New User problems...Linuxcnc terminated with an error
27 Jun 2021 04:30 #212998 by Simon
Hello good people :)
Complete new user here. I have spent all weekend trying to install and configure linuxcnc and a mesa 7i76e board, for a Churchill-Redman lathe (Monarch copy) conversion, with limited success so far.
I bought the 7i76e second hand, but unused. The guy I got it from originally bought it in 2014.
Card details:
7I76E
Mesa Electronics lot#13608L1
Firmware revision S14H1
UNIT = 1A000005
I have tried several installations of different iso's ,and am currently running Debian Buster 2.8.0 iso. Running on an old windows machine I had kicking around.
simon@debian:~$ sudo lshw -short
H/W path               Device           Class          Description
                                        system         To Be Filled By O.E.M. (T
/0                                      bus            B75M-ITX
/0/0                                    memory         64KiB BIOS
/0/7                                    memory         1MiB L2 cache
/0/8                                    memory         256KiB L1 cache
/0/9                                    memory         6MiB L3 cache
/0/a                                    memory         4GiB System Memory
/0/a/0                                  memory         DIMM [empty]
/0/a/1                                  memory         4GiB DIMM DDR3 Synchronou
/0/b                                    processor      Intel(R) Core(TM) i5-3470
/0/100                                  bridge         Xeon E3-1200 v2/3rd Gen C
/0/100/2                                display        Xeon E3-1200 v2/3rd Gen C
/0/100/14                               bus            7 Series/C210 Series Chip
/0/100/14/0            usb2             bus            xHCI Host Controller
/0/100/14/1            usb3             bus            xHCI Host Controller
/0/100/16                               communication  7 Series/C216 Chipset Fam
/0/100/1a                               bus            7 Series/C216 Chipset Fam
/0/100/1a/1            usb1             bus            EHCI Host Controller
/0/100/1a/1/1                           bus            Integrated Rate Matching
/0/100/1a/1/1/2                         input          HP USB Optical Mouse
/0/100/1a/1/1/4                         generic        802.11n WLAN Adapter
/0/100/1b                               multimedia     7 Series/C216 Chipset Fam
/0/100/1c                               bridge         7 Series/C216 Chipset Fam
/0/100/1c.3                             bridge         7 Series/C216 Chipset Fam
/0/100/1c.3/0          enp2s0           network        RTL8111/8168/8411 PCI Exp
/0/100/1d                               bus            7 Series/C216 Chipset Fam
/0/100/1d/1            usb4             bus            EHCI Host Controller
/0/100/1d/1/1                           bus            Integrated Rate Matching
/0/100/1d/1/1/5                         bus            Hub in Apple Extended USB
/0/100/1d/1/1/5/3                       input          Apple Extended USB Keyboa
/0/100/1e                               bridge         82801 PCI Bridge
/0/100/1f                               bridge         B75 Express Chipset LPC C
/0/100/1f.2            scsi0            storage        7 Series/C210 Series Chip
/0/100/1f.2/0.0.0      /dev/sda         disk           320GB ST320LT007-9ZV14
/0/100/1f.2/0.0.0/1    /dev/sda1        volume         294GiB EXT4 volume
/0/100/1f.2/0.0.0/2    /dev/sda2        volume         3775MiB Extended partitio
/0/100/1f.2/0.0.0/2/5  /dev/sda5        volume         3775MiB Linux swap volume
/0/100/1f.3                             bus            7 Series/C216 Chipset Fam
/0/1                                    system         PnP device PNP0c01
/0/2                                    system         PnP device PNP0c02
/0/3                                    system         PnP device PNP0b00
/0/4                                    generic        PnP device INT3f0d
/0/5                                    system         PnP device PNP0c02
/0/6                                    system         PnP device PNP0c02
/0/c                                    system         PnP device PNP0c02
/0/d                                    system         PnP device PNP0c01
/1                     wlx801f02fda5f4  network        Wireless interface
simon@debian:~$ uname -a
Linux debian 4.19.0-11-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.146-1 (2020-09-17) x86_64 GNU/Linux
I have managed to get the network talking to the card, but only on the default IP 192.168.1.121, for some reason I can't connect using 10.10.10.10, the ping drops all packets, and mesaflash says no 7i76e found...
