Error Message - maybe, BigJohnT ?
27 Oct 2019 19:50 - 27 Oct 2019 21:28 #148922 by Irritant
Error Message - maybe, BigJohnT ? was created by Irritant
I use LinuxCNC as a tool and not so much as a hobby. I am getting an error message as attached.
I am running Mint 17.3, CNC 2.7.4 with a MESA 5i25 board to a Probotix Unity controller.
My previous computer died and changed the SSD to another computer, something happened to leave me with this problem but otherwise seems to run okay. I most likely have the files, just which ones and where?
Any help is greatly appreciated!
Last edit: 27 Oct 2019 21:28 by Irritant. Reason: not attached?
  • Moderator
  • Moderator
27 Oct 2019 20:42 #148927 by tommylight
Replied by tommylight on topic Error Message - maybe, BigJohnT ?
Attachment ???
27 Oct 2019 21:28 #148931 by Irritant
Replied by Irritant on topic Error Message - maybe, BigJohnT ?
I thought I had but i have now for sure!
  • Moderator
  • Moderator
27 Oct 2019 22:26 #148936 by tommylight
Nope ! :)
28 Oct 2019 15:16 #148981 by Irritant
Replied by Irritant on topic Message
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.4
Machine configuration directory is '/home/emc/linuxcnc/configs/mesa-prob-unitywithstop'
Machine configuration file is 'mesa-prob-unity.ini'
INIFILE=/home/emc/linuxcnc/configs/mesa-prob-unitywithstop/mesa-prob-unity.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./mesa-prob-unity.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: axis
Killing task linuxcncsvr, PID=2913
Killing task milltask, PID=2966
task: 117 cycles, min=0.000019, max=0.022822, avg=0.008704, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Debug file information:
./mesa-prob-unity.hal:1: Warning: File contains DOS-style line endings.
intel_do_flush_locked failed: Input/output error
2913
PID TTY STAT TIME COMMAND
2966
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e8000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000005f7b1d00 (usable)
[ 0.000000] BIOS-e820: 000000005f7b1d00 - 000000005f7b3d00 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000005f7b3d00 - 0000000060000000 (reserved)
[ 0.000000] BIOS-e820: 00000000f4000000 - 00000000f8000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fed40000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed45000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.4 present.
[ 0.000000] DMI: Hewlett-Packard HP Compaq dc5700 Microtower/0A60h, BIOS 786E2 v02.04 04/13/2007
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x5f7b1 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-E3FFF write-protect
[ 0.000000] E4000-EFFFF write-back
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 base 040000000 mask FE0000000 write-back
[ 0.000000] 2 base 05F800000 mask FFF800000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00f9bf0] f9bf0
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 35722000 - 36b89000
[ 0.000000] ACPI: RSDP 000e7610 00014 (v00 COMPAQ)
[ 0.000000] ACPI: RSDT 5f7c3d40 00040 (v01 HPQOEM SLIC-BPC 20070413 00000000)
[ 0.000000] ACPI: FACP 5f7c3de8 00074 (v01 COMPAQ BROADH2O 00000001 00000000)
[ 0.000000] ACPI: DSDT 5f7c4143 0970D (v01 COMPAQ DSDT_PRJ 00000001 MSFT 0100000E)
[ 0.000000] ACPI: FACS 5f7c3d00 00040
[ 0.000000] ACPI: APIC 5f7c3e5c 00068 (v01 COMPAQ BROADH2O 00000001 00000000)
[ 0.000000] ACPI: ASF! 5f7c3ec4 00063 (v32 COMPAQ BROADH2O 00000001 00000000)
[ 0.000000] ACPI: MCFG 5f7c3f27 0003C (v01 COMPAQ BROADH2O 00000001 00000000)
[ 0.000000] ACPI: TCPA 5f7c3f63 00032 (v01 COMPAQ BROADH2O 00000001 00000000)
[ 0.000000] ACPI: SLIC 5f7c3f95 00176 (v01 HPQOEM SLIC-BPC 00000001 00000000)
[ 0.000000] ACPI: HPET 5f7c410b 00038 (v01 COMPAQ BROADH2O 00000001 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 639MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0005f7b1
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0005f7b1
[ 0.000000] On node 0 totalpages: 390976
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f6c0d200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 1280 pages used for memmap
[ 0.000000] HighMem zone: 162483 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0xf808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e8000
[ 0.000000] PM: Registered nosave memory: 00000000000e8000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 60000000 (gap: 60000000:94000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f6be2000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 387920
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=9dd9218b-408e-4a02-8118-525491b67c4f ro quiet splash vt.handoff=7
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 3128584 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0005f7b1)
[ 0.000000] Memory: 1520896k/1564356k available (3496k kernel code, 43008k reserved, 1237k data, 416k init, 655052k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc136a04a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc136a04a (3496 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:512 16
[ 0.000000] CPU 0 irqstacks, hard=f4c08000 soft=f4c0a000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 3391.275 MHz processor.
[ 0.004002] Calibrating delay loop (skipped), value calculated using timer frequency.. 6782.55 BogoMIPS (lpj=13565100)
[ 0.004009] pid_max: default: 32768 minimum: 301
[ 0.004077] Security Framework initialized
[ 0.004084] AppArmor: AppArmor disabled by boot time parameter
[ 0.004111] Mount-cache hash table entries: 512
[ 0.004375] Initializing cgroup subsys cpuacct
[ 0.004379] Initializing cgroup subsys memory
[ 0.004392] Initializing cgroup subsys devices
[ 0.004396] Initializing cgroup subsys freezer
[ 0.004399] Initializing cgroup subsys net_cls
[ 0.004402] Initializing cgroup subsys blkio
[ 0.004413] Initializing cgroup subsys perf_event
[ 0.004460] CPU: Physical Processor ID: 0
[ 0.004463] CPU: Processor Core ID: 0
[ 0.004467] mce: CPU supports 4 MCE banks
[ 0.004479] CPU0: Thermal monitoring enabled (TM1)
[ 0.004553] ACPI: Core revision 20120320
[ 0.012066] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.012411] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.054763] CPU0: Intel(R) Pentium(R) D CPU 3.40GHz stepping 05
[ 0.056003] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.056003] ... version: 0
[ 0.056003] ... bit width: 40
[ 0.056003] ... generic registers: 18
[ 0.056003] ... value mask: 000000ffffffffff
[ 0.056003] ... max period: 0000007fffffffff
[ 0.056003] ... fixed-purpose events: 0
[ 0.056003] ... event mask: 000000000003ffff
[ 0.064037] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.076043] CPU 1 irqstacks, hard=f4c9a000 soft=f4c9c000
[ 0.076049] Booting Node 0, Processors #1 Ok.
