Compiling linuxcnc 2.9 help on mint (SOLVED)
13 Aug 2023 03:22 - 13 Aug 2023 17:04 #277793 by fabled523
After somehow successfully installing the preempt_rt kernel I have been working at compiling linuxcnc 2.9 on linux mint.
All dependencies have been installed, attached is what I get after trying to compile.OS is mint 21.2, kernelĀ 5.10.180-rt89-rc1, i5 2500 8gb ram.
I also tried just installing linuxcnc 2.8.4 from a .deb file but i get a message saying dependency is not satisfiable: python (>=2.7). I have python 2.7.18-3 installed, not sure what the issue there is.
Any help would be appreciated.
EDIT: Recompiling with no-docs worked! Thank you very much!
Last edit: 13 Aug 2023 17:04 by fabled523. Reason: Solution Found
13 Aug 2023 04:05 #277796 by Aciera
Replied by Aciera on topic Compiling linuxcnc 2.9 help on mint
To build 2.9 from the github source (only that is currently possible on mint) use a fresh installation of mint install the dependencies. Leave the python alone! If you start fiddling with with python versions you're going to loose your mind.
If you still have problems I strongly recommend using Debian Bookworm and installing Linuxcnc from the Package manager.
  • Platinum Member
  • Platinum Member
13 Aug 2023 04:25 - 13 Aug 2023 04:30 #277798 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Compiling linuxcnc 2.9 help on mint
When you cd into the debian directory (before building packages )run configure with the
no-docs option
I have 2 machines running Mint 21.2 Victoria and this works.
This is what I have on my machine:
xxxxxx@xxxxxx:~$ cat /etc/lsb-release
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=21.2
DISTRIB_CODENAME=victoria
DISTRIB_DESCRIPTION="Linux Mint 21.2 Victoria"
xxxxxx@xxxxxx:~$ python --version
Python 3.10.12
Last edit: 13 Aug 2023 04:30 by Cant do this anymore bye all.
  • Moderator
  • Moderator
13 Aug 2023 11:00 #277813 by tommylight
Replied by tommylight on topic Compiling linuxcnc 2.9 help on mint
If you want to give Debian 12 BookWorm a try, use the Mate Desktop Environment, it is the same thing Mint uses.
Or XFCE if on an older PC.
Time to create page: 0.069 seconds
