Installation, PC want's to mount a CD-ROM!!! Why and how please?
4 years 6 months ago #241087 by tommylight
It can not be done without a USB or a DVD.
Well it can, but not easy at all.
4 years 6 months ago #241406 by andypugh
I am running into the same problem on a Biostar mini-ITX board. But I boot from an SSD (loaded with the linuxcnc 2.8.2 - buster iso).
Is that SSD meant to be the boot drive? The ISO is a bootable ISO image, but is really intended to be an installer and test environment.
This issue with looking for a DVD is a problem with the Debian installer, and is only found on a subset of machines. You might find more answers looking on generic Debian forums.
4 years 6 months ago #241414 by tommylight
He has written the ISO image to SSD and is booting the PC from it and at the same time trying to install on that same SSD.
4 years 6 months ago #241587 by andypugh
I wonder if that can ever work?
4 years 6 months ago #241590 by tommylight
There is a way, use the empty space left from writing the ISO image to create another EXT4 partition, use that as root partition when installing and install GRUB on /dev/sda, not on /dev/sda1 or sda2.
Never actually tried this, but it should work.
Although the Debian installer is consistently inconsistent ! :)
