7i92M very weird communication problem!!!
1 year 4 months ago #331087
by ANGELOS13
7i92M very weird communication problem!!! was created by ANGELOS13
OK here we go:
1. 7i92m with a BOB, and the latest Linuxcnc.
2. card is setup at ip 10.10.10.10 it pings and i can flash the card with the bin file using MesaCT
3. Tested the card with the pathpilot and it works and moved the table.
4. when i use the linuxcnc pncconf wizard or the linuxcnc all comunications with the card stops, even the ping stops responding.
I'm stuck here any ideas?
Angelos
Angelos
1 year 3 months ago #331107
Replied by PCW on topic 7i92M very weird communication problem!!!
Not sure about pncconf, but LinuxCNC deliberately blocks card access when running.
1 year 3 months ago #331110
by ANGELOS13
Replied by ANGELOS13 on topic 7i92M very weird communication problem!!!
Good to know, the only thing is that as soon the linuxcnc is open there is no lights activity at the Ethernet port,
1 year 3 months ago #331120
If there was no communication, LinuxCNC should exit.
Are you saying LinuxCNC is running but you have no activity light
(green LED on 7I92 RJ45)?
What does:
ip a
report when in this state?
What does:
ip a
1 year 3 months ago #331128
by ANGELOS13
1 year 3 months ago - 1 year 3 months ago #331130
OK, so there is a real time issue that needs to be addressed
before LinuxCNC will run on that system.
To get a rough idea of network latency:
sudo chrt 99 ping -i .001 -q -c 60000 10.10.10.10
This will run for a minute and then print statistics.
Last edit: 1 year 3 months ago by PCW.
Time to create page: 0.060 seconds
