Hi all, hope you are all doing well.
I've tried installing the linuxcnc 2.9.2 ISO as described
here
. I initially tried to download using the link on the downloads page (using firefox 126.0 (64-bit)). This went fine (20MB/s, sweet). I got the file "
LinuxCNC_2.9.2-amd64.hybrid.iso" and compare the md5 checksum as well as the SHA256. None of them match!image missing /media/kunena/emoticons/sad.png
My result:
md5: d541b51f02ecc6f07fe652faa0fc4a2b LinuxCNC_2.9.2-amd64.hybrid.iso
sha256: a2c9df3d1a16c2e09c66bbb87869be876892fd6bf9182fc39009c944cbf8f800 LinuxCNC_2.9.2-amd64.hybrid.iso
Results in the article:
amd64 (PC)
md5sum: 1815aceaac0e7861747aa34d61846e79
sha256sum: 08b3f59233e47c91cf1c9a85c41df48542c97b134efefa7446d3060c9a3e644b
I tried downloading the file again (did you hear about the definition of insanity?). This gave the same results, so I tried to use the z-sync method. After installing z-sync (I am running Ubuntu 20.04)
, I got the following response:
failed on url
www.linuxcnc.org/iso/LinuxCNC_2.9.2-amd64.hybrid.iso
could not read control file from URL
Undeterred, I continued with my wrong checksum ISO and used
to write my the ISO to my FAT formatted USB drive. I plugged it into my sacrificial PC and tried to do a live version. However, once I saw the initial blue Debian 12, I was greeted with a bunch of errors along the line of:
SQUASHFS ERROR: XZ DECOMPRESSION FAILED DATA PROBABLY CORRUPT
together with some specific address that was apparently not working. I could get a CLI using ctrl+alt+f?3? I believe, and execute some basic commands (cd, ls, mkdir).
Anyway, I've googled a bit and what I understand 3 things could have gone wrong:
1. wrong iso.
2. incorrect writing to USB
3. fault in USB.
I don't think I did anything wrong while writing to the USB, but it could be that my USB is faulty. To rule that out I ordered a new USB stick. Lets see what it does when it arrives in the mail tomorrow. In the meanwhile, I hope to start the discussion on point 1:
-How come my checksum doesn't match, and why can I not use zsync?
Any ideas / tips / suggestions on this point or any other point in my message would be greatly appreciated.
Many thanks,
Jerry
