Raspberry Pi OS PREEMPT RT 6.13 Kernel Cookbook
- gene_weber
- Thank you received: 19
15 Jan 2025 20:36 - 16 Jan 2025 13:53 #319049
by gene_weber
Raspberry Pi OS PREEMPT RT 6.13 Kernel Cookbook was created by gene_weber
I'm posting the steps I executed to build and install a PREEMPT RT Linux kernel in Raspberry Pi OS for my Pi 4B for two reasons.
NOTE: Version 6.13 of the Linux kernel is under development and could have bugs / issues. So far it's been stable for me, but your mileage may vary.
I started with a fresh installation of Raspberry Pi OS on my Pi 4B.
1/16/25 Edit: Based on responses after the initial post it was clear that the Wayland display protocol is non-optimal for LinuxCNC. A comparison of the baseline pre-optimized jitter was conducted where the only difference is the display protocol, Wayland vs X11. The latency histograms for each are included in those posts, and show a dramatic difference with X11 inducing significantly less jitter. Wayland is the default in the current Raspberry Pi OS, but is easily changed to X11.
You can check the session type: wayland
Launch Rasp-config command line tool in a terminal:Arrow down to "Advanced Options", and enter.
Arrow down to "Wayland Switch between X and Wayland backends", and enter.
If not on the line that says "W1 X11 Openbox window manager with X11 backend", arrow to it and enter.
The popup should say "Openbox on X11 is active" and have "Ok" highlighted. Enter.
It will return to the main screen. Use left-righ arrows to select "Finish". Enter.
Popup asks if you would like to reboot now, with "Yes" highlighted. Enter.
After reboot: x11
Raspberry Pi's documentation on how to build a kernel was used as the guideline for this process:
Download the source code for the 6.13 Raspberry Pi kernel:
Install the needed build dependencies:
Download the RT patches for v6.13 and the signature file. Starting here , select the tarballs link at bottom left of page. From the list of versions, select the 6.13 link .
Download the patch file patch-6.13-rc6-rt3.patch.gz:Download the signature file patch-6.13-rc6-rt3.patch.sign:
Verify the signature of the patch file. These were committed by Sebastian Andrzej Siewior.
Add the following two lines:
Get the public key for "Sebastian Andrzej Siewior <This email address is being protected from spambots. You need JavaScript enabled to view it.>"
Unzip the patch file:
Verify signature: gpg: assuming signed data in 'patch-6.13-rc6-rt3.patch'
gpg: Signature made Thu 09 Jan 2025 05:04:09 AM EST
gpg: using RSA key 57892E705233051337F6FDD105641F175712FA5B
gpg: Good signature from "Sebastian Andrzej Siewior <This email address is being protected from spambots. You need JavaScript enabled to view it.>" [unknown]
gpg: WARNING: This key is not certified with a trusted signature!
gpg: There is no indication that the signature belongs to the owner.