[ 0.008000] Initializing CPU#1
[ 0.088034] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.088089] Brought up 2 CPUs
[ 0.088094] Total of 2 processors activated (13565.10 BogoMIPS).
[ 0.089577] devtmpfs: initialized
[ 0.089577] PM: Registering ACPI NVS region [mem 0x5f7b1d00-0x5f7b3cff] (8192 bytes)
[ 0.089577] HP Compaq Laptop series board detected. Selecting BIOS-method for reboots.
[ 0.089577] dummy:
[ 0.089577] NET: Registered protocol family 16
[ 0.089577] ACPI: bus type pci registered
[ 0.089577] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf4000000-0xf7ffffff] (base 0xf4000000)
[ 0.089577] PCI: MMCONFIG at [mem 0xf4000000-0xf7ffffff] reserved in E820
[ 0.089577] PCI: Using MMCONFIG for extended config space
[ 0.089577] PCI: Using configuration type 1 for base access
[ 0.092051] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.092055] mtrr: probably your BIOS does not setup all CPUs.
[ 0.092057] mtrr: corrected configuration.
[ 0.092792] bio: create slab <bio-0> at 0
[ 0.092792] ACPI: Added _OSI(Module Device)
[ 0.092792] ACPI: Added _OSI(Processor Device)
[ 0.092792] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.092792] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.094520] ACPI: EC: Look up EC in DSDT
[ 0.101243] ACPI: SSDT 5f7ce602 00320 (v01 COMPAQ CPU_TM2 00000001 MSFT 0100000E)
[ 0.101243] ACPI: Dynamic OEM Table Load:
[ 0.101243] ACPI: SSDT (null) 00320 (v01 COMPAQ CPU_TM2 00000001 MSFT 0100000E)
[ 0.108392] ACPI: Interpreter enabled
[ 0.108409] ACPI: (supports S0 S3 S4 S5)
[ 0.108449] ACPI: Using IOAPIC for interrupt routing
[ 0.116997] ACPI: No dock devices found.
[ 0.117008] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.120436] ACPI Error: [CAPD] Namespace lookup failure, AE_ALREADY_EXISTS (20120320/dsfield-143)
[ 0.120451] ACPI Error: Method parse/execution failed [\_SB_.PCI0._OSC] (Node f4c44a58), AE_ALREADY_EXISTS (20120320/psparse-536)
[ 0.120466] ACPI: Marking method _OSC as Serialized because of AE_ALREADY_EXISTS error
[ 0.120478] ACPI Warning: For \_SB_.PCI0._OSC: Parameter count mismatch - ASL declared 5, ACPI requires 4 (20120320/nspredef-359)
[ 0.120489] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.121074] pci_root PNP0A08:00: host bridge window [mem 0xf8000000-0xfebfffff] (ignored)
[ 0.121080] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.121084] pci_root PNP0A08:00: host bridge window [io 0x1000-0x2fff] (ignored)
[ 0.121088] pci_root PNP0A08:00: host bridge window [io 0x3000-0x6fff] (ignored)
[ 0.121092] pci_root PNP0A08:00: host bridge window [io 0x7000-0xafff] (ignored)
[ 0.121096] pci_root PNP0A08:00: host bridge window [io 0xb000-0xffff] (ignored)
[ 0.121100] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.121105] pci_root PNP0A08:00: host bridge window [mem 0x60000000-0xf3ffffff] (ignored)
[ 0.121109] PCI: root bus 00: using default resources
[ 0.121173] PCI host bridge to bus 0000:00
[ 0.121178] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.121182] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.121198] pci 0000:00:00.0: [8086:2990] type 00 class 0x060000
[ 0.121261] pci 0000:00:02.0: [8086:2992] type 00 class 0x030000
[ 0.121279] pci 0000:00:02.0: reg 10: [mem 0xf0400000-0xf04fffff]
[ 0.121299] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.121308] pci 0000:00:02.0: reg 20: [io 0x1200-0x1207]
[ 0.121382] pci 0000:00:1a.0: [8086:2834] type 00 class 0x0c0300
[ 0.121435] pci 0000:00:1a.0: reg 20: [io 0x1100-0x111f]
[ 0.121476] pci 0000:00:1a.1: [8086:2835] type 00 class 0x0c0300
[ 0.121528] pci 0000:00:1a.1: reg 20: [io 0x1120-0x113f]
[ 0.121580] pci 0000:00:1a.7: [8086:283a] type 00 class 0x0c0320
[ 0.121605] pci 0000:00:1a.7: reg 10: [mem 0xf0504000-0xf05043ff]
[ 0.121692] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.121726] pci 0000:00:1b.0: [8086:284b] type 00 class 0x040300
[ 0.121748] pci 0000:00:1b.0: reg 10: [mem 0xf0500000-0xf0503fff 64bit]
[ 0.121820] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.121850] pci 0000:00:1c.0: [8086:283f] type 01 class 0x060400
[ 0.121923] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.121957] pci 0000:00:1c.1: [8086:2841] type 01 class 0x060400
