libxenomai-dev says no!
7 years 2 months ago #143320 by CatweazleMagic
I was installing Uspace on Lubuntu 18.03 according to Big Johns directions ( gnipsel.com/linuxcnc/uspace/lubuntu18-emc.html )
Right until the end everything went fine and flawless: really nice work. But when I told the machine
debian/configure uspace
It answerred with:
Package libxenomai-dev exists, but information about its source package is not available. This most likely means that you do not have the right deb-src lines in /etc/apt, or that you need to "apt-get update".
I updated thrice, but without any result.
Does someone have a solution for this nasty little problem.
Thnx in advance.
7 years 2 months ago #143322 by bevins
Replied by bevins on topic libxenomai-dev says no!
I would guess your missing source code repositories.
7 years 2 months ago #143331 by BigJohnT
Replied by BigJohnT on topic libxenomai-dev says no!
That would be my guess as well.
Unfortunately I lost all the Lubuntu source during an upgrade but still had the html files so I fixed the index so they could be found again.
JT
7 years 2 months ago #143332 by andypugh
Replied by andypugh on topic libxenomai-dev says no!
You should only _actually_ need libxenomai if you are compiling for a xenomai kernel.
What happens if you carry on without it?
7 years 2 months ago #143339 by CatweazleMagic
I somehow ran into the solution which did not turn up in my first search. I now can't find it anymore. But, in the software and updates preferences menu I had to check the source code. After that I got it working.
The last few lines of instructions I found on gnipsel.com/linuxcnc/uspace/linuxmint19-emc.html They are still missing on the lubuntu 18.03 page. But that's a minor.
Now it all runs :)
Thank you all so much.
Grtz, CatweazleMagic
7 years 2 months ago - 5 years 7 months ago #143341 by tommylight
Replied by tommylight on topic libxenomai-dev says no!
bevins wrote: I would guess your missing source code repositories.
Mentioned above.
Last edit: 5 years 7 months ago by tommylight. Reason: typo
Time to create page: 0.105 seconds
