Difficulty building RTAI linuxcnc from source
21 Jul 2023 16:57 #275966 by southbayguy
Have installed Linuxcnc 2.8.4 on Debian 10 Buster.  Have installed a Motenc Lite board.
When the linuxcnc application starts, I accept the motenc configuration.
The application fails.  It reports finding core_servo.hal and motenc_motion.hal, which is encouraging.  But it reports it fails to find hal_motenc.so.  I went to usr/lib/linuxcnc/modules and I couldn't find it either.
Where do I find hal_motenc.so so I can copy it into usr/lib/linuxcnc/modules?
Thanks.
22 Jul 2023 06:44 #275986 by cmorley
Replied by cmorley on topic Difficulty building RTAI linuxcnc from source
Looks like (from the make file) motenc is RTAI only. Did you build for RTAI?
The following user(s) said Thank You: southbayguy
22 Jul 2023 21:37 #276028 by southbayguy
Replied by southbayguy on topic Difficulty building RTAI linuxcnc from source
I'm figuring from your reply that the motenc interface board is supported only by the RTAI kernel. So I went back to the download page and looked at the instructions for downloading Debian 10 Buster RTAI. The instructions contained a link to documentation describing downloading the RTAI kernel, which I followed. The getting and installing of the RTAI kernel seemed to go correctly. I restarted the machine and clicked Applications -> CNC -> LinuxCNC as in previous trials. The application failed again, but with different error messages, which is progress. One of the assignments in the RTAI kernel documentation was to verify the machine booted the RTAI kernel. I didn't know how to do that verification but from reading the error messages it looks like indeed after restart the computer came up under the RTAI kernel.
I would like to attach the error file but don't see how to, so I'm going to copy it into this reply.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-4.19.195-rtai-amd64/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.4
Machine configuration directory is '/home/robert/linuxcnc/configs/by_interface.vitalsystems'
Machine configuration file is 'motenc.ini'
INIFILE=/home/robert/linuxcnc/configs/by_interface.vitalsystems/motenc.ini
VERSION=1.1
PARAMETER_FILE=motenc.var
TASK=milltask
HALUI=
DISPLAY=tklinuxcnc
COORDINATES=X Y Z
KINEMATICS=trivkins
Starting LinuxCNC...
Found file(lib): /usr/share/linuxcnc/hallib/core_servo.hal
Found file(REL): ./motenc_motion.hal
Debug file information:
insmod: ERROR: could not insert module /usr/realtime-4.19.195-rtai-amd64/modules/linuxcnc/hal_motenc.ko: No such device
./motenc_motion.hal:4: exit value: 1
./motenc_motion.hal:4: insmod for hal_motenc failed, returned -1
See the output of 'dmesg' for more information.
1181
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 81.889306] I-pipe: head domain RTAI registered.
[ 81.889307] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[ 81.889309] SYSINFO - # CPUs: 4, TIMER NAME: 'lapic-deadline', TIMER IRQ: 4355, TIMER FREQ: 436496376, CLOCK NAME: 'tsc', CLOCK FREQ: 3491913000, CPU FREQ: 3491913000, LINUX TIMER IRQ: 4355.
[ 81.916994] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 81.917026] kstacks pool size = 524288 bytes
[ 81.917027] RTAI[sched]: hard timer type/freq = lapic-deadline/436496376(Hz)
[ 81.917027] linear timed lists.
[ 81.917028] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3491913000 hz.
[ 81.917028] RTAI[sched]: timer setup = 84 ns, resched latency = 0 ns.
[ 81.922989] USERMODE CHECK: OK.
[ 81.922990] USERMODE CHECK PROVIDED (ns): KernelLatency -1, UserLatency -1.
[ 82.047900] KERNEL SPACE LATENCY ENDED AT CYCLE: 1243, LATENCY = 2035, VARIANCE = 33761/10004569, GAIN = 843651/1000000000, LEAST = 1802.
[ 82.135457] AFTER KERNEL CALIBRATION (WITH RTAI TASK, ns): KernelLatency 582, UserLatency -1 (CALIBRATION: PERIOD 10000 (ns), TIME 212464979 (ns)).
[ 82.282734] USER SPACE LATENCY ENDED AT CYCLE: 1203, LATENCY = 2428.91, VARIANCE = 0.00352333, GAIN = 0.000880833, LEAST = 2394.
[ 82.283597] USERMODE USER SPACE CALIBRATION: OK.
[ 82.283598] AFTER USER CALIBRATION (ns): KernelLatency 582, UserLatency 695 (CALIBRATION: PERIOD 10000 (ns), TIME 148140014 (ns)).