[ 0.122032] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.122068] pci 0000:00:1d.0: [8086:2830] type 00 class 0x0c0300
[ 0.122119] pci 0000:00:1d.0: reg 20: [io 0x1140-0x115f]
[ 0.122160] pci 0000:00:1d.1: [8086:2831] type 00 class 0x0c0300
[ 0.122211] pci 0000:00:1d.1: reg 20: [io 0x1160-0x117f]
[ 0.122263] pci 0000:00:1d.7: [8086:2836] type 00 class 0x0c0320
[ 0.122288] pci 0000:00:1d.7: reg 10: [mem 0xf0504400-0xf05047ff]
[ 0.122375] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.122403] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.122476] pci 0000:00:1f.0: [8086:2810] type 00 class 0x060100
[ 0.122572] pci 0000:00:1f.0: quirk: [io 0xf800-0xf87f] claimed by ICH6 ACPI/GPIO/TCO
[ 0.122579] pci 0000:00:1f.0: quirk: [io 0xfa00-0xfa3f] claimed by ICH6 GPIO
[ 0.122585] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0400 (mask 007f)
[ 0.122590] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 0480 (mask 000f)
[ 0.122595] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 3 PIO at 0cb0 (mask 000f)
[ 0.122642] pci 0000:00:1f.2: [8086:2820] type 00 class 0x01018a
[ 0.122662] pci 0000:00:1f.2: reg 10: [io 0x1208-0x120f]
[ 0.122674] pci 0000:00:1f.2: reg 14: [io 0x1228-0x122b]
[ 0.122685] pci 0000:00:1f.2: reg 18: [io 0x1210-0x1217]
[ 0.122697] pci 0000:00:1f.2: reg 1c: [io 0x122c-0x122f]
[ 0.122708] pci 0000:00:1f.2: reg 20: [io 0x11c0-0x11cf]
[ 0.122719] pci 0000:00:1f.2: reg 24: [io 0x11d0-0x11df]
[ 0.122750] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.122774] pci 0000:00:1f.5: [8086:2825] type 00 class 0x010185
[ 0.122794] pci 0000:00:1f.5: reg 10: [io 0x1218-0x121f]
[ 0.122805] pci 0000:00:1f.5: reg 14: [io 0x1230-0x1233]
[ 0.122817] pci 0000:00:1f.5: reg 18: [io 0x1220-0x1227]
[ 0.122828] pci 0000:00:1f.5: reg 1c: [io 0x1234-0x1237]
[ 0.122839] pci 0000:00:1f.5: reg 20: [io 0x11e0-0x11ef]
[ 0.122851] pci 0000:00:1f.5: reg 24: [io 0x11f0-0x11ff]
[ 0.122881] pci 0000:00:1f.5: PME# supported from D3hot
[ 0.122943] pci 0000:00:1c.0: PCI bridge to [bus 20-20]
[ 0.123037] pci 0000:3f:00.0: [14e4:167b] type 00 class 0x020000
[ 0.123067] pci 0000:3f:00.0: reg 10: [mem 0xf0800000-0xf080ffff 64bit]
[ 0.123185] pci 0000:3f:00.0: PME# supported from D3hot D3cold
[ 0.128035] pci 0000:00:1c.1: PCI bridge to [bus 3f-3f]
[ 0.128048] pci 0000:00:1c.1: bridge window [mem 0xf0600000-0xf08fffff]
[ 0.128110] pci 0000:07:04.0: [2718:5125] type 00 class 0x110000
[ 0.128129] pci 0000:07:04.0: reg 10: [mem 0xf0900000-0xf090ffff]
[ 0.128241] pci 0000:00:1e.0: PCI bridge to [bus 07-07] (subtractive decode)
[ 0.128250] pci 0000:00:1e.0: bridge window [mem 0xf0900000-0xf0bfffff]
[ 0.128259] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.128263] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.128283] pci_bus 0000:00: on NUMA node 0
[ 0.128290] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.128777] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCX1._PRT]
[ 0.128920] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCX2._PRT]
[ 0.129063] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB_._PRT]
[ 0.129637] ACPI Error: [CAPD] Namespace lookup failure, AE_ALREADY_EXISTS (20120320/dsfield-143)
[ 0.129651] ACPI Error: Method parse/execution failed [\_SB_.PCI0._OSC] (Node f4c44a58), AE_ALREADY_EXISTS (20120320/psparse-536)
[ 0.129671] ACPI Warning: For \_SB_.PCI0._OSC: Parameter count mismatch - ASL declared 5, ACPI requires 4 (20120320/nspredef-359)
[ 0.129682] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.151972] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 14 15)
[ 0.152114] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 14 15)
[ 0.152230] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 14 15)
[ 0.152346] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 14 15) *0, disabled.
[ 0.152465] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 *10 11 14 15)
[ 0.152582] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 *5 6 7 10 11 14 15)
[ 0.152698] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 *10 11 14 15)
[ 0.152817] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 14 15) *0, disabled.
