MD5 Checksum doesn't match although downloaded with zsync
2 years 7 months ago - 2 years 7 months ago #296539 by reneas
As the title says I downloaded the newest release with:
zsync http://www.linuxcnc.org/iso/LinuxCNC_2.9.2-amd64.hybrid.iso.zsync
The output was:
#################### 100.0% 1854.5 kBps DONE No relevent local data found - I will be downloading the whole file. If that's not what you want, CTRL-C out. You s hould specify the local file is the old version of the file to download with -i (you might have to decompress it wi th gzip -d first). Or perhaps you just have no data that helps download the file downloading from http://www.linuxcnc.org/iso/LinuxCNC_2.9.2-amd64.hybrid.iso: -------------------- 0.0% 12.3 kBps #################### 100.0% 7389.8 kBps DONE verifying download...checksum matches OK used 0 local, fetched 3472884144
After downloading I ran the MD5 Checksum tool and got:
d541b51f02ecc6f07fe652faa0fc4a2b  LinuxCNC_2.9.2-amd64.hybrid.iso
which is different from the checksum at here
which says it should be
md5sum: 1815aceaac0e7861747aa34d61846e79
Also when I tried to run the whole thing on my PC I could boot into live session but when I started the installer it would just get stuck on a black screen and not do a thing forever.
Last edit: 2 years 7 months ago by reneas. Reason: formatting
2 years 7 months ago #296695 by reneas
Okay at least the installation worked now after resetting the BIOS to default settings. Still wondering why the Checksum didn't match...
2 years 7 months ago #296701 by tommylight
Thank you for reporting back.
2 years 7 months ago #296719 by JT
You're comparing different iso checksums so they won't be the same. The docs are listing md5sum linuxcnc-2.9.2-amd64.iso not the hybrid iso and they also state if you use zsync checking is not needed.
JT
2 years 7 months ago - 2 years 7 months ago #297245 by steveb48
Ah, I'm having a similar problem. I followed the instructions here (( linuxcnc.org/docs/stable/html/getting-st...etting-linuxcnc.html ) and the link downloads the hybrid iso. Not using zsync (on macOS). The listed checksums don't match probably for the same reason listed above. Is there another link I should be downloading from or is there a set of hybrid checksum? I did try to add zsync to my LinuxCNC machine and just do the download there but I get a file not found from FTP.
Thanks,
Steve
Last edit: 2 years 7 months ago by steveb48.
2 years 7 months ago - 2 years 7 months ago #297292 by steveb48
Replying to myself.
It turns out there's a zsync port for macOS on Homebrew.
I was able to download using:
zsync www.linuxcnc.org/iso/LinuxCNC_2.9.2-amd64.hybrid.iso.zsync
Note "http" not "https".
The download link produces LinuxCNC... and the instructions call for linuxcnc....
The dd instructions for macOS have the source file at root where the linux instructions start at the current directory.
I think I have it all sorted. We'll find out tomorrow when the new computer arrives.
The following user(s) said Thank You: jerry420
Time to create page: 0.075 seconds