When using the default IP I get:
simon@debian:~$ mesaflash --device 7i76e --verbose
ETH device 7I76E-16 at ip=192.168.1.121
Communication:
  transport layer: ethernet IPv4 UDP
  ip address: 192.168.1.121
  mac address: 00:60:1B:10:40:05
  protocol: LBP16 version 2
Board info:
  Flash size: 16Mb (id: 0x14)
  Connectors count: 3
  Pins per connector: 17
  Connectors names: on-card P1 P2
  FPGA type: 6slx16ftg256
  Number of leds: 4
Board firmware info:
  memory spaces:
    0: HostMot2 (registers, RW, 32-bit) [size=64K]
    1: KSZ8851 (registers, RW, 16-bit) [size=256]
    2: EtherEEP (EEPROM, RW, 16-bit) [size=128], page size: 1, erase size: 1
    3: FPGAFlsh (flash, RW, 32-bit) [size=16M], page size: 256, erase size: 65536
    6: LBP16RW (memory, RW, 16-bit) [size=16]
    7: LBP16RO (memory, RO, 16-bit) [size=16]
  [space 0] HostMot2
  [space 2] Ethernet eeprom:
    ip address: 10.10.10.10
    board name: 7I76E-16
    user leds: eth debug
  [space 3] FPGA flash eeprom:
    flash size: 16Mb (id: 0x14)
  [space 6] LBP16 control/status:
    packets received: all 23738, UDP 20007, bad 0
    packets sent: all 12346, UDP 12333, bad 0
    parse errors: 4, mem errors 0, write errors 0
    error flags: 0x0001
    debug LED ptr: 0x0008
    scratch: 0x0000
  [space 7] LBP16 info:
    LBP16 protocol version 2
    board firmware version 13
    IP address jumpers at boot: fixed 192.168.1.121
Now to my problem...I have run through the Pncconf, with a very basic step and direction only configuration, just to try and make a stepper going...baby steps...
The Hal latency test shows:
Servo thread (1ms): Max Jitter 6011
Base Thread (25us): Max jitter 12973
The test / tune axis dosen't appear to do anything, otherwise the Pncconf finishes without errors.
However, when I run Linuxcnc, it does not start, saying linuxcnc terminated with and error.
And running linuxcnc from the console I get:
simon@debian:~$ linuxcnc
LINUXCNC - 2.8.1
Machine configuration directory is '/home/simon/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'my_LinuxCNC_machine.ini'
Starting LinuxCNC...
Found file(REL): ./my_LinuxCNC_machine.hal
Note: Using POSIX realtime
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: INFO: Hardware address (MAC): 00:60:1b:10:40:05
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: Low Level init 0.15
hm2/hm2_7i76e.0: Smart Serial Firmware Version 42
Board hm2_7i76e.0.7i76.0.0 Hardware Mode 0 = standard
Board hm2_7i76e.0.7i76.0.0 Software Mode 0 = io_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 1 = io_ana_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
board fails HM2 registration
hm2_eth: in hm2_eth_reset
hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
./my_LinuxCNC_machine.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./my_LinuxCNC_machine.hal:9: /usr/bin/rtapi_app exited without becoming ready
./my_LinuxCNC_machine.hal:9: insmod for hm2_eth failed, returned -1
Running HAL shutdown script
hm2: unloading
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/simon/linuxcnc_debug.txt
and
    /home/simon/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
This has been a pretty tough learning curve, having never used linux before this weekend. All my knowledge so far comes from this forum, and I wouldn't have got this far without it, but I am at a loss what to try next.
Any help would be greatly appreciated!
Cheers,
Simon : )
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
27 Jun 2021 04:44 #213000 by BeagleBrainz
Shame you're having a issue, Mesa gear is rock solid.
Do you have the Mesa card connected to the computer directly via cable. ie not through a hub, switch or router ?
That's all I can suggest at the moment, PCW should chime and fix you right up.
In the meantime could you post your hal & ini file ? These always help in debugging issues.
27 Jun 2021 06:23 #213003 by chris@cnc
let's analyze the debug first.
You want to load this config: "my_LinuxCNC_machine.ini" with this card: "hm2_eth: 192.168.1.121:. "
The message from the debug.
"hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)"
Possible mistake:
Your network configuration is not correct and your card cannot be found.
Network card in the PC must have a static IP address and other than your "7i76e" adress.
wiki.debian.org/NetworkConfiguration
The channel is busy during operation and cannot talk to any other device. There should be no hub or router between.
To use adress 10.10.10.10 set up jumper W3 in UP position.
Common stable setup is 2 Networkcards.
In PC static address 10.10.10.1 and mesa address 10.10.10.10 with set up Jumper W3.
Second card adjust to your home network.
27 Jun 2021 07:53 #213005 by Simon
Thanks for the speedy replies!
Some progress!
I can now connect with mesaflash using 10.10.10.10. I wonder if my problems might be coming from Wicd network manager? I only have one ethernet card, and am using an edimax USB wifi doodad for internet connection.