Primary key fingerprint: 6425 4695 FFF0 AA44 66CC 19E6 7B96 E816 2A8C F5D1
Subkey fingerprint: 5789 2E70 5233 0513 37F6 FDD1 0564 1F17 5712 FA5B
Go back to the linux directory created by the git clone:Patch the 6.13 RT kernel: patching file arch/arm/Kconfig
patching file arch/arm/kernel/module-plts.c
patching file arch/arm/kernel/traps.c
patching file arch/arm/mm/fault.c
patching file arch/arm64/kernel/ftrace.c
patching file arch/arm64/kernel/traps.c
patching file arch/loongarch/kernel/ftrace_dyn.c
patching file arch/loongarch/kernel/unwind_orc.c
patching file arch/powerpc/Kconfig
patching file arch/powerpc/include/asm/stackprotector.h
patching file arch/powerpc/include/asm/thread_info.h
patching file arch/powerpc/kernel/interrupt.c
patching file arch/powerpc/kernel/trace/ftrace.c
patching file arch/powerpc/kernel/trace/ftrace_64_pg.c
patching file arch/powerpc/kernel/traps.c
patching file arch/powerpc/kvm/Kconfig
patching file arch/powerpc/lib/vmx-helper.c
patching file arch/powerpc/platforms/pseries/Kconfig
patching file arch/powerpc/platforms/pseries/iommu.c
patching file arch/s390/kernel/dumpstack.c
patching file arch/x86/kernel/callthunks.c
patching file arch/x86/kernel/dumpstack.c
patching file arch/x86/kernel/unwind_orc.c
patching file arch/xtensa/kernel/traps.c
patching file drivers/gpu/drm/i915/Kconfig
patching file drivers/gpu/drm/i915/display/intel_crtc.c
patching file drivers/gpu/drm/i915/display/intel_cursor.c
patching file drivers/gpu/drm/i915/display/intel_display_trace.h
patching file drivers/gpu/drm/i915/display/intel_vblank.c
patching file drivers/gpu/drm/i915/gt/intel_execlists_submission.c
patching file drivers/gpu/drm/i915/gt/uc/intel_guc.h
patching file drivers/gpu/drm/i915/i915_request.c
patching file drivers/gpu/drm/i915/i915_trace.h
patching file drivers/gpu/drm/i915/i915_utils.h
patching file drivers/tty/serial/8250/8250_core.c
Hunk #1 succeeded at 403 (offset 15 lines).
Hunk #2 succeeded at 411 (offset 15 lines).
Hunk #3 succeeded at 541 (offset 15 lines).
patching file drivers/tty/serial/8250/8250_port.c
Hunk #4 succeeded at 3317 (offset 9 lines).
Hunk #5 succeeded at 3350 (offset 9 lines).
Hunk #6 succeeded at 3409 (offset 9 lines).
Hunk #7 succeeded at 3475 (offset 9 lines).
Hunk #8 succeeded at 3618 (offset 9 lines).
Hunk #9 succeeded at 3628 (offset 9 lines).
patching file include/linux/kallsyms.h
patching file include/linux/module.h
patching file include/linux/preempt.h
patching file include/linux/serial_8250.h
patching file kernel/cfi.c
patching file kernel/jump_label.c
patching file kernel/kprobes.c
patching file kernel/ksysfs.c
patching file kernel/livepatch/core.c
patching file kernel/module/internal.h
patching file kernel/module/kallsyms.c
patching file kernel/module/main.c
patching file kernel/module/tracking.c
patching file kernel/module/tree_lookup.c
patching file kernel/module/version.c
patching file kernel/sched/core.c
patching file kernel/static_call_inline.c
patching file kernel/trace/bpf_trace.c
patching file kernel/trace/trace.c
patching file kernel/trace/trace_kprobe.c
patching file lib/bug.c
patching file lib/dump_stack.c
patching file localversion-rt
- Hopefully it helps someone trying to do this or something similar. I appreciate the pointers I got from alangibson, cornholio, and rodw
- This is the first Linux kernel I've ever built. So I open this up to comments and suggestions.
echo $XDG_SESSION_TYPELaunch Rasp-config command line tool in a terminal:
sudo raspi-configArrow down to "Wayland Switch between X and Wayland backends", and enter.
After reboot:
echo $XDG_SESSION_TYPERaspberry Pi's documentation on how to build a kernel was used as the guideline for this process:
git clone -b rpi-6.13.y --depth=1 https://github.com/raspberrypi/linuxInstall the needed build dependencies:
sudo apt install bc bison flex libssl-dev makeDownload the RT patches for v6.13 and the signature file. Starting here , select the tarballs link at bottom left of page. From the list of versions, select the 6.13 link .
curl -OL https://cdn.kernel.org/pub/linux/kernel/projects/rt/6.13/patch-6.13-rc6-rt3.patch.gzcurl -OL https://cdn.kernel.org/pub/linux/kernel/projects/rt/6.13/patch-6.13-rc6-rt3.patch.signcd ~/DownloadsVerify the signature of the patch file. These were committed by Sebastian Andrzej Siewior.
