Debian 12 MESA ethernet with wifi configuration
3 years 3 months ago #274704 by thadwald
I’m in the process of configuring new computer to upgrade an existing system. Right now I’m stuck at getting network to work with both, the MESA ethernet and wifi LAN.
I set up the MESA ethernet in /etc/network/interfaces as per the Debian 12 installation document. This part works fine. However, after configuring my wifi internet connection (via the GUI tool in the taskbar), the system appears to use the MESA ethernet as the default route, and the wifi connection quits working.
If I try to configure MESA ethernet via the GUI tool, the connection appears to work for a few minutes but then disconnects.
I THINK what I want is to specify the MESA  ethernet connection as not providing the default route.
I would also appreciate some clarification as to what the various tools do and if I should be using them. (NetworkManager, networking daemon, etc) I would prefer not having any automatic connections happening on this system.
3 years 3 months ago #274706 by PCW
What address are you using for the real time interface?
Its best to use the 10.10.10.x range for the real time interface
as this does not overlap existing NAT ranges.
3 years 3 months ago #274711 by rodw
Please watch my video
Networking fundamentals is discussed about 16 minutes in
You have to understand this to get the two NICs working.
After that it is easy!
3 years 3 months ago #274722 by thadwald
So you configure all your network interfaces from the gui. The funny thing is that this is the second time around with this specific computer (I messed up something pretty badly and just started again from scratch) and the first time around it worked perfectly. The only thing I did different this time is I unchecked the gnome gui during installation. (Xfce on both)
Yes, I have the MESA board set to 10.10.10.10 and 10.10.10.11 on the nic.
3 years 3 months ago #274736 by thadwald
Turns out it was an issue with my router.
Thanks.
3 years 3 months ago #274737 by tommylight
Mesa board should be wired directly to PC, never through a Hub or Switch or Router or Access point.
Time to create page: 0.059 seconds
