LinuxCNC 2.8 doesn't run after upgrading from 2.7
5 years 11 months ago - 5 years 11 months ago #190619 by rbarry1068
Hope someone can help me debug my installation. I was running LinuxCnc 2.7 then upgraded to 2.8, now I can't get LinuxCnc up and running with my machine configuration (it runs until I try to load in my machine config file). I'm running Debian Stretch with RTAI. See attached error log file:
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0
Machine configuration directory is '/home/robert/linuxcnc/configs/Solsylva_24by48'
Machine configuration file is 'Solsylva_24by48.ini'
INIFILE=/home/robert/linuxcnc/configs/Solsylva_24by48/Solsylva_24by48.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins
Starting LinuxCNC...
Found file(REL): ./Solsylva_24by48.hal
Found file(REL): ./custom.hal
INFO CLASSICLADDER- No ladder GUI requested-Realtime runs till HAL closes.
Starting DISPLAY program: axis
USRMOT: ERROR: command timeout
emcMotionInit: emcTrajInit failed
waiting for s.joints<0>, s.kinematics_type<0>
Debug file information:
Note: Using POSIX non-realtime
note: MAXV max: 1.000 units/sec 60.000 units/min
note: LJOG max: 1.000 units/sec 60.000 units/min
note: LJOG default: 0.200 units/sec 12.000 units/min
Waiting for component 'inihal' to become ready...................................A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
..11442
11493
..........HAL: ERROR: exit called before init
<commandline>:0: waitpid failed milltask inihal
<commandline>:0: milltask exited without becoming ready
Stopping realtime threads
Unloading hal components
Waited 3 seconds for master. giving up.
classicladder_rt: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
stepgen: not loaded
hal_parport: not loaded
motmod: not loaded
trivkins: not loaded
<commandline>:0: unloadrt failed
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Sun Nov 29 12:56:40 EST 2020
UTC Date: Sun Nov 29 17:56:40 UTC 2020
this program: /usr/bin/linuxcnc_info
uptime: 12:56:40 up 25 min, 1 user, load average: 0.46, 0.61, 0.40
lsb_release -sa: Debian Debian GNU/Linux 9.13 (stretch) 9.13 stretch
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/robert/linuxcnc/configs/Solsylva_24by48
USER: robert
LOGNAME: robert
HOME: /home/robert
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1280x1024 pixels (338x270 millimeters)
PATH: /usr/bin:/home/robert/linuxcnc/configs/Solsylva_24by48/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: robworkshop2
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
machine -m: i686
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/vmlinuz-3.4-9-rtai-686-pae root=/dev/mapper/robworkshop2-root ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
model name: AMD FX(tm)-6300 Six-Core Processor
cores: 3
cpu MHz: 3515.558
parport: 0378-037a : parport0
serial: 03f8-03ff : serial
Versions:
gcc: gcc (Debian 6.3.0-18+deb9u1) 6.3.0 20170516
python: Python 2.7.13
git: git version 2.11.0
git commit: NA
/usr/bin/linuxcnc_info: line 155: tclsh: command not found
tcl:
/usr/bin/linuxcnc_info: line 156: wish: command not found
tk:
glade: not_in_PATH
glade-gtk2: glade3 3.8.0
linuxcnc_var all:
LINUXCNCVERSION: 2.8.0
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
rc linuxcnc 1:2.8.0~pre1.3935.g715a485 i386 motion controller for CNC machines and robots
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.8.0~pre1.3935.g715a485 all motion controller for CNC machines and robots (English documentation)
ii linuxcnc-doc-es 1:2.8.0 all controlador de movimiento para máquinas CNC y robots (Español).
un linuxcnc-sim <none> <none> (no description available)
ii linuxcnc-uspace 1:2.8.0 i386 motion controller for CNC machines and robots
Last edit: 5 years 11 months ago by rbarry1068. Reason: added additional details
5 years 11 months ago #190623 by tommylight
Main issue seems to be using a uspace version of LinuxCNC with an RTAI kernel, so it is working as sim only.
You need to install the RTAI version of LinuxCNC, not the Preempt-RT version, or install a Preempt-RT kernel.
See here on how to do that:
linuxcnc.org/docs/2.8/html/getting-start...dating-linuxcnc.html
The easiest would be to download the official ISO, but make sure you back up the configs and anything related to them and that the PC can handle the new operating system.
5 years 10 months ago #193248 by rbarry1068
OK, I have installed Debian 10 with LinuxCnC 2.8.1 from the LinuxCnc 2.8.0 - Buster installation image. I am now running the RT-Preempt kernel. uname -r gives "4.19.0-13-rt-amd64" and I am using uspace LinuxCnC. I think this is correct from what I read in the "getting Started V2.8.1" Manual.
My machine seems to be running OK now.
THanks.
Time to create page: 0.047 seconds
