconds
