Linuxcnc-ethercat: undefined symbol: ecrt_slave_config_sdo
- Stormholt
- Thank you received: 8
22 Mar 2021 05:57 #203225
by Stormholt
Linuxcnc-ethercat: undefined symbol: ecrt_slave_config_sdo was created by Stormholt
Hello
I know this problem is pretty normal with first installation of linuxcnc-ethercat, however none of the answers on the other topics have done it for me, or maybe i am too dense to understand the answer.
SO... i have followed Grotius' installation guide using ec-debianize.
The error happens when running the line "loadrt lcec" in the postgui.hal file
The answers i have already tried to solve this with have been:
Using the realtime.mk from 0.9.1 release
This one, not quite relevant due to the installation method
This never really came to a conclusion
I definetly believe that the lcec.so and libethercat are not linked properly as "ldd lcec.so" prints:However i have no idea how to solve this.
libethercat.so are located: /usr/lib/x86_64-linux-gnu/libethercat.so
I have gone through the process of installation on two pc's, one with ubuntu 20.04 and another with Mint 19.3, both have reached the same point.
Can someone please help me ? Thanks in advance
lcec: dlopen: /home/vaerks/linuxcnc/rtlib/lcec.so: undefined symbol: ecrt_slave_config_sdo
hal/postgui.hal:7: waitpid failed /home/vaerks/linuxcnc/bin/rtapi_app lcec
hal/postgui.hal:7: /home/vaerks/linuxcnc/bin/rtapi_app exited without becoming ready
hal/postgui.hal:7: insmod for lcec failed, returned -1The answers i have already tried to solve this with have been:
ldd ~/linuxcnc/rtlib/lcec.so
linux-vdso.so.1 (0x00007ffc4c342000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f7837fbb000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f7837bca000)
/lib64/ld-linux-x86-64.so.2 (0x00007f7838579000)libethercat.so are located: /usr/lib/x86_64-linux-gnu/libethercat.so
- Hakan
- Thank you received: 482
22 Mar 2021 06:22 - 22 Mar 2021 06:24 #203227
by Hakan
Replied by Hakan on topic Linuxcnc-ethercat: undefined symbol: ecrt_slave_config_sdo
The step to place a small file in /etc/ld.so.conf.d to help find where libethercat.so is has gone wrong.
Before starting linuxcnc enter
% export LD_LIBRARY_PATH=/opt/etherlab/lib:$LD_LIBRARY_PATH
or wherever the libethercat.so is.
Last edit: 22 Mar 2021 06:24 by Hakan.
The following user(s) said Thank You: Stormholt
- Stormholt
22 Mar 2021 07:23 #203231
by Stormholt
Replied by Stormholt on topic Linuxcnc-ethercat: undefined symbol: ecrt_slave_config_sdo
Hello Hakan, thank you for your answer!
I tried the following before running linuxcnc:However it did not seem to work :-/
After linuxcnc i get this:
$ export LD_LIBRARY_PATH=/usr/lib/x86_64-linux-gnu$LD_LIBRARY_PATH
$ $LD_LIBRARY_PATH
bash: /usr/lib/x86_64-linux-gnu: Is a directoryAfter linuxcnc i get this:
$LD_LIBRARY_PATH
bash: /home/vaerks/linuxcnc/lib:/usr/lib/x86_64-linux-gnu: No such file or directoryPlease Log in or Create an account to join the conversation.
- Hakan
22 Mar 2021 08:03 #203233
by Hakan
In a new fresh terminal window, type
$ echo $LD_LIBRARY_PATH
If that produce an empty output, then type
If there is an output, type
$ export LD_LIBRARY_PATH=/usr/lib/x86_64-linux-gnu:$LD_LIBRARY_PATH
Don't forget the ":" Then followed by
$ linuxcnc your-ini.ini
It can also be that the libethercat.so is found but the build of it has gone wrong and is missing the functions you list.
- Stormholt
22 Mar 2021 08:10 #203234
by Stormholt
yeah i removed the ":" because the variable was empty.