[ 0.152924] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.152924] vgaarb: loaded
[ 0.152924] vgaarb: bridge control possible 0000:00:02.0
[ 0.152924] PCI: Using ACPI for IRQ routing
[ 0.153899] PCI: pci_cache_line_size set to 64 bytes
[ 0.153996] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.154001] reserve RAM buffer: 000000005f7b1d00 - 000000005fffffff
[ 0.154189] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.154200] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.157034] Switching to clocksource hpet
[ 0.157134] pnp: PnP ACPI init
[ 0.157156] ACPI: bus type pnp registered
[ 0.157480] pnp 00:00: [mem 0xf8000000-0xfebfffff window]
[ 0.157485] pnp 00:00: [bus 00-ff]
[ 0.157489] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.157494] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.157497] pnp 00:00: [io 0x1000-0x2fff window]
[ 0.157501] pnp 00:00: [io 0x3000-0x6fff window]
[ 0.157505] pnp 00:00: [io 0x7000-0xafff window]
[ 0.157509] pnp 00:00: [io 0xb000-0xffff window]
[ 0.157513] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.157517] pnp 00:00: [mem 0x60000000-0xf3ffffff window]
[ 0.157585] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.157612] pnp 00:01: [io 0x00f0-0x00ff]
[ 0.157625] pnp 00:01: [irq 13]
[ 0.157664] pnp 00:01: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.157695] pnp 00:02: [io 0x0000-0x000f]
[ 0.157699] pnp 00:02: [io 0x0080-0x008f]
[ 0.157703] pnp 00:02: [io 0x00c0-0x00df]
[ 0.157707] pnp 00:02: [dma 4]
[ 0.157746] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.157770] pnp 00:03: [io 0x0070-0x0071]
[ 0.157779] pnp 00:03: [irq 8]
[ 0.157821] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.157842] pnp 00:04: [io 0x0061]
[ 0.157884] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.157909] pnp 00:05: [irq 12]
[ 0.157953] pnp 00:05: Plug and Play ACPI device, IDs PNP0f13 PNP0f0e (active)
[ 0.157975] pnp 00:06: [io 0x0060]
[ 0.157980] pnp 00:06: [io 0x0064]
[ 0.157987] pnp 00:06: [irq 1]
[ 0.158031] pnp 00:06: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.158525] pnp 00:07: [irq 7]
[ 0.158530] pnp 00:07: [dma 3]
[ 0.158534] pnp 00:07: [io 0x0378-0x037f]
[ 0.158537] pnp 00:07: [io 0x0778-0x077d]
[ 0.158647] pnp 00:07: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.159030] pnp 00:08: [irq 4]
[ 0.159035] pnp 00:08: [io 0x03f8-0x03ff]
[ 0.159141] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 PNP0500 (active)
[ 0.159478] pnp 00:09: [irq 6]
[ 0.159482] pnp 00:09: [dma 2]
[ 0.159486] pnp 00:09: [io 0x03f0-0x03f5]
[ 0.159490] pnp 00:09: [io 0x03f7]
[ 0.159551] pnp 00:09: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.159687] pnp 00:0a: [mem 0xfec00000-0xfec00fff]
[ 0.159736] pnp 00:0a: Plug and Play ACPI device, IDs PNP0003 (active)
[ 0.159819] pnp 00:0b: [mem 0xfed00000-0xfed003ff]
[ 0.159819] pnp 00:0b: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.159819] pnp 00:0c: [io 0x0010-0x001f]
[ 0.159819] pnp 00:0c: [io 0x0050-0x0053]
[ 0.159819] pnp 00:0c: [io 0x0072-0x0077]
[ 0.159819] pnp 00:0c: [io 0x0090-0x009f]
[ 0.159819] pnp 00:0c: [io 0x04d0-0x04d1]
[ 0.159819] system 00:0c: [io 0x04d0-0x04d1] has been reserved
[ 0.159819] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.159819] pnp 00:0d: [io 0x004e-0x004f]
[ 0.159819] pnp 00:0d: [io 0x0400-0x041f]
[ 0.159819] pnp 00:0d: [io 0x0420-0x043f]
[ 0.159819] pnp 00:0d: [io 0x0440-0x045f]
[ 0.159819] pnp 00:0d: [io 0x0460-0x047f]
[ 0.159819] pnp 00:0d: [io 0x0480-0x048f]
[ 0.159819] pnp 00:0d: [io 0x0cb0-0x0cbf]
[ 0.159819] pnp 00:0d: [io 0xf800-0xf81f]
[ 0.159819] pnp 00:0d: [io 0xf820-0xf83f]
[ 0.159819] pnp 00:0d: [io 0xf840-0xf85f]
[ 0.159819] pnp 00:0d: [io 0xf860-0xf87f]
[ 0.159819] pnp 00:0d: [io 0xfa00-0xfa3f]
[ 0.159819] pnp 00:0d: [io 0xfc00-0xfc7f]
[ 0.159819] pnp 00:0d: [io 0xfc80-0xfcff]
[ 0.159819] pnp 00:0d: [io 0xfe00-0xfe7f]
[ 0.159819] pnp 00:0d: [io 0xfe80-0xfeff]
[ 0.159819] pnp 00:0d: disabling [io 0xf800-0xf81f] because it overlaps 0000:00:1f.0 BAR 13 [io 0xf800-0xf87f]
[ 0.159819] pnp 00:0d: disabling [io 0xf820-0xf83f] because it overlaps 0000:00:1f.0 BAR 13 [io 0xf800-0xf87f]
[ 0.159819] pnp 00:0d: disabling [io 0xf840-0xf85f] because it overlaps 0000:00:1f.0 BAR 13 [io 0xf800-0xf87f]
[ 0.159819] pnp 00:0d: disabling [io 0xf860-0xf87f] because it overlaps 0000:00:1f.0 BAR 13 [io 0xf800-0xf87f]
[ 0.159819] system 00:0d: [io 0x0400-0x041f] has been reserved
[ 0.159819] system 00:0d: [io 0x0420-0x043f] has been reserved
[ 0.159819] system 00:0d: [io 0x0440-0x045f] has been reserved
[ 0.159819] system 00:0d: [io 0x0460-0x047f] has been reserved
[ 0.159819] system 00:0d: [io 0x0480-0x048f] has been reserved
[ 0.159819] system 00:0d: [io 0x0cb0-0x0cbf] has been reserved
[ 0.159819] system 00:0d: [io 0xfa00-0xfa3f] has been reserved
[ 0.159819] system 00:0d: [io 0xfc00-0xfc7f] has been reserved
[ 0.159819] system 00:0d: [io 0xfc80-0xfcff] has been reserved
[ 0.159819] system 00:0d: [io 0xfe00-0xfe7f] has been reserved
[ 0.159819] system 00:0d: [io 0xfe80-0xfeff] has been reserved
[ 0.159819] system 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.160365] pnp 00:0e: [mem 0x00000000-0x0009ffff]
[ 0.160370] pnp 00:0e: [mem 0x00100000-0x5fffffff]
[ 0.160374] pnp 00:0e: [mem 0x000e4000-0x000fffff]
[ 0.160378] pnp 00:0e: [mem 0xfec01000-0xfecfffff]
[ 0.160382] pnp 00:0e: [mem 0xfed00400-0xfed3ffff]
[ 0.160386] pnp 00:0e: [mem 0xfed40000-0xffffffff]
[ 0.160389] pnp 00:0e: [mem 0xf4000000-0xf7ffffff]
