Debian Buster is not running Ncam
5 years 9 months ago #194993 by Barry
I have been using NativeCam for a couple of years and have successfully installed it on 8 machines all running Debian; however, when I upgraded my operating system to Debian Buster, NativeCam no longer worked. Please help.
To find the bugs, I opened a terminal and imported ncam.py into Python3. It looked like Buster did not load the following modules and their dependencies as part of it's basic installation package,
Pango.py
python-gobject
gtk
pygtk
cStringIO
Tkinter
configparser
and there may have been more.
Is there an easy way to upload these modules and all of their dependencies into Debain Buster. The Synaptic Package Manager did not appear to have these listed and I researched Forums, but got overwhelmed by what appeared to be a very lengthy and time consuming process for doing this. Please help.
Thank you,
Barry
5 years 9 months ago #195016 by pdxalz
Take a look at this post: NativeCAM deb package for BUSTER
The post by russtuff has a solution that works.
5 years 9 months ago #195136 by Barry
Thank you. I followed the instructions exactly; however, ncam is still not running in Buster, I am getting the error message:
no module named gtk
Any thoughts on what to do next?
Thank you,
Barry
5 years 9 months ago #195149 by andypugh
Maybe try installing gtk2?
At a guess: sudo apt-get install gtk2
5 years 9 months ago #195151 by andypugh
Did you install standard Buster or the LinuxCNC disto? I would expect the LinuxCNC version to be compatible. Or, at least, more compatible.
5 years 9 months ago #195174 by Barry
You are definitely pointing me in the right direction and thought that I was there...but then OMGosh, I ran ncam and got the error....No module named linuxcnc. I then looked under the Applications pull down menu and sure enough linuxcnc was not installed. So as you suspected, obviously I must have downloaded the wrong iso but where do I go to get the right iso? I downloaded DVD-1 from the address below. I assumed that this was the standard Buster and not the LinuxCNC distro.
cdimage.debian.org/debian-cd/current/amd64/iso-dvd/
[ISO] debian-10.7.0-amd64-DVD-1.iso
Anyway this may not matter now since I don't have the linuxcnc module installed, but to successfully clear all of earlier error messages I did the following.
Open Applications > System > Synaptic Package Manager
Select everything starting with "gtk" for install (I agree this was obsessive but hey it worked! :))
Opened a terminal and typed
sudo apt-get install python-tk
sudo apt update -y
sudo apt upgrade -y
ncam
then the error message....No module named linuxcnc....darn it!
With just a little more coaching & help I know I can get this working in Buster.
Can you please point me in the right direction for the right iso download for both the AMD64 format and the i386 format?
Thank you for helping me with this.
Barry
Time to create page: 0.374 seconds