[ 82.283599] FINAL CALIBRATION SUMMARY (ns): KernelLatency 582, UserLatency 695.
[ 82.299324] RTAI[math]: loaded, using musl libm.
[ 82.498353] MOTENC: ERROR, unknown card detected
[ 84.960423] RTAI[math]: unloaded.
[ 85.031025] SCHED releases registered named ALIEN PEDV$D
[ 85.033507] RTAI[malloc]: unloaded.
[ 85.138915] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 85.156159] I-pipe: head domain RTAI unregistered.
[ 85.156163] RTAI[hal]: unmounted.
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Sat 22 Jul 2023 02:15:24 PM PDT
UTC Date: Sat 22 Jul 2023 09:15:24 PM UTC
this program: /usr/bin/linuxcnc_info
uptime: 14:15:24 up 4 min, 1 user, load average: 0.10, 0.40, 0.22
lsb_release -sa: Debian Debian GNU/Linux 10 (buster) 10 buster
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/robert/linuxcnc/configs/by_interface.vitalsystems
USER: robert
LOGNAME: robert
HOME: /home/robert
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1920x1080 pixels (508x285 millimeters)
PATH: /usr/bin:/home/robert/linuxcnc/configs/by_interface.vitalsystems/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: debian
kernel-name -s: Linux
kernel-vers -v: #5 SMP PREEMPT Sun Jul 11 19:13:27 BST 2021
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.195-rtai-amd64 root=UUID=b657697c-0bf8-4903-9250-3f8aee8bca89 ro initrd=/install/gtk/initrd.gz quiet
model name: Intel(R) Core(TM) i5-4690 CPU @ 3.50GHz
cores: 4
cpu MHz: 3229.143
parport:
serial: 0000-0000 : serial 0000-0000 : serial
Versions:
gcc: gcc (Debian 8.3.0-6) 8.3.0
python: Python 2.7.16
git: git version 2.20.1
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.4
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: /usr/realtime-4.19.195-rtai-amd64/bin/rtai-config
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii linuxcnc 1:2.8.4 amd64 motion controller for CNC machines and robots
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.8.4.1.gb7824717b all motion controller for CNC machines and robots (English documentation)
ii linuxcnc-doc-es 1:2.8.4.1.gb7824717b all controlador de movimiento para máquinas CNC y robots (Español).
ii linuxcnc-doc-fr 1:2.8.4.1.gb7824717b all motion controller for CNC machines and robots (French documentation)
un linuxcnc-sim <none> <none> (no description available)
rc linuxcnc-uspace 1:2.8.4.1.gb7824717b amd64 motion controller for CNC machines and robots
23 Jul 2023 19:53 #276103 by andypugh
Replied by andypugh on topic Difficulty building RTAI linuxcnc from source
I think that this means that the motenc device was not found, rather than that the driver was not found.
In the kernel log there is
So I think that the system is returning the ENODEV code from here:
github.com/LinuxCNC/linuxcnc/blob/master...rs/hal_motenc.c#L313
Ideally you would increase the rtapi debug level and try again.
To do this, insert "debug 3" in the HAL file above the "loadrt hal_motenc" line
23 Jul 2023 23:07 #276113 by southbayguy
Hi -
Thank you very much for your help.
I inserted a line "debug 3" immediately above the line "loadrt hal_motenc" in the file motenc_motion.hal,
which is at home/robert/linuxcnc/configs/by_interface.vitalsystems/
"Debug 3" did not seem to contribute much new except maybe more latency detail.
Comments about the Motenc board all cite the Motenc-100 board. I'm using an older Motenc-7544 board. Dunno if this matters.
I can pull and re-seat the board if that will help. It is encouraging that the kernel sees a PCI board. I guess it just doesn't know what to do with it.
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.4
VERSION=1.1
TASK=milltask
HALUI=
DISPLAY=tklinuxcnc
COORDINATES=X Y Z
KINEMATICS=trivkins
./motenc_motion.hal:5: exit value: 1
./motenc_motion.hal:5: insmod for hal_motenc failed, returned -1
3136
[91800.110178] I-pipe: head domain RTAI registered.
[91800.110180] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[91800.110182] SYSINFO - # CPUs: 4, TIMER NAME: 'lapic-deadline', TIMER IRQ: 4355, TIMER FREQ: 436496376, CLOCK NAME: 'tsc', CLOCK FREQ: 3491913000, CPU FREQ: 3491913000, LINUX TIMER IRQ: 4355.