So it must have something to do with the build as you wrote :-/
- Stormholt
22 Mar 2021 10:42 #203252
by Stormholt
I managed to get past this error. With an answer i had previously tried, but apparently failed
Thanks to Shameless
For anyone with the same problem, You need to overwrite your ~/linuxcnc-ethercat/src/realtime.mk file with the following:
After which you can do following:
Thanks to Shameless
include ../config.mk
include Kbuild
cc-option = $(shell if $(CC) $(CFLAGS) $(1) -S -o /dev/null -xc /dev/null \
> /dev/null 2>&1; then echo "$(1)"; else echo "$(2)"; fi ;)
.PHONY: all clean install
ifeq ($(BUILDSYS),kbuild)
module = $(patsubst %.o,%.ko,$(obj-m))
ifeq (,$(findstring -Wframe-larger-than=,$(EXTRA_CFLAGS)))
EXTRA_CFLAGS += $(call cc-option,-Wframe-larger-than=2560)
endif
$(module):
$(MAKE) EXTRA_CFLAGS="$(EXTRA_CFLAGS)" KBUILD_EXTRA_SYMBOLS="$(RTLIBDIR)/Module.symvers $(RTAIDIR)/modules/ethercat/Module.symvers" -C $(KERNELDIR) SUBDIRS=`pwd` CC=$(CC) V=0 modules
clean::
rm -f $(obj-m)
rm -f *.mod.c .*.cmd
rm -f modules.order Module.symvers
rm -rf .tmp_versions
else
module = $(patsubst %.o,%.so,$(obj-m))
EXTRA_CFLAGS := $(filter-out -Wframe-larger-than=%,$(EXTRA_CFLAGS))
$(module): $(lcec-objs)
$(CC) -shared -o $@ $(lcec-objs) -Wl,-rpath,$(LIBDIR) -L$(LIBDIR) -llinuxcnchal -lethercat -lrt
%.o: %.c
$(CC) -o $@ $(EXTRA_CFLAGS) -Os -c $<
endif
all: $(module)
clean::
rm -f $(module)
rm -f $(lcec-objs)
install: $(module)
mkdir -p $(DESTDIR)$(RTLIBDIR)
cp $(module) $(DESTDIR)$(RTLIBDIR)/After which you can do following:
cd ~/linuxcnc-ethercat
make clean
make
sudo make install
The following user(s) said Thank You: cncLab, mat1370
- Grotius
- Thank you received: 2349
22 Mar 2021 10:46 - 22 Mar 2021 10:51 #203254
by Grotius
Replied by Grotius on topic Linuxcnc-ethercat: undefined symbol: ecrt_slave_config_sdo
For ethercat i have a iso over here.
And a newer iso over here.
Ethercat is working for kernels up to 4.19 with ec-debianize. Tested on Debian.
For your error : undefined symbol: ecrt_slave_config_sdo.
Did you follow the ec-debianize procedure and installed the 2 .deb package's both?
To be sure, i advise to install a fresh pc and do the process again. But you fixed it i see, nice !
The mercurial repository has changed to git. See etherlab website. This is important for ec-debianize.
The source is changed, and at the moment not compatible with newer kernels.
Finally i now have my new distro Bullseye working with realtime kernel and ethercat.
Linux debian 5.10.0-4-rt-amd64 And Linux debian 5.10.0-5-rt-amd64 are working for ethercat.
Today i had a conversation with Florian Pose about some ethercat problems, related to the latest kernels > 5.0.0
They are solved. So now i must look to make a .deb package for it. And i must dig into ec-debianize to fix this.
Last edit: 22 Mar 2021 10:51 by Grotius.
The following user(s) said Thank You: arvidb, Stormholt, Rabin
- Stormholt
23 Mar 2021 03:28 #203360
by Stormholt
Hey Grotius
I have been reading a lot of your post getting into ethercat with linuxcnc, so thank for your answer to this topic and thanks for your answers in general.
I did indeed follow the ec-debianize procedure and installed both packages.
In terms of kernel my first attempt was on Ubuntu 20.04 withLinux 5.8.0-45-generic x86_64 and second attempt on Mint 19.3 with Linux 5.0.0-32-generic x86_64, so i am very interested in the .deb package and revision to ec-debianize you will be working on. Where can i follow the development of this project or get notified of its completion?
- Grotius
23 Mar 2021 05:39 #203377
by Grotius
Hi Stromholt,
5.8.0-45-generic x86_64, i don't know if this is compatible. Ubuntu is long time ago for me.
For Debian i use at least a "rt" in the kernel name.
Current development for compatibility with latest kernels is here
It's like a working dir for me.
Just got linuxcnc deb package ready, and now starting with the ec-debianize story. I hope it goes well. But i know with linux
you could get a few head scratchers....
But my starting point is perfect. Ethercat-bus works already and Linuxcnc works.
- Stormholt
23 Mar 2021 07:20 #203383
by Stormholt
And of course it makes sense you would primarily work with real time kernels, however i am working on a team taking turns working with the actually cnc machine so i mainly develop and sim on my private ubuntu pc and later push an implement on the actual machine with an rt kernel.
I will try and setup a machine with this kernel (similar to our machine) to work with ethercat.
Good luck with the head scratching!