mkdir .gnupgvi .gnupg/gpg.confAdd the following two lines:
auto-key-locate wkd,dane,localauto-key-retrieveGet the public key for "Sebastian Andrzej Siewior <This email address is being protected from spambots. You need JavaScript enabled to view it.>"
gpg --locate-keys [email]bigeasy@linutronix.de[/email]Unzip the patch file:
gzip -d patch-6.13-rc6-rt3.patch.gzVerify signature:
gpg2 --verify patch-6.13-rc6-rt3.patch.signgpg: Signature made Thu 09 Jan 2025 05:04:09 AM EST
cd ~/linuxpatch -p1 < ~/Downloads/patch-6.13-rc6-rt3.patchpatching file arch/arm/kernel/module-plts.c
Last edit: 16 Jan 2025 13:53 by gene_weber.
The following user(s) said Thank You: behai
- gene_weber
15 Jan 2025 20:38 - 16 Jan 2025 14:32 #319050
by gene_weber
Replied by gene_weber on topic Raspberry Pi OS PREEMPT RT 6.13 Kernel Cookbook
Create the base .config file for the Raspberry Pi 4 64-bit:
NOTE: For a Raspberry Pi 5 64-bit the lines should be:
Make / launch the menuconfig utility:
Install the required package:
Under General Setup, select: Fully Preemptible Kernel (Real-Time)Exit and Save.
Change Local version name. vi .config and change the following line:To:
Build the kernel and log the output (Note this took over 2 hr 10 min):
NOTE: During the compilation process the temperature of the ARM processor increased from ~30°C to as high as 43°C. I have a heat-sink and cooling fan on my Pi. If you don't, you may want to keep an eye on the temp (/usr/bin/vcgencmd measure_temp). The maximum rating on the Pi is 85°C.
Install the kernel modules onto the boot media and log the output:
create a backup image of the current kernel, install the fresh kernel image, overlays, README, and unmount the partitions:
Reboot the Raspberry Pi to run the new kernel:
Check kernel after reboot: Linux raspberrypi 6.13.0-rc7-rt3-v8_full_preempt+ #1 SMP PREEMPT_RT Tue Jan 14 12:49:46 EST 2025 aarch64 GNU/Linux
From the LinuxCNC downloads page , download LinuxCNC Uspace 2.9.3 arm64 .
Install the Gdebi installer:Run the Gdebi installer and install linuxcnc-uspace_2.9.3_arm64.deb
EDITED 1/16/25: Changed image to X11 pre-optimization latency.
Ran a baseline latency test before making any jitter optimizations. Note: Using POSIX realtime
I checked the real-time attributes of the latency-histogram process (the process ID for this run was 10527): pid 10527's current scheduling policy: SCHED_OTHER
pid 10527's current scheduling priority: 0
I had thought the policy would be SCHED_FIFO, or SCHED_RR. But even after I added CPU isolation it remains SCHED_OTHER.
I will probably create a separate thread about jitter optimization.
KERNEL=kernel8make bcm2711_defconfigNOTE: For a Raspberry Pi 5 64-bit the lines should be:
KERNEL=kernel_2712make bcm2712_defconfigMake / launch the menuconfig utility:
sudo apt install libncurses5-devmake menuconfigUnder General Setup, select: Fully Preemptible Kernel (Real-Time)Exit and Save.
CONFIG_LOCALVERSION="-v8"CONFIG_LOCALVERSION="-v8_full_preempt"Build the kernel and log the output (Note this took over 2 hr 10 min):
make -j6 Image.gz modules dtbs 2>&1 | tee make.logNOTE: During the compilation process the temperature of the ARM processor increased from ~30°C to as high as 43°C. I have a heat-sink and cooling fan on my Pi. If you don't, you may want to keep an eye on the temp (/usr/bin/vcgencmd measure_temp). The maximum rating on the Pi is 85°C.
