7i92M very weird communication problem!!!
02 Jul 2025 04:34 #331087 by ANGELOS13
OK here we go:
1. 7i92m with a BOB, and the latest Linuxcnc.
2. card is setup at ip 10.10.10.10 it pings and i can flash the card with the bin file using MesaCT
3. Tested the card with the pathpilot and it works and moved the table.
4. when i use the linuxcnc pncconf wizard or the linuxcnc all comunications with the card stops, even the ping stops responding.
I'm stuck here any ideas?
Angelos
02 Jul 2025 15:13 #331107 by PCW
Not sure about pncconf, but LinuxCNC deliberately blocks card access when running.
02 Jul 2025 15:59 #331110 by ANGELOS13
Replied by ANGELOS13 on topic 7i92M very weird communication problem!!!
Good to know, the only thing is that as soon the linuxcnc is open there is no lights activity at the Ethernet port,
02 Jul 2025 19:34 #331120 by PCW
If there was no communication, LinuxCNC should exit.
Are you saying LinuxCNC is running but you have no activity light
(green LED on 7I92 RJ45)?
What does:
ip a
report when in this state?
02 Jul 2025 21:36 #331128 by ANGELOS13
Linuxcnc is running, the light on the rj45 stays solid green and the lights on the board stay solid without any activity.
02 Jul 2025 22:09 - 02 Jul 2025 22:10 #331130 by PCW
OK, so there is a real time issue that needs to be addressed
before LinuxCNC will run on that system.
To get a rough idea of network latency:
sudo chrt 99 ping -i .001 -q -c 60000 10.10.10.10
This will run for a minute and then print statistics.
Last edit: 02 Jul 2025 22:10 by PCW.
02 Jul 2025 22:56 #331131 by ANGELOS13
--- 10.10.10.10 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 60420ms
rtt min/avg/max/mdev = 0.057/0.276/16.993/0.227 ms, pipe 2
02 Jul 2025 23:20 - 02 Jul 2025 23:22 #331132 by PCW
OK that (almost 17 ms) is the issue.
Depending on the Ethernet hardware on the host, solutions are:
If it's a Realtek MAC, install the DKMS driver
Disable PCIE/Ethernet power management
Make sure all power management is disabled in the BIOS
It that's not good enough, pin the Ethernet IRQ to the last processor
and use isolcpus in the kernel command line.
Here's a long  thread on solutions to this issue:
forum.linuxcnc.org/18-computer/56380-error-finishing-read-sigh
Last edit: 02 Jul 2025 23:22 by PCW.
05 Jul 2025 02:51 #331293 by ANGELOS13
I reinstalled the ethernet drivers and got it down to 12ms so got it working for now, all tho at slow speeds. I order a faster mini computer so I hope that gets fixed, I installed a 7i76u daughter card, I flashed the bin file and nothing again the CR3 led is yellow and CR6 led is red. I installed the 7i92 with 7i76 bin file.
Time to create page: 0.356 seconds
