How build Linuxcnc with xenomai3?
3 years 1 month ago #279778 by shaying526
Hi Franco,
Your information is very useful to me
I want to build a LinuxCNC based on Xenomai
But I couldn't find the installation tutorial in 'Getting Started'
Do you have any related installation tutorial links?
Much thanks!
3 years 1 month ago #279799 by SummerLotus
Hello, do you have the steps to compile and configure xenomai with linuxcnc? When I use --with-realtime=uspace, it always prompts that it is POSIX, not XENOMAI (posix-skin) realtime
3 years 1 month ago #279803 by andypugh
To run with Xenomai you need to install the uspace-xenomai helper package.
Which I have definitely seen, but can't currently find.
buildbot.linuxcnc.org/dists/buster/2.8-rtpreempt/binary-amd64/
For example has the RTA version (linuxcnc-uspace-rtai_2.8.4....deb)
I think that if you compile from source and then build packages you should end up with the Xenomai helper.
Which LinuxCNC version are you using? I can try to look into this.
3 years 1 month ago #279804 by andypugh
Incidentally, I think that you want to end up with the info line saying
"Note: Using XENOMAI (posix-skin) realtime"
github.com/LinuxCNC/linuxcnc/blob/2.8/sr...pace_xenomai.cc#L171
3 years 3 weeks ago #282666 by shaying526
hi
I encountered the same problem as you
I found the reason by looking at the source code of LinuxCNC, but I'm not sure if you have the same problem
The source code relies on identifying the complete character '- xenomai' in the string returned by 'uname(&u)' to determine if you are using the xenomai system
'uspace_common.h' line 365: return strcasestr (u.release, "-xenomai") != 0;
and I set 'append to kernel release' to '-xeno' at the beginning
Confirm if you have such a problem
I encountered other issues later, are you Chinese? Add WeChat or my email address
wechat:shaying526
email:solo526@126.com
1 month 3 weeks ago #349490 by Hannes
Hi All
Meanwhile, I fixed Xenomai3 support.
Additionally, I added Xenomai4 including support Ethernet mesa cards.
Details:
github.com/LinuxCNC/linuxcnc/issues/3878
Prebuilt Kernels and Linuxcnc 2.9.10 back-port for Xenomai4:
github.com/hdiethelm/xenomai3-linuxcnc
github.com/hdiethelm/xenomai4-linuxcnc
Is someone using Xenomai3 actively? Xenomai3 support for Ethernet mesa cards is available in a private branch but not (yet) merged.
Time to create page: 0.064 seconds