[91800.113045] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[91800.113070] kstacks pool size = 524288 bytes
[91800.113070] RTAI[sched]: hard timer type/freq = lapic-deadline/436496376(Hz)
[91800.113071] linear timed lists.
[91800.113071] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3491913000 hz.
[91800.113072] RTAI[sched]: timer setup = 81 ns, resched latency = 0 ns.
[91800.119208] USERMODE CHECK: OK.
[91800.119209] USERMODE CHECK PROVIDED (ns): KernelLatency 581, UserLatency 694.
[91800.119210] FINAL CALIBRATION SUMMARY (ns): KernelLatency 581, UserLatency 694.
[91800.121540] RTAI[math]: loaded, using musl libm.
[91800.150350] MOTENC: ERROR, unknown card detected
[91802.443987] RTAI[math]: unloaded.
[91802.490705] SCHED releases registered named ALIEN PEDV$D
[91802.495351] RTAI[malloc]: unloaded.
[91802.602675] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[91802.620012] I-pipe: head domain RTAI unregistered.
[91802.620016] RTAI[hal]: unmounted.
pastebin.com
Date: Sun 23 Jul 2023 03:48:37 PM PDT
UTC Date: Sun 23 Jul 2023 10:48:37 PM UTC
uptime: 15:48:37 up 1 day, 1:37, 1 user, load average: 0.00, 0.00, 0.00
USER: robert
LOGNAME: robert
HOME: /home/robert
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
uname items:
nodename -n: debian
machine -m: x86_64
/proc items:
cores: 4
cpu MHz: 3603.331
parport:
Versions:
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
23 Jul 2023 23:30 #276115 by andypugh
Odd, 3 should show the "INFO" messages:
linuxcnc.org/docs/2.9/html/man/man3/rtap...sg_level.3rtapi.html
No harm in trying 5 I suppose.
Anyway, it does seem that the driver only supports the Motend-100 and Motenc-lite:
github.com/LinuxCNC/linuxcnc/blob/2.8/sr...rs/hal_motenc.c#L397
If you are prepared to build LinuxCNC from source, then it might turn out to be quite easy to modify the driver to support your board.
24 Jul 2023 01:43 #276118 by southbayguy
The odd thing is that the Motenc 7544 board is the Motenc-Lite board.
www.vitalsystem.com/portal/motion/motenc/motenc_lite.php
24 Jul 2023 08:53 #276135 by andypugh
OK, so we need to work out what values the driver is reading from the card to see where it is getting confused.
And setting the debug level higher ought to be giving us that information.
The driver does override the msg_level in one place, but should set it back afterwards.
github.com/LinuxCNC/linuxcnc/blob/2.8/sr...rs/hal_motenc.c#L451
24 Jul 2023 18:40 #276160 by southbayguy
I have tried varying the J7 jumpers. According to Vital Systems documentation for the Motenc Lite boards, there is a bit 0 board ID jumper and a bit 1 board ID jumper, and when the jumper is installed the value is 0. Even if I'm misunderstanding the Vital Systems documentation, there are only four states those two J7 jumpers can be in, and I have tried all four. The debug output has not changed. I have also tried setting the debug output at 5 and at ALL, again with no change. Looking at the hal_motenc.c code, the two board ID values the code considers valid are 0 and 1. If the board ID is zero, then the code thinks the board is a Motenc-100 board. If the board ID is zero, then the code thinks the board is a Motenc-Lite board. If the board ID is not zero or one, then the hal_motenc code writes an error "unknown card detected."
After trying these variations, with no change in result, I'm wondering if there might be something funkier going on, like the hal_motenc code is looking for the board ID in the wrong place ... something like that.
My confidence in the board itself is high because it has run a CNC mill for seven or eight years, running under Ubuntu. This was the original installation of LinuxCNC you helped me with. Both J7 jumpers were installed when the board was running that original machine.
I'm thinking the code (specifically the hal_motenc driver) has evolved since then while the Motenc hardware has not. Back when we put the first machine together, the Motenc-Lite board was mainstream hardware and the code expected its use. Perhaps that isn't true any more.
24 Jul 2023 18:49 #276161 by andypugh
boardID is different to fpga[0].boardVersion
That's reading something from the FPGA, but it's hard to know what without the debug working.
It really should be telling us what it found in this line:
rtapi_print_msg(RTAPI_MSG_INFO, "MOTENC: Card is %s, ID: %d\n", pDevice->pTypeName, pDevice->boardID);
Is there any chance that the FPGA has been reprogrammed by someone, at some time?