[ 0.160393] pnp 00:0e: [mem 0x000cdc00-0x000e3fff]
[ 0.160494] system 00:0e: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.160500] system 00:0e: [mem 0x00100000-0x5fffffff] could not be reserved
[ 0.160505] system 00:0e: [mem 0x000e4000-0x000fffff] could not be reserved
[ 0.160510] system 00:0e: [mem 0xfec01000-0xfecfffff] has been reserved
[ 0.160514] system 00:0e: [mem 0xfed00400-0xfed3ffff] has been reserved
[ 0.160519] system 00:0e: [mem 0xfed40000-0xffffffff] could not be reserved
[ 0.160524] system 00:0e: [mem 0xf4000000-0xf7ffffff] has been reserved
[ 0.160528] system 00:0e: [mem 0x000cdc00-0x000e3fff] has been reserved
[ 0.160533] system 00:0e: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.160556] pnp: PnP ACPI: found 15 devices
[ 0.160559] ACPI: ACPI bus type pnp unregistered
[ 0.160564] PnPBIOS: Disabled by ACPI PNP
[ 0.200881] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 20-20] add_size 1000
[ 0.200890] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 20-20] add_size 200000
[ 0.200896] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 20-20] add_size 200000
[ 0.200908] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 3f-3f] add_size 1000
[ 0.200914] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 3f-3f] add_size 200000
[ 0.200934] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 0.200938] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.200943] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.200947] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.200951] pci 0000:00:1c.1: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.200957] pci 0000:00:1c.0: BAR 14: assigned [mem 0x60000000-0x601fffff]
[ 0.200962] pci 0000:00:1c.0: BAR 15: assigned [mem 0x60200000-0x603fffff 64bit pref]
[ 0.200967] pci 0000:00:1c.1: BAR 15: assigned [mem 0x60400000-0x605fffff 64bit pref]
[ 0.200972] pci 0000:00:1c.0: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.200977] pci 0000:00:1c.1: BAR 13: assigned [io 0x3000-0x3fff]
[ 0.200985] pci 0000:00:1c.0: PCI bridge to [bus 20-20]
[ 0.200990] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
[ 0.200997] pci 0000:00:1c.0: bridge window [mem 0x60000000-0x601fffff]
[ 0.201003] pci 0000:00:1c.0: bridge window [mem 0x60200000-0x603fffff 64bit pref]
[ 0.201012] pci 0000:00:1c.1: PCI bridge to [bus 3f-3f]
[ 0.201017] pci 0000:00:1c.1: bridge window [io 0x3000-0x3fff]
[ 0.201024] pci 0000:00:1c.1: bridge window [mem 0xf0600000-0xf08fffff]
[ 0.201030] pci 0000:00:1c.1: bridge window [mem 0x60400000-0x605fffff 64bit pref]
[ 0.201038] pci 0000:00:1e.0: PCI bridge to [bus 07-07]
[ 0.201045] pci 0000:00:1e.0: bridge window [mem 0xf0900000-0xf0bfffff]
[ 0.201086] pci 0000:00:1e.0: setting latency timer to 64
[ 0.201092] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.201096] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.201100] pci_bus 0000:20: resource 0 [io 0x2000-0x2fff]
[ 0.201104] pci_bus 0000:20: resource 1 [mem 0x60000000-0x601fffff]
[ 0.201108] pci_bus 0000:20: resource 2 [mem 0x60200000-0x603fffff 64bit pref]
[ 0.201112] pci_bus 0000:3f: resource 0 [io 0x3000-0x3fff]
[ 0.201115] pci_bus 0000:3f: resource 1 [mem 0xf0600000-0xf08fffff]
[ 0.201119] pci_bus 0000:3f: resource 2 [mem 0x60400000-0x605fffff 64bit pref]
[ 0.201123] pci_bus 0000:07: resource 1 [mem 0xf0900000-0xf0bfffff]
[ 0.201127] pci_bus 0000:07: resource 4 [io 0x0000-0xffff]
[ 0.201130] pci_bus 0000:07: resource 5 [mem 0x00000000-0xffffffff]
[ 0.201251] NET: Registered protocol family 2
[ 0.201336] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.201614] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.202125] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.202381] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.202384] TCP: reno registered
[ 0.202388] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.202398] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.202520] NET: Registered protocol family 1
[ 0.202545] pci 0000:00:02.0: Boot video device
[ 0.202758] PCI: CLS 64 bytes, default 64
[ 0.202837] Unpacking initramfs...
[ 0.766017] Freeing initrd memory: 20892k freed
[ 0.778971] audit: initializing netlink socket (disabled)
[ 0.778992] type=2000 audit(943920195.772:1): initialized
[ 0.792697] highmem bounce pool size: 64 pages
[ 0.792706] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.793030] VFS: Disk quotas dquot_6.5.2
[ 0.793075] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.793187] msgmni has been set to 1731
[ 0.793522] alg: No test for stdrng (krng)
[ 0.793580] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.793586] io scheduler noop registered
[ 0.793589] io scheduler deadline registered
[ 0.793627] io scheduler cfq registered (default)
[ 0.793905] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.793937] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.793941] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.794528] vesafb: mode is 1024x768x32, linelength=4096, pages=0
[ 0.794532] vesafb: scrolling: redraw
[ 0.794536] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.795073] vesafb: framebuffer at 0xe0000000, mapped to 0xf8080000, using 3072k, total 3072k
[ 0.795169] fbcon: VESA VGA (fb0) is primary device
[ 0.827399] Console: switching to colour frame buffer device 128x48
[ 0.859569] fb0: VESA VGA frame buffer device
[ 0.859630] GHES: HEST is not enabled!
[ 0.859653] isapnp: Scanning for PnP cards...