sudo make -j6 modules_install 2>&1 | tee install.logcreate a backup image of the current kernel, install the fresh kernel image, overlays, README, and unmount the partitions:
sudo cp /boot/firmware/$KERNEL.img /boot/firmware/$KERNEL-backup.imgsudo cp arch/arm64/boot/Image.gz /boot/firmware/$KERNEL.imgsudo cp arch/arm64/boot/dts/broadcom/*.dtb /boot/firmware/sudo cp arch/arm64/boot/dts/overlays/*.dtb* /boot/firmware/overlays/sudo cp arch/arm64/boot/dts/overlays/README /boot/firmware/overlays/Reboot the Raspberry Pi to run the new kernel:
sudo rebootCheck kernel after reboot:
uname -aFrom the LinuxCNC downloads page , download LinuxCNC Uspace 2.9.3 arm64 .
sudo apt install gdebiEDITED 1/16/25: Changed image to X11 pre-optimization latency.
latency-histogram --nobase --sbins 1000I checked the real-time attributes of the latency-histogram process (the process ID for this run was 10527):
chrt -p 10527pid 10527's current scheduling priority: 0
Last edit: 16 Jan 2025 14:32 by gene_weber.
The following user(s) said Thank You: tommylight, rodw, gmr, behai
- Thank you received: 4149
15 Jan 2025 22:12 #319057
Replied by rodw on topic Raspberry Pi OS PREEMPT RT 6.13 Kernel Cookbook
This is badly needed based on the reported latency which is unusableI will probably create a separate thread about jitter optimization.
- Thank you received: 426
15 Jan 2025 23:36 #319061
Replied by Cant do this anymore bye all on topic Raspberry Pi OS PREEMPT RT 6.13 Kernel Cookbook
16 Jan 2025 00:03 #319063
If you're using a Rasp OS image you'll want to swap from wayland to X if you are looking to run axis, the "compatibility layer" is "not quite optimum".
- gene_weber
16 Jan 2025 00:08 #319064
by gene_weber
Thanks for the heads up regarding wayland and axis.
16 Jan 2025 00:29 #319067
It would be interesting to see the latency values after switching to X. This can be done via the config utility for the Rpi, the actual binary name escapes me ATM.
16 Jan 2025 01:19 #319074
In a Debian environment tasksel allows you to install a number of desktops. There is a (X) reason why we use XFCE in the linuxcnc images. It uses X windows not wayland
16 Jan 2025 01:36 #319076
First of all your opening post was great. I'm actaully giving it a go now, just wish I had a nvme drive hooked up to the PCIe bus.
There's a couple of points regarding Linux kernels.
Sometimes the latest kernel may not be the optimum for your hardware.
The kernel you are using is a "release candidate" whilst usable for all intents is still going through some work.
The 6.1.y branch works fine on the RPi4, I think the kernel in the Linuxcnc image maybe 6.1.54
The RPi platforms with regards to Linuxcnc are a little different to the x86 platforms. Your Rpi4 & Rpi5 hardware is what it is. Whereas you may need a specific kernel dpending which x86 motherboard you buy.
The Rpi branch that appears to be active is the 6.6.y branch, so one could assume this is the branch that is receiving the most "bug fixies".
Simple things like isolating cores 2,3 will see latency drop. There doesn't seem to be as many options/tricks for latency on the RPi platforms as the x86 platforms.
I would chose to use a kernel that is a couple of version behind the the latest and greatest if it more tried in the real world and has better latency.
In my discussions with royka we talked about the fact that a kernel that is a little older is sometimes the better option.
Due to the issues with wayland I would recommend the use of the image form the Download page, Xorg is used. Plus it's easier to deploy
Mind tho I'm not saying this is the only way to do it.
What I would suggest is trying some of the earlier kernels to see how performance differs.
One thing regarding the 6.6.y branch.
The latest version is 6.6.70 which I couldn't find any real time patches for.
The previous commit is 6.6.65 for which there are rt patches, but for some reason the overlay's aren't in the source. Which is a pain when building an image using Rod's image builder.
It seems, ATM, the deeper you dive it can seem a little confusing.
Sorry for the multiple posts but this editor is PITA.
16 Jan 2025 02:41 #319081
Time to create page: 0.172 seconds
