libxenomai-dev says no!
- CatweazleMagic
27 Aug 2019 07:34 #143320
by CatweazleMagic
libxenomai-dev says no! was created by CatweazleMagic
I was installing Uspace on Lubuntu 18.03 according to Big Johns directions ( gnipsel.com/linuxcnc/uspace/lubuntu18-emc.html)
Right until the end everything went fine and flawless: really nice work. But when I told the machineIt answerred with:
I updated thrice, but without any result.
Does someone have a solution for this nasty little problem.
Thnx in advance.
debian/configure uspacePackage libxenomai-dev exists, but information about its source package
is not available. This most likely means that you do not have the
right deb-src lines in /etc/apt, or that you need to "apt-get update".I updated thrice, but without any result.
Thnx in advance.
- bevins
- Thank you received: 338
27 Aug 2019 07:50 #143322
by bevins
Replied by bevins on topic libxenomai-dev says no!
I would guess your missing source code repositories.
- BigJohnT
- Thank you received: 994
27 Aug 2019 11:17 #143331
by BigJohnT
Replied by BigJohnT on topic libxenomai-dev says no!
That would be my guess as well.
Unfortunately I lost all the Lubuntu source during an upgrade but still had the html files so I fixed the index so they could be found again.
JT
JT
27 Aug 2019 11:34 #143332
Replied by andypugh on topic libxenomai-dev says no!
You should only _actually_ need libxenomai if you are compiling for a xenomai kernel.
What happens if you carry on without it?
- CatweazleMagic
27 Aug 2019 12:46 #143339
by CatweazleMagic
Replied by CatweazleMagic on topic libxenomai-dev says no!
I somehow ran into the solution which did not turn up in my first search. I now can't find it anymore. But, in the software and updates preferences menu I had to check the source code. After that I got it working.
The last few lines of instructions I found on gnipsel.com/linuxcnc/uspace/linuxmint19-emc.html They are still missing on the lubuntu 18.03 page. But that's a minor.
Now it all runs
Thank you all so much.
Grtz, CatweazleMagic
Now it all runs
- Thank you received: 7504
27 Aug 2019 13:15 - 04 Mar 2021 03:32 #143341
Replied by tommylight on topic libxenomai-dev says no!
Mentioned above.I would guess your missing source code repositories.
Last edit: 04 Mar 2021 03:32 by tommylight. Reason: typo
- CatweazleMagic
27 Aug 2019 14:10 #143347
by CatweazleMagic
ah, that one was just a bit too cryptic for me.
- JetForMe
- Thank you received: 27
04 Mar 2021 00:22 #200994
by JetForMe
Replied by JetForMe on topic libxenomai-dev says no!
In my case (Ubuntu 18.04 Bionic), I had to ensure the following lines were not commented out in /etc/apt/sources.list:
deb-src us.archive.ubuntu.com/ubuntu/ bionic main restricted
deb-src us.archive.ubuntu.com/ubuntu/ bionic-updates main restricted
deb-src us.archive.ubuntu.com/ubuntu/ bionic universe
deb-src us.archive.ubuntu.com/ubuntu/ bionic-updates universe
Time to create page: 0.374 seconds
