Q: 2.8 from buildbot don't recognize PREEMPT_RT kernel
7 years 1 month ago #145738 by tommylight
You should take Todd's advice and download that image, boot it from a USB and check the latency without installing it, that way you eliminate the HDD issues if there are any.
7 years 1 month ago #146048 by LinuksGuru
HDD is WD SSD, and it is fine.
At first, I supposed it was problem with nVidia GT630 and nouveau driver.
I replaced GT630 with Radeon HD6450, as suggested here (post #418):
www.cnc-club.ru/forum/viewtopic.php?f=15&t=1078&start=400
Latency is still horrible.
I disabled onboard audio, firewire, tweaked grub kernel params - all same,
Finally, I found this thread, which describe latency spikes on Gigabyte P35-DS3 and DS4.
forums.tomshardware.com/threads/audio-la...ith-p35-ds3r.411939/
Its a buggy m/b BIOS after all.
I'll simply trash this m/b, its very old anyway, and buy something else.
Hope this info will be useful for someone.
7 years 1 month ago #146055 by tommylight
Had the same processor on an Asus P5B Deluxe, it is still working perfectly well overclocked at 3.2 i think, latency was never over 40000.
I remember i did change the BIOS as it would not work with that processor.
Did you try flashing the BIOS ?
7 years 1 month ago #146078 by LinuksGuru
Yes, I re-flashed latest available F14, no changes.
Here is another thread with similar latency issues, looks like the whole P35 family of Gigabyte m/b have been problematic.
forums.anandtech.com/threads/gigabyte-bo...-dpc-latency.171880/
Replacement m/b cost close to nothing, the most cumbersome part is a re-assembly.
7 years 1 month ago #146088 by tommylight
Oh well, been there done that........a lot of times....like a lot !
Glad you got to the bottom of it, so now it is only up from here. :)
7 years 1 month ago #146166 by LinuksGuru
Connected my SSD with same OS install to another m/b - everything fine with latency. So yes, culprit is a specific family of m/b.
Time to create page: 0.055 seconds