[ 1.169531] isapnp: No Plug & Play device found
[ 1.169627] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.190031] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.210986] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.211406] Linux agpgart interface v0.103
[ 1.211561] agpgart-intel 0000:00:00.0: Intel 965Q Chipset
[ 1.211669] agpgart-intel 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
[ 1.212513] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 1.212695] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[ 1.212897] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f0e:PS2M] at 0x60,0x64 irq 1,12
[ 1.215384] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.215433] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.215640] mousedev: PS/2 mouse device common for all mice
[ 1.215707] rtc_cmos 00:03: RTC can wake from S4
[ 1.215893] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 1.215924] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.216106] TCP: cubic registered
[ 1.216206] NET: Registered protocol family 10
[ 1.216510] Mobile IPv6
[ 1.216515] NET: Registered protocol family 17
[ 1.216522] Registering the dns_resolver key type
[ 1.216588] Using IPI No-Shortcut mode
[ 1.216833] PM: Hibernation image not present or could not be loaded.
[ 1.216857] registered taskstats version 1
[ 1.217374] rtc_cmos 00:03: hctosys: invalid date/time
[ 1.217850] Freeing unused kernel memory: 416k freed
[ 1.218127] Write protecting the kernel text: 3500k
[ 1.218159] Write protecting the kernel read-only data: 980k
[ 1.243721] systemd-udevd[57]: starting version 204
[ 1.264178] usbcore: registered new interface driver usbfs
[ 1.264217] usbcore: registered new interface driver hub
[ 1.264280] usbcore: registered new device driver usb
[ 1.264660] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.264730] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.264738] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 1.264771] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.264825] uhci_hcd 0000:00:1a.0: irq 20, io base 0x00001100
[ 1.264887] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.264892] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.264896] usb usb1: Product: UHCI Host Controller
[ 1.264901] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.264904] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.265084] hub 1-0:1.0: USB hub found
[ 1.265096] hub 1-0:1.0: 2 ports detected
[ 1.265244] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 1.265251] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 1.265265] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 2
[ 1.265309] uhci_hcd 0000:00:1a.1: irq 21, io base 0x00001120
[ 1.265365] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.265371] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.265376] usb usb2: Product: UHCI Host Controller
[ 1.265380] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.265384] usb usb2: SerialNumber: 0000:00:1a.1
[ 1.265541] hub 2-0:1.0: USB hub found
[ 1.265550] hub 2-0:1.0: 2 ports detected
[ 1.265700] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.265706] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.265721] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 3
[ 1.265751] uhci_hcd 0000:00:1d.0: irq 20, io base 0x00001140
[ 1.265812] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.265816] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.265819] usb usb3: Product: UHCI Host Controller
[ 1.265823] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.265826] usb usb3: SerialNumber: 0000:00:1d.0
[ 1.265975] hub 3-0:1.0: USB hub found
[ 1.265985] hub 3-0:1.0: 2 ports detected
[ 1.266122] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.266129] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.266142] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 4
[ 1.266173] uhci_hcd 0000:00:1d.1: irq 21, io base 0x00001160
[ 1.266229] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.266234] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.266238] usb usb4: Product: UHCI Host Controller
[ 1.266242] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.266246] usb usb4: SerialNumber: 0000:00:1d.1
[ 1.266395] hub 4-0:1.0: USB hub found
[ 1.266405] hub 4-0:1.0: 2 ports detected
[ 1.269519] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.269526] Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[ 1.269608] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 1.269616] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 1.269635] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 5
[ 1.269670] ehci_hcd 0000:00:1a.7: debug port 1
[ 1.273028] [drm] Initialized drm 1.1.0 20060810
[ 1.273971] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 1.273983] ACPI: Power Button [PBTN]
[ 1.274079] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 1.274087] ACPI: Power Button [PWRF]
[ 1.276263] ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
[ 1.276310] ehci_hcd 0000:00:1a.7: irq 22, io mem 0xf0504000
[ 1.277983] wmi: Mapper loaded
[ 1.280082] tg3.c:v3.123 (March 21, 2012)
[ 1.288613] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 1.288680] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.288686] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.288690] usb usb5: Product: EHCI Host Controller
[ 1.288694] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.288698] usb usb5: SerialNumber: 0000:00:1a.7
[ 1.288998] hub 5-0:1.0: USB hub found
[ 1.289009] hub 5-0:1.0: 4 ports detected
[ 1.289321] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.289327] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.289342] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 6
[ 1.289378] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.292419] SCSI subsystem initialized
[ 1.296049] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.296074] ehci_hcd 0000:00:1d.7: irq 20, io mem 0xf0504400
[ 1.296084] libata version 3.00 loaded.
[ 1.297331] tg3 0000:3f:00.0: eth0: Tigon3 [partno(BCM95755) rev a002] (PCI Express) MAC address 00:1b:78:3f:ae:fd
[ 1.297338] tg3 0000:3f:00.0: eth0: attached PHY is 5755 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[ 1.297344] tg3 0000:3f:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 1.297349] tg3 0000:3f:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 1.302598] FDC 0 is a post-1991 82077
[ 1.308130] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.308191] usb usb6: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.308196] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.308201] usb usb6: Product: EHCI Host Controller
[ 1.308204] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.308207] usb usb6: SerialNumber: 0000:00:1d.7
[ 1.308412] hub 6-0:1.0: USB hub found
[ 1.308421] hub 6-0:1.0: 4 ports detected
[ 1.309040] i915 0000:00:02.0: setting latency timer to 64
[ 1.335503] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 1.335511] [drm] Driver supports precise vblank timestamp query.
[ 1.335569] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 1.380879] [drm] initialized overlay support
[ 1.423883] checking generic (e0000000 300000) vs hw (e0000000 10000000)
[ 1.423889] fb: conflicting fb hw usage inteldrmfb vs VESA VGA - removing generic driver
[ 1.423909] Console: switching to colour dummy device 80x25
[ 1.424521] fbcon: inteldrmfb (fb0) is primary device
[ 1.464553] Console: switching to colour frame buffer device 170x48
[ 1.468513] fb0: inteldrmfb frame buffer device
[ 1.468516] drm: registered panic notifier
[ 1.468613] ACPI Exception: AE_NOT_FOUND, Evaluating _DOD (20120320/video-1179)
[ 1.468693] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input2
[ 1.468704] ACPI: Video Device [GFX0] (multi-head: no rom: yes post: no)
[ 1.468740] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 1.468789] ata_piix 0000:00:1f.2: version 2.13
[ 1.468855] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.624061] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.624598] scsi0 : ata_piix
[ 1.624792] scsi1 : ata_piix
[ 1.625032] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0x11c0 irq 14
[ 1.625040] ata2: SATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0x11c8 irq 15
[ 1.625112] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 1.776032] Refined TSC clocksource calibration: 3391.500 MHz.
