i will run sudo chrt 99 ping -i .001 -q 10.10.10.10, when i am in front of it again tomorrow. i have run that command before and let it run for several minutes. the ping times don't seem too bad with ping 10.10.10.10 and ping 10.10.10.1. > ~ .100 and ~.037 respectively. i'll get an accurate measurement in the morning.
what would be the drawbacks of reflashing the mesa 7i96s? a clean slate if you know what i mean. but i don't want to do something for no reason. if you think a re-flash would do anything or not.............
the reason i am questioning the mesa hardware is, i have an intel and an amd machine and i get very similar errors with both machines. im currently running on the dell vostro 270 i5. an extra ethernet card in both machines conflict and it is unable to start. but not right away. on either machine. if i install the OS with the card in, it conflicts. i have to install debian without the additional card in to get linuxcnc installed, run pncconf, setup linuxcnc, and then install additional ethernet card and it will run for a little while, but after i shut it off, it won't start back up inless i reinstall the OS.
at this point, even with that extra card out, i can go through pncconf and test each axis, but when in qtdragon, i get a watchdog error in the gui and the red light on the mesa 7i96s comes on and it makes me exit.
i
