Issues installing LinuxCNC
1 year 5 months ago #328536 by besi99
Hello,
I just installed my first Linux version on an old Thinkcentre i have laying around. Iam planning onbuilding a new CNC using LinuxCNC so I thought maybe I can and lear how to use it before i finish my CNC. Kinda just to get used to Linux.
So after like 2 hours I finally managed to get debian 12.10.0 running on my Thinkcentre. Then I started to follow the instructions on the LinuxCNC page.
I did the updates:
sudo apt-get update
sudo apt-get dist-upgrade
Then I installed the Preempt-RT kernel
sudo apt-get install linux-image-rt-amd64
everything worked fine. After the restart it selected the right linux RT version.
So the issue starts here.
If i click on the link for the linuxcnc-install.sh file it doesnt download anything. So where exactly do I get the script? Iam probably just to stupid to understand it.
Also chmod +x linuxcnc-install.sh doesnt work. I have even tried opening an txt.file and naming it linuxcnc.install.sh with the script from the browser. But still nothing.
Found another thread with simillar issue
$ chmod +x besnik/home/Downloads/linuxcnc-install.sh
Or better yet
$ cd besnik/home/Downloads/
$ chmod +x linuxcnc-install.sh
Always says No such file or directory.
Does anyone have an idea what I am missing I can already deel its something easy to fix I just dont see it. Kinda embarrassing asking for help :D
1 year 5 months ago #328539 by tommylight
Both seem wrong, should always be
/home/user_name/Downloads
or in your case
/home/besnik/Downloads
P.S.
Pershendetje me shumic.
1 year 5 months ago #328549 by besi99
Replied by besi99 on topic Issues installing LinuxCNC
Okay thats a good tip that thoose commands are wrong. I found thoose commands on the forum.I tried the commands with the order you told. But I still get the same error. I took some pics maybe they help.
Thanks for trying to help me :)
- Shume flm per ndhime
1 year 5 months ago #328552 by Todd Zuercher
You had the directory tree order wrong. You typed "cd home/besnik/downloads/" and it needs to be "cd besnik/home/Downloads/". Also Linux is case sensitive so the capitol leter "D" is also important.
The following user(s) said Thank You: besi99
1 year 5 months ago #328553 by tommylight
home and besnik are in the wrong places again and Downloads starts with upper case D. Linux is case sensitive so D and d are not the same.
Copy and paste from here:
cd /home/besnik/Downloads
sudo chmod +x /home/besnik/Downloads/linuxcnc-install.sh
./linuxcnc-install.sh
1 year 5 months ago #328558 by besi99
Man I definetly need to take some sleep....
It definetly did something this time. Thanks for youre help guys. I was ready to just go back to Estlcam and windows haha.
If I go to Applications -> CNC there are only two options there is Documentation and G-Code Quick Reference. There is no LinuxCNC application does that mean somthing went wrong with the installation? I did a restart same thing.
Time to create page: 0.177 seconds