[ 1.776044] Switching to clocksource tsc
[ 1.780044] ata_piix 0000:00:1f.5: setting latency timer to 64
[ 1.780466] scsi2 : ata_piix
[ 1.780588] scsi3 : ata_piix
[ 1.780780] ata3: SATA max UDMA/133 cmd 0x1218 ctl 0x1230 bmdma 0x11e0 irq 18
[ 1.780786] ata4: SATA max UDMA/133 cmd 0x1220 ctl 0x1234 bmdma 0x11e8 irq 18
[ 1.880030] usb 1-2: new low-speed USB device number 2 using uhci_hcd
[ 2.057892] usb 1-2: New USB device found, idVendor=046d, idProduct=c326
[ 2.057899] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.057905] usb 1-2: Product: USB Keyboard
[ 2.057909] usb 1-2: Manufacturer: Logitech
[ 2.086534] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-2/1-2:1.0/input/input3
[ 2.086626] generic-usb 0003:046D:C326.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-0000:00:1a.0-2/input0
[ 2.110926] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.123036] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-2/1-2:1.1/input/input4
[ 2.123306] generic-usb 0003:046D:C326.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-0000:00:1a.0-2/input1
[ 2.123335] usbcore: registered new interface driver usbhid
[ 2.123339] usbhid: USB HID core driver
[ 2.256058] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.275041] ata3.00: ATAPI: HL-DT-STDVD-ROM GDRH10N, D70D, max UDMA/100
[ 2.275168] ata1.00: SATA link down (SStatus 0 SControl 300)
[ 2.275182] ata1.01: SATA link down (SStatus 4 SControl 300)
[ 2.288178] ata3.00: configured for UDMA/100
[ 2.316032] usb 4-2: new low-speed USB device number 2 using uhci_hcd
[ 2.420080] ata2.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.420098] ata2.01: SATA link down (SStatus 4 SControl 300)
[ 2.420375] ata2.00: ATA-9: SPCC Solid State Disk, SAFM12.2, max UDMA/133
[ 2.420383] ata2.00: 234441648 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.420733] ata2.00: configured for UDMA/133
[ 2.420883] scsi 1:0:0:0: Direct-Access ATA SPCC Solid State SAFM PQ: 0 ANSI: 5
[ 2.424708] scsi 2:0:0:0: CD-ROM HL-DT-ST DVD-ROM GDRH10N D70D PQ: 0 ANSI: 5
[ 2.430735] sd 1:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB)
[ 2.430881] sd 1:0:0:0: [sda] Write Protect is off
[ 2.430886] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.430932] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.431892] sda: sda1 sda2 < sda5 >
[ 2.432438] sd 1:0:0:0: [sda] Attached SCSI disk
[ 2.437389] sr0: scsi3-mmc drive: 48x/48x cd/rw xa/form2 cdda tray
[ 2.437398] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.437656] sr 2:0:0:0: Attached scsi CD-ROM sr0
[ 2.491242] usb 4-2: New USB device found, idVendor=15d9, idProduct=0a4c
[ 2.491250] usb 4-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.491257] usb 4-2: Product: USB OPTICAL MOUSE
[ 2.508891] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.1/usb4/4-2/4-2:1.0/input/input5
[ 2.509012] generic-usb 0003:15D9:0A4C.0003: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.1-2/input0
[ 2.676888] device-mapper: uevent: version 1.0.3
[ 2.677394] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 2.755628] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.014357] init: ureadahead main process (182) terminated with status 5
[ 3.191592] Adding 8280060k swap on /dev/sda5. Priority:-1 extents:1 across:8280060k SS
[ 3.222798] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 3.447126] systemd-udevd[300]: starting version 204
[ 3.549128] lp: driver loaded but no devices found
[ 3.571448] ppdev: user-space parallel port driver
[ 3.574759] parport_pc 00:07: reported by Plug and Play ACPI
[ 3.574825] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 3.597023] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 3.672330] lp0: using parport0 (interrupt-driven).
[ 3.679438] fuse init (API version 7.18)
[ 3.720838] systemd-udevd[317]: renamed network interface eth0 to eth5
[ 3.800277] microcode: CPU0 sig=0xf65, pf=0x4, revision=0x7
[ 4.000743] device-mapper: multipath: version 1.3.0 loaded
[ 4.094078] microcode: CPU1 sig=0xf65, pf=0x4, revision=0x7
[ 4.105718] Bluetooth: Core ver 2.16
[ 4.105781] NET: Registered protocol family 31
[ 4.105927] Bluetooth: HCI device and connection manager initialized
[ 4.105933] Bluetooth: HCI socket layer initialized
[ 4.105937] Bluetooth: L2CAP socket layer initialized
[ 4.105950] Bluetooth: SCO socket layer initialized
[ 4.117943] Bluetooth: RFCOMM TTY layer initialized
[ 4.117952] Bluetooth: RFCOMM socket layer initialized
[ 4.117956] Bluetooth: RFCOMM ver 1.11
[ 4.122473] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.122479] Bluetooth: BNEP filters: protocol multicast
[ 4.139465] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 4.172582] input: HP WMI hotkeys as /devices/virtual/input/input6
[ 4.229567] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input7
[ 4.233452] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 4.233742] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 4.234015] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 4.234483] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 5.368509] ADDRCONF(NETDEV_UP): eth5: link is not ready
[ 5.626175] init: samba-ad-dc main process (730) terminated with status 1
[ 6.413789] init: plymouth-upstart-bridge main process ended, respawning
[ 7.586294] init: plymouth-stop pre-start process (1393) terminated with status 1
[ 14.152020] [drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung
[ 14.152032] [drm] capturing error event; look for more information in /debug/dri/0/i915_error_state
[ 29.045137] I-pipe: head domain RTAI registered.