Wicd only seems to let me connect to either the wifi or mesa card, but not both at the same time. I just de-selected 'automatically connect to this network' for the wifi, and mesaflash connected for the first time using 10.10.10.10...
simon@debian:~$ ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether bc:5f:f4:a2:1c:4d brd ff:ff:ff:ff:ff:ff
    inet 10.10.10.11/8 brd 10.255.255.255 scope global enp2s0
    inet6 fe80::be5f:f4ff:fea2:1c4d/64 scope link
5: wlx801f02fda5f4: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    link/ether 80:1f:02:fd:a5:f4 brd ff:ff:ff:ff:ff:ff
simon@debian:~$ mesaflash --device 7i76e --addr 10.10.10.10 --verbose
ETH device 7I76E-16 at ip=10.10.10.10
Communication:
Board info:
  Connectors count: 3
  Number of leds: 4
  memory spaces:
  [space 0] HostMot2
    packets received: all 15577, UDP 15091, bad 0
    packets sent: all 9354, UDP 9334, bad 0
    parse errors: 3, mem errors 0, write errors 0
    error flags: 0x0001
    scratch: 0x0000
    IP address jumpers at boot: fixed from EEPROM
But, linuxcnc is still not loading...I did just notice the line: "Note: Using POSIX realtime"
is this my problem? Does it need to be preemp rt kernel for the 7i76e?
LINUXCNC - 2.8.1
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:10:40:05
hm2: unloading
and
I tried looking through the dmesg, but I don't know what I'm looking for : /
Thanks again,
Simon.
  • BeagleBrainz
  • Visitor
  • Visitor
27 Jun 2021 07:55 - 27 Jun 2021 07:56 #213006 by BeagleBrainz
Going by this
The driver has found the MAC and reports discovering the 7i76e.
The Op has also reported he managed to get info from the board, so I think we can assume that the PC & Mesa card are on the same network. Hopefully the wireless & wired network are on different networks......otherwise there could be an issue.
The output of
ip a
would help.
Last edit: 27 Jun 2021 07:56 by BeagleBrainz.
27 Jun 2021 08:16 #213007 by Simon
Thanks again,
I will show two results for ip a, because I can only connect to either wifi or the mesa card at one time.
This one when I'm connected to the 7i76:
And this one when I'm connected to wifi.
5: wlx801f02fda5f4: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    inet 192.168.20.43/24 brd 192.168.20.255 scope global dynamic wlx801f02fda5f4
       valid_lft 86393sec preferred_lft 86393sec
    inet6 fe80::821f:2ff:fefd:a5f4/64 scope link
27 Jun 2021 08:32 - 27 Jun 2021 08:32 #213008 by chris@cnc
uname -a show: "Linux debian 4.19.0-11-rt-amd64 #1 SMP PREEMPT RT"
You have the right one
but to start linuxcnc change into your config folder
cd /home/simon/linuxcnc/configs/my_LinuxCNC_machine
and start linuxcnc by
linuxcnc my_LinuxCNC_machine.ini
or shortcut on your desktop
But share your hal and ini. Maybe there is something wrong inside
Last edit: 27 Jun 2021 08:32 by chris@cnc.
  • Moderator
  • Moderator
27 Jun 2021 08:38 #213009 by tommylight
1 how is Mesa powered
2 give us the "debug" part of the error report also.
  • BeagleBrainz
  • Visitor
  • Visitor
27 Jun 2021 08:44 - 27 Jun 2021 08:44 #213010 by BeagleBrainz
This is your issue.
The PC & Mesa card must be on the same network.
The Mesa card can not have a 192.168.1.xxx and the PC have a 10.10.10.xxx address.
Also the wired network card must have a static address. The reason for this is that the Mesa card most be connected directly to the PC via a cable, there can be no hub, switch or router connected and therefore there will be no other device that can give out an IP address.
Technically there is no reason why the wifi interface & wired interface can not be enabled at the same time. But they must be on separate networks.
ie: The wifi would have an 192.168.1.xx address
The wired interface would have a 10.10.10.xxx address (but not the same as the mesa card)
The manual for the 7i76e is here www.mesanet.com/pdf/parallel/7i76eman.pdf and has info on setting the jumpers.
The page for the IP Address is here: www.mesanet.com/pdf/parallel/7i76eman.pdf#page=10
Set the Jumpers for "FIXED FROM EEPROM" as long as the user hasn't messed with this.
Remember to power down the 7i76e before changing the jumpers.
Last edit: 27 Jun 2021 08:44 by BeagleBrainz.
27 Jun 2021 13:17 #213018 by arvidb
This user had the same issue. Flashing an up-to-date bitfile seems to have fixed the problem, if I get that thread correctly.
Time to create page: 4.378 seconds
