Regarding Repositories
- Nitram
- Thank you received: 15
08 Apr 2022 07:17 #239627
by Nitram
Regarding Repositories was created by Nitram
Hello, I just wonder if I have this right...
Having installed Buster from the downloads section, I want to install some probing routines which come as a .zip file.
Back when I had Wheezy installed, I recall there was an unzip program already there.
I cannot find the same thing in this version of Buster and I cannot seem to be able to get a decompression program to be able to unzip the files I have to commence their install.
Are the repositories limited to keep from bloating the OS?
I feel somewhat embarrassed by this but for the life of me I cannot get these files unzipped, nor am I making any headway with my research to do so...
A sudo apt update followed by apt install unzip doesn't do much for me... Is it a repository thing given the image installed??
Thanks.
Thanks.
- Thank you received: 4068
08 Apr 2022 07:31 - 08 Apr 2022 07:31 #239631
Replied by rodw on topic Regarding Repositories
Last edit: 08 Apr 2022 07:31 by rodw.
- Nitram
08 Apr 2022 07:34 #239632
by Nitram
Replied by Nitram on topic Regarding Repositories
sudo apt install unzip gave me unable to locate package unzip.
How do I steer this towards:
packages.debian.org/buster/unzip
- Nitram
08 Apr 2022 07:37 #239633
by Nitram
By the way Rod, IIRC you're in Australia??
I'm up here in Cairns...
08 Apr 2022 07:46 #239634
Its odd that that did not work. what if you try zip instead?
Will they untar?
I guess the other way would be to unzip on another pc an copy to usb stick.
Ahh, another Queenslander! I am in Brisbane. I lived in Atherton for about 12 months back in 1990.By the way Rod, IIRC you're in Australia??
Will they untar?
- Nitram
08 Apr 2022 08:00 #239635
by Nitram
Thanks Rod, I've just unzipped on a PC and will try that...
Still unsure why I cannot get access to any other decompression software out there via this Buster image from the downloads section...
Again, when I had Wheezy it would do it natively, but again, I ma wondering whether the buster image was kept lean? In which case I wonder how I can ultimately get other programs onto this PC then??
I just need a little background on the process and wonder whether the repositories are limited?
I was in Atherton just last weekend and I don't think too much would have changed since 1990!!!
08 Apr 2022 09:07 #239639
I probably would not tamper too much but the file containing the lit of repositories is in
/etc/apt/sources.list
This random link might help
computingforgeeks.com/add-debian-10-bust...ies-to-sources-list/
The following user(s) said Thank You: Nitram
- Nitram
08 Apr 2022 09:11 #239640
by Nitram
Thanks Rod.
I'll check further tommorow.
Cheers again from Mareeba!
08 Apr 2022 09:37 #239642
Doesn't that mean you live in a seperate country up there in FNQ?Thanks Rod.
- Nitram
08 Apr 2022 09:42 #239643
by Nitram
Given the culture and the vibe up here... ALMOST CERTAINLY
Southerners from Melb and Syd think Brisbane is quite a ways north, but don't understand that Cairns/Mareeba/Atherton is still some 1800km further north, and about another 1000km up to the tip!
I have family in Europe and it is almost impossible for them to fathom that those distances and places are even in the same country, let alone the same state!!
So I completely concur, I recon FNQ is pretty much a whole 'nuther country hehehe
Time to create page: 0.273 seconds