[ 29.045146] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 29.045229] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 29.045234] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 3391275000, CPU_FREQ 3391275000
[ 29.045238] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 29.045243] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12375000
[ 29.064872] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 29.064922] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 29.064931] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 29.064937] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3391275000 hz.
[ 29.064941] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 29.099832] RTAI[math]: loaded.
[ 29.306719] hm2: loading Mesa HostMot2 driver version 0.15
[ 29.312370] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 29.312421] hm2_pci: discovered 5i25 at 0000:07:04.0
[ 29.315462] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 29.315467] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 29.315471] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 29.315475] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #0, pin Step (Output)
[ 29.315479] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 29.315483] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #0, pin Direction (Output)
[ 29.315487] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 29.315490] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #1, pin Step (Output)
[ 29.315494] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 29.315498] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #1, pin Direction (Output)
[ 29.315502] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #2, pin Step (Output)
[ 29.315506] hm2/hm2_5i25.0: IO Pin 010 (P3-07): StepGen #2, pin Direction (Output)
[ 29.315510] hm2/hm2_5i25.0: IO Pin 011 (P3-08): StepGen #3, pin Step (Output)
[ 29.315514] hm2/hm2_5i25.0: IO Pin 012 (P3-09): StepGen #3, pin Direction (Output)
[ 29.315518] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 29.315522] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin A (Input)
[ 29.315526] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[ 29.315530] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin Index (Input)
[ 29.315534] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 29.315537] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 29.315541] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #4, pin Step (Output)
[ 29.315545] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 29.315548] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #4, pin Direction (Output)
[ 29.315552] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 29.315556] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 29.315559] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 29.315562] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 29.315566] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 29.315569] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 29.315573] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 29.315576] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 29.315580] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 29.315583] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 29.315586] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 29.315590] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 29.315763] hm2/hm2_5i25.0: registered
[ 29.315766] hm2_5i25.0: initialized AnyIO board at 0000:07:04.0
[ 30.739329] hm2_5i25.0: dropping AnyIO board at 0000:07:04.0
[ 30.739340] hm2/hm2_5i25.0: unregistered
[ 30.740737] hm2_pci: driver unloaded
[ 30.744445] hm2: unloading
[ 32.908505] RTAI[math]: unloaded.
[ 32.911533] SCHED releases registered named ALIEN PEDV$D
[ 32.925686] RTAI[malloc]: unloaded.
[ 33.024038] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 33.026892] I-pipe: head domain RTAI unregistered.
[ 33.027147] RTAI[hal]: unmounted.
[ 44.835740] I-pipe: head domain RTAI registered.
[ 44.835749] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 44.835833] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 44.835840] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 3391275000, CPU_FREQ 3391275000
[ 44.835845] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 44.835851] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 11984000
[ 44.847083] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 44.847137] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 44.847145] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 44.847150] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3391275000 hz.
[ 44.847153] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 44.867816] RTAI[math]: loaded.
[ 45.046098] hm2: loading Mesa HostMot2 driver version 0.15
[ 45.049603] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 45.049650] hm2_pci: discovered 5i25 at 0000:07:04.0
[ 45.052412] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 45.052418] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 45.052422] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 45.052505] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #0, pin Step (Output)
[ 45.052516] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 45.052524] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #0, pin Direction (Output)
[ 45.052535] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 45.052544] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #1, pin Step (Output)
[ 45.052554] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 45.052562] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #1, pin Direction (Output)
[ 45.052566] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #2, pin Step (Output)
[ 45.052577] hm2/hm2_5i25.0: IO Pin 010 (P3-07): StepGen #2, pin Direction (Output)
[ 45.052588] hm2/hm2_5i25.0: IO Pin 011 (P3-08): StepGen #3, pin Step (Output)
[ 45.052598] hm2/hm2_5i25.0: IO Pin 012 (P3-09): StepGen #3, pin Direction (Output)
[ 45.052608] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 45.052617] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin A (Input)
[ 45.052627] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[ 45.052636] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin Index (Input)
[ 45.052646] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 45.052654] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 45.052664] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #4, pin Step (Output)
[ 45.052674] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 45.052683] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #4, pin Direction (Output)
[ 45.052693] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 45.052701] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 45.052709] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 45.052718] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 45.052726] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 45.052735] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 45.052744] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 45.052752] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 45.052761] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 45.052770] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 45.052778] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 45.052786] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 45.052965] hm2/hm2_5i25.0: registered
[ 45.052972] hm2_5i25.0: initialized AnyIO board at 0000:07:04.0
[ 46.367937] hm2_5i25.0: dropping AnyIO board at 0000:07:04.0
[ 46.367946] hm2/hm2_5i25.0: unregistered
[ 46.369261] hm2_pci: driver unloaded
[ 46.372124] hm2: unloading
[ 48.529543] RTAI[math]: unloaded.
[ 48.532251] SCHED releases registered named ALIEN PEDV$D
[ 48.537837] RTAI[malloc]: unloaded.
[ 48.636026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 48.638864] I-pipe: head domain RTAI unregistered.
[ 48.639120] RTAI[hal]: unmounted.
  • Moderator
  • Moderator
28 Oct 2019 20:55 #149002 by tommylight
Replied by tommylight on topic Message
Do not edit files on a windows computer.
Make a new config and edit it on a Linux computer.
28 Oct 2019 23:32 #149021 by bevins
Replied by bevins on topic Message
Or use something like notepad++. that will get rid of the line endings.
29 Oct 2019 11:39 #149043 by Hakan
Replied by Hakan on topic Message
But isn't the real problem the next line
which seems to be some bug in the graphics driver. Gone in newer linuxes.
30 Oct 2019 20:36 #149216 by Irritant
Thanks for the help to all. I will see of this helps me. Thanks,!
06 Nov 2019 21:13 #149752 by Irritant
Well I am pretty much lost on this. Are there still guys that will sell a drive with it all installed and working?
Time to create page: 0.179 seconds
