- Thank you received: 43
7i76e configuration tool error
- CNCFred
- Topic Author
6 years 8 months ago #157353
by CNCFred
7i76e configuration tool error was created by CNCFred
Hello,
I made again a fresh install on Debian10 and build the deb package which I then installed on the same machine and it worked.
I also tried to install the configuration tool following jethornton.github.io/7i76e/install.html
starting the 7i76e I get
Since this is the second install on a fresh machine with the same error I wonder if this should be working?
thank you very much for your help
File "/home/user1/.local/bin/7i76e", line 6
from m7i76e.7i76e import main
SyntaxError: invalid syntax
- bbsr_5a
- Thank you received: 106
6 years 8 months ago #157460
by bbsr_5a
Replied by bbsr_5a on topic 7i76e configuration tool error
Hi
do you realy need the Tool for a Real machine or just playing with the experimentel stuff
the PNC Conf can make a 5i25 7i76 that can be used very quick for a machine
Please Keep in mind the Setup tool is only for the basic Configuration of a machione you will need to interact the Files INI
and HAL for a furrther and better setup
It is by far not like the"M" gui as it is based on the setup files not on a interface you can chouse freely to use
The following user(s) said Thank You: CNCFred
- CNCFred
- Topic Author
6 years 8 months ago #157492
by CNCFred
Replied by CNCFred on topic 7i76e configuration tool error
OK if you say I don't need it, I will skip it.
The standard setup works...
What is the "M" gui you are referring to?
So still to deal with Hal and ini, that's hard tobaco
- Thank you received: 5334
6 years 8 months ago #157501
Replied by PCW on topic 7i76e configuration tool error
pncconf for 2.8 or later should support the 7I76E
I don't think JTs 7I76E config tool is finished
- bbsr_5a
6 years 8 months ago #157510
by bbsr_5a
sorry for the missleding "M" means here as far as i get it as a new builder the WINDows Mach3 controller
Thank you PWC to get the info that the new Master is suporting the ETH based cards
is there a Side that provides the newest Development infos for the PNCCONF to readback what is in work or has made it to the Master/Buildbot
in order a List of suported MESA to the Pncconf like FULL/StillExperimental/InDevelop/NOTNow
Time to create page: 0.107 seconds
