Bookworm and Bullseye with latest git linuxcnc
  • kwarup
  • kwarup's Avatar Topic Author
  • Junior Member
  • Junior Member
09 Sep 2022 19:29 - 10 Sep 2022 00:39 #251564 by kwarup
I could not find how to do it,
install bookworm from here
cdimage.debian.org/cdimage/unofficial/no...ng-amd64-netinst.iso
So for that this is the Compilation of latest linuxcnc2.9.0 bookworm.
Linuxcnc Latest 2.9.0 bookworm from github
If this is not usable or this post violate something please remove .
As Root (sudo -i)
BOOKWORM
sudo apt install wget
As Root (sudo -i) import key :
wget -O- deb.durvalhenke.com/durvalhenke.key | gpg --dearmour > /etc/apt/trusted.gpg.d/durvalhenke.gpg
echo "deb [arch=amd64] deb.durvalhenke.com/apt-repo bookworm main " > /etc/apt/sources.list.d/durvalhenke.list
BULLSEYE
echo "deb [arch=amd64] deb.durvalhenke.com/apt-repo bullseye main " > /etc/apt/sources.list.d/durvalhenke.list
sudo apt update
sudo apt upgrade
sudo apt install linuxcnc-uspace
sudo apt install linuxcnc-uspace-dev
sudo apt install mesaflash
Last edit: 10 Sep 2022 00:39 by kwarup.
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
10 Sep 2022 01:38 #251591 by rodw
In Bookworm, you only need to do:
In bullseye. follow this process.
www.qtpyvcp.com/install/bullseye.html
or run this script which does the above automatically
github.com/joco-nz/lcnc-bullseye-installer
You can't guarantee that the bookworm packages will install on bullseye because of different dependencies
Just note that the current version in bookworm dates back to about March. There is a current version in sid but it will take a little while for it to get to bookworm. You could upgrade to sid and it will get the latest.
  • kwarup
  • Junior Member
  • Junior Member
10 Sep 2022 13:39 #251614 by kwarup
there is bookworm and bullseye packages..
I do not want to go to sid on bookworm
Also for me with bullseye updated and upgraded packages this
github.com/jogo-nz/lcnc-bullseye-installer does not compile for me.
Also www.qtpyvcp.com/install/bullseye.html has older linuxcnc-2.9.0pre0 .
This is for my use and research.
I'm retired and with a lot of time to spend .
so for that why not share my work :-)
Anyone is free to use or not, this is for the community.
I wish to have more knowledge to contribute .
10 Sep 2022 19:33 #251631 by tommylight
Replied by tommylight on topic Bookworm and Bullseye with latest git linuxcnc
www.gnipsel.com
JT has guides for all Debians.
  • kwarup
  • Junior Member
  • Junior Member
10 Sep 2022 20:07 #251634 by kwarup
Packages for Ubuntu Jammy finished..Now reading how to do a ppa :-)
Who is curious and want to try ..
download pakages
deb.durvalhenke.com/ubuntu/jammy/main/
www.gnipsel.comJT has guides for all Debians.
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
10 Sep 2022 22:31 #251654 by rodw
www.qtpyvcp.com/install/bullseye.html clones the 2.9 source code so it will always be 100% up to date.
The following user(s) said Thank You: kwarup
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
10 Sep 2022 22:33 #251655 by rodw
www.gnipsel.com
JT's approach is a bit long winded for SID. I think he wanted to ensure  there was mesaflash support for the Mesa 7i96s.
There is no need to do this as the latest is in SID anyway. Bookworm will follow.
The following user(s) said Thank You: tommylight, kwarup
Time to create page: 0.152 seconds
