Latency Tuning Questions
  • Project_Hopeless
  • Project_Hopeless's Avatar Topic Author
  • Elite Member
  • Elite Member
15 May 2019 00:45 #133797 by Project_Hopeless
Latency Tuning Questions was created by Project_Hopeless
I'm tuning a Dell Inspirion Pentium DualCore E2180 to run a yet to be purchased 7i96e Mesa card.
I've been trying some of the tips found in this older wikki'
wiki.linuxcnc.org/cgi-bin/wiki.pl?RealTime
I'm currently trying;
isolcpus=1
intel_idle.max_cstate=0
processor.max_cstate=0
idle=poll"
GRUB_CMDLINE_LINUX_DEFAULT="isolcpus=1 intel_idle.max_cstate=0 processor.max_cstate=0 idle=poll"
The wiki says not to permanently run all these combined settings as the CPU can over heat.
Are these still valid settings for Preempt_RT and Stretch? Are there different settings for Stretch?
The changes helped somewhat. When I run latency test by itself I get the following;
Servo 2K ns
Base 7K ns
Which is much better. When I open the Browser run a utube video they jump to 90-130K which is only slightly better then without the changes. If I bang around, like writing this post they climb to 195K, 140K ns respectively.
Any thoughts?
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
15 May 2019 02:41 #133804 by Todd Zuercher
Replied by Todd Zuercher on topic Latency Tuning Questions
The little I've played with a Peempt-rt machine, this is what I found. Turn off all power management and Core2Duos states in the Bios, have at least 2gb of memory, and try isolcpus. Isolcpus made a pretty big difference on the i5 cpu machine I was messing with. I don't think the cpu hog and idle poll techniques are applicable to Preemt-RT (or were even a good idea when they were. )
15 May 2019 11:24 #133828 by pl7i92
Replied by pl7i92 on topic Latency Tuning Questions
at 7000 latency most here woudt be in heven stepper systems run perfect on < 150k
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
15 May 2019 13:19 #133835 by Todd Zuercher
Problem is he isn't seeing 7k, not even 150k he's getting almost 200k. 7k for a period of time when the machine is idle doesn't count. It needs to be consistent ALL the time regardless of machine state or usage. A large outlier at the wrong time while machining could have devastating results.
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
15 May 2019 13:23 #133836 by Todd Zuercher
PS I forgot to say, don't forget to turn off Hyperthreading in the BIOS, it is utterly useless for real time.
15 May 2019 14:58 #133845 by pl7i92
Sorry For missreading the Text
then he needs to find the reason maybe SMI is taking effect
wiki.linuxcnc.org/cgi-bin/wiki.pl?FixingSMIIssues
15 May 2019 15:15 - 15 May 2019 15:19 #133847 by PCW
Replied by PCW on topic Latency Tuning Questions
Another thing that helps noticeably with Preempt-RT is CPU speed and cache size.
If you replace the E2180 with a E8500 you get about double the performance and
3 times the cache size (for about 6 bucks on Ebay)...
Edit: Note if you intend to use a Ethernet card you should not have a base thread enabled
in your test as it will give inaccurate results.
Heres a E8500 Core Duo on a HP DC7800, with a current kernel
(3 day test doing normal browsing + GLXGears)
Last edit: 15 May 2019 15:19 by PCW.
15 May 2019 16:49 #133856 by pl7i92
PCW at your knolige it is very easy to do this
while only month into Linux and CNc it is very hard
and on a NEWby it is a nightmare
15 May 2019 17:30 #133862 by PCW
Changing a CPU should not be a big deal...
  • InMyDarkestHour
  • InMyDarkestHour's Avatar
  • Visitor
  • Visitor
15 May 2019 18:23 #133874 by InMyDarkestHour
Replied by InMyDarkestHour on topic Latency Tuning Questions
Mounting root with the noatime option can give a little reduction when opening files. I have noticed that on some systems opening a file can cause a jump in latency. Getting your hands on an SSD can help as well.
More about fstab and file mounting options.
wiki.debian.org/fstab
Time to create page: 0.748 seconds
